Fixing hole in side of block
Status
Not open for further replies.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Might need to get 2 L305 tractors for 1000, stripping body get ready for paint
Steering wheel fully seized to shaft, hit hard with air diesel torch air chisel, nothing works, broke round part trying to unseize it
Picture: let it sit in solvent while I put tractor on blocks thinking of what to do about steering wheel seized
@D2Cat
Yes, she is in amazing shape
Hit it hard with torch, air chisel, won't budge, burned melted top and bottom
Let it sit for a day, clean body
Pointed metal and compressed air, now, poke diesel brush into crevices, soak body in diesel
This video show you science of how solvent clean metal
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Seized steering wheel sat in transmission fluid and acetone over night, clean body get ready for blue paint
Goal: Try again to unseize steering wheel, finish wire wheeling body, and give one last wash, then use up rest of blue paint
Why cleaning is important: notice separation from loosened bolts, ton of crud was here, crud make panels separate from hot and cold cycles
Old steel coming back to life
Hitting steering wheel torch, get ready to hit with air chisel
Cooking steering shaft, melting plastic, at this point I consider destroying it to get it off
I am 2-3 hours into trying everything to unseize steering wheel
Sharpened air chisel destroying steering wheel, it is fully seized
@D2Cat
Paint hardener: yes I agree, if I would have put hardener in that engine paint, it would have dried hard and not have lizard look
@fried1765
Why sand don't get in the paint:
When I hit it with solvent, it charges the metal to be repellent to holding dirt,
watch video from last post
I give up, sharpened chisel few times, fully seized
Start cutting steering wheel
After hours of air chisel, slice steering wheel with cutting disc
5,188
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Raise fuel tank to access loose gear box
Empty diesel tank, take bolts off, raise it to reach gearbox problem
Took out fuel tank and steering in one shot
Mistake: did not have to destroy steering wheel, it would've come out and
I would have been able to seal up and fasten the gearbox properly
keep cleaning, get to painting chassis
Hit entire body with wire wheel, hit with compressed air, hit with cleaner
Now: hit with air, tape off handles, hit with paint
First coat paint
5,164
This work is inspired by real events and may have been fictionalized for creative purposes. Names, parts suppliers, and details have been changed to protect privacy and enhance the narrative. Any resemblance to actual tractors, living or dead, or actual events is purely coincidental and not intended by the thread starter.
The author makes no claims to the accuracy of events or the portrayal of this repair and is not liable for any misinterpretation. This story is provided “as is,” and any opinions expressed are those of the forum members and do not reflect the views of the thread starter.
Reactions: 6 users
7,669
CAT, once again you mention something I know nothing about :D :D
Can you point online to an example (for enamel paint?) All I see is stuff to solidify old paint for disposal. Or is that it?? Thanks..
Just type in something like "auto paint hardener".
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Daylight pictures
Main bearing case bolt dilemma:
I cannot get myself to pay $65 for a bolt
Then, I still need 2 connecting rods and 2 pistons for this engine
$800 just for 2 connecting rods and 2 pistons new
My narrative: why not just buy 2 whole engines for the same cost?
But I am scared that now I will turn into that guy with tons of parts all over their yard
Or, am I making the smart decision and saving money?
Please critique my dilemma
There is tractor parts all over the yard, and now I want to grab 2 more tractors and have more parts laying around?
Maybe that is the proper rythym - fix one engine at a time by buying entire tractors instead of paying retail for new parts
Summary: I did rebuild the engine with the hole in it with many parts of the engine that now I need to build
Meaning I saved tons of money so far in not buying 2 connecting rods for the engine that is complete
But now that engine need 2 connecting rods, 2 or 3 pistons
That alone minimum is $1000
This is why I keep going back to deciding to get whole tractors instead of new parts
@L35
Right? Having junk laying around is better than paying $1000 for a few pieces of steel
And
With getting 2 L305 tractors, I would have tons of all the bolts, extra gears, crankshafts etc
And I would have 2 d1301 engine blocks that that I can maybe turn into one working engine
Found bolt on Coleman for $15, ordered it since
it would move engine build all the way forward most of engine on tractor, everything but head and oil pan, then
at that point, I can go get another engine or two and pull pistons out of those and put them into the current build
@Vlach7
yes I am considering that, it could be true, that if I get 2 more d1301 engines that I might be able to
finish building current engine and MAYBE be able to put together another good d1301 engine
total I would have 3 running tractors, and I would sell one and would we can experiment with what the market is willing to pay
ok yes I am decided now: save up for more d1301 engines and go get them
only use part suppliers for small purchases
get more tractors and maybe build one to sell
ok plan for this week: put wheels on running tractor, test run make sure she don’t leak, then put loader on tractor and make progress on the hydraulic lines
and if the bolt show up, I can also reassemble the other engine all the way to piston installation
regardless, schedule should be full and I should not have to order anything, or wonder what to do
before running tractor on wheels, make sure fluids are in the axles and the transmission
found genuine used Kubota connecting rods for less than $100
these connecting rods are in tons of other Kubota engine so they are interchangeable
solved: don’t need to get more tractors
I also found Taiwanese pistons for $50, tons of people buy them, they seem well made
more and more I am finding these parts cheaper and cheaper, I found 4 sets of rings for $100, new open box
Moose7060
Oct 14, 2023
827
2,243
bc
Keep doing what you are doing Joe. It was an interesting thread to follow and it makes no difference what others may think. Just do what makes you happy.
Reactions: 6 users
L35
Jun 13, 2010
710
829
CT
Someone explain this post, why is this being said?
Daylight pictures
Meaning I saves tons of money so far in not buying 2 connecting rods for the engine that is complete
I don’t think an extra engine or 2 hanging around will change the landscape much. I’d go for it.
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Its only time before somebody will need a part you have laying there, and you will be able to recoup some of your costs.
7,669
Depending on your location you may be able to use all the parts you need and sell the remains of what you don't want to inventory. Post on the internet the items you want to sell, someone is looking for them!
5,449
Y'all can say whatever you want, but for the record, 40,000+ views is damn impressive.
Gotta give Joe props for that. (y) (y)
6,307
yes, I know too late to th eparty but...
curious..... Would it have been possible to remove the steering wheel AND the shaft as one piece ?
If so, it could have been held in a good sturdy vice and then a 'pickle fork' used to push the steering wheel off.
Gotta give Joe credit ! He's like the Energizer bunny..keeps on going and going and going and .......
Status
