pokey1416
Jun 24, 2020
572
885
SW Michigan
So every year I check torque on BH subframe before installing the BH92. This year (I’m really late) I stripped a bolt just like last year, like WTF 😬. The Mrs says did you check the manual? Yes, please get me a beer (note to self - dumb request!). I pull up the WSM and the torque says 275lbs. like I’ve been doing (actually 250 cause that’s as high as my wrench will go). BINGO! I notice that the bolts I’m stripping are not in the same location as the 275lbs one, so I read a few more pages and discover I’m on the connecting plate and factory is 145-166ft lbs. I slink into the house to get my own beer and order more replacements.
  1. Don’t assume that “subframe” torque is the same for every bolt.
  2. Keep mouth shut and get your own beer!🍻 IMG_0781.jpeg IMG_0779.jpeg IMG_0780.png
Reactions: 10 users
lynnmor
B2601-1
May 3, 2021
1,798
1,605
Red Lion
  2. Keep mouth shut and get your own beer!🍻 View attachment 134543
What's up with the short bolts?
5,164
Would a ZTR work for you?
They are MUCH more maneuverable, less tiring to use, and much faster!
I have a 42" ZTR and it takes me longer to use that than the 60" rear finish mower. The strawberry patch is going to be removed this fall and once I don't have to mow around that, it should cut my mowing time by a minimum of 30-45 minutes.
pokey1416
Jun 24, 2020
572
885
SW Michigan
OEM calls for same bolts both sides and this side has an extra piece in it. They protrude on the other side so I’m assuming it was a cost consideration to use them for either side?
Old_Paint
Dec 5, 2020
2,039
2,308
AL
I would assume they goofed.
Per ASTM, 2 threads in the nut will hold the shear strength of the bolt. Not sure I would agree either, but if Kubota can save $.03/bolt……I prefer to see at least 2 threads sticking out of the nut. My experience in MV switchgear has never been pleasant with short bolts.
5,187
How many acres is your "strawberry patch"?
lynnmor
B2601-1
May 3, 2021
1,798
1,605
Red Lion
I doubt that it is about the $.03, I also know better than using bolts that don't reach thru the nut. Any engineer that believes that two threads will hold a bolt needs to find employment where he doesn't endanger others.
Gasifier
2014 Kubota M59TLB, 2016 Kubota RTV X1140C, 2024 Land Pride RCF 2072
Didn't you sell one last year?
Yes. I usually buy and sell one a year. Sometimes two. Get a LOT of work done with them and then see if I can get my money back. Sometimes I lose a little, sometimes I make a little. And now I’m tired of it. Keeping this one. :)
3,851
2,392
The nice weather this week inspired me to buy Katy a tree puller. I found a reasonably priced Land Honor about 90 miles from home, so I took a road trip. Saturday, I'll deliver it to the farm and we'll try it out. I think I'll have to improvise some hydraulic connections.
5,187
It is 323 1/3 of an acre. Just enough to be a nuisance to have to mow around. The birds and critters get to the strawberries before my wife can pick them.
I understand the problem.
I would grow some sweet corn,......and the coons would eat it the day before I was ready to pick.
Old_Paint
Dec 5, 2020
2,039
2,308
AL
I agree with you. But I had that argument more than once with a lot of different manufacturers that paid more for the warranty repairs than a longer bolt would have ever cost them. Just remember, if you want 5 ONLY ways to do something, just ask 5 engineers. I’m a firm believer that if at least one thread isn’t showing, the bolt is too short, and as an engineer, that’s my ONLY way.
