molten land narrative continue:
this narrative really stuck in your head in that:
you were having trouble leveling an area, getting frustrated, ripping apart your Japan robot, what an idiot
wondering why you could not get it to level properly
the angle you run your machine, similar to the angle of how you run your flame
drop you molten into the low area by aiming around the low point turning the higher points into molten and they successfully fill your low point
this discipline / action lead you to now:
like a Japanese artist, your realm is your canvas
you swing that big steel bucket around after playing with the lava, with a new understanding of how to grade your realm properly, instinctually
somehow your rear bracket did not break, but you are nervous it will breaks since now the front support is flexing/broken
later today:
we are fixing to cut an I beam that is laying around, we fixing to melt a massive I beam and go insane with the flame, fusing together your robot so it does NOT come apart again
that bracket that did not break: you are really surprised and amazed that your molten rebar nail bracket complex held, and so amazed/grateful
50 something page into your thread, the narrative beg the reader:
go play you with the molten, your life is bs and all your everything is nonsense
if you play you with the molten, it will solve problem that you have been trying to solve for decade and decade!
i beam: figure you out a way to cut it, and somehow use it to hold together that front support that keep busting
maybe: melt you some 90s on both side of your busted support,
or get crazy and come up with elaborate pattern that will hold
you dont know yet, just keep brainstorm, no decision
also, you do have 2 inch square tube that can be used to make 90s etc
the only problem: using cut off disc difficult, you need miter saw or something expensive
you still aint no magician, that front support busting making all the rest of your robot come apart
try to go cut you that I beam and make your 90s for your support,
if you cant cut them, then you need a special blade for your miter saw
again, your fel valve bust, setup lumber give it support
put you a locking vice onto a bolt head laying around where you broke your weld
tired of your magic trick not working, spread you massive molten longway
your fixing to run out of magic gas if you cannot get your robot to stay put together
woah narrative wont let you go:
"manipulate you the molten and level out your realm are connected left and right foot,
your talent in those is synonomous, in your ability to do them properly
get you better at playing with the molten, get you better at shaping your realm with your robot"
stop ramblin go finish you a magic trick
lost in molten, superman start to lose his power
you ran out of magic gas
million other task you need to get to,  and no magic gas to keep magic show,
say you - i wish i had infinite magic gas and play with lava from now until the end
