Brake carnage!!
lynnmor
B2601-1
May 3, 2021
1,786
1,595
Red Lion
I had a sticking caliper on my F250 and thought that the Ford warranty should make the repair. They said that it was due to rust and I would be charged over $700 to repair the front brakes. I said that I would repair it myself and found some very light rust that didn't harm a thing and the sticking was simply dry pins. In this photo you will see that the skilled Ford technician bent the hard part of the brake hose to get at the bolt with power tools and then left it clothe lined across the coil spring where it could have failed at any time. I have to do absolutely everything because of the nutjobs in the industry.
11,755
Damn! That's very disappointing for sure, but once again reminds me why I prefer to do all my own maintenance and repairs.
11,755
I just got a call from the local UPS depot to tell me that the brake rotors and pads arrived this morning, quite a few days ahead of schedule, so I can get everything installed this weekend. I might have to go back to plan A in terms of bleeding the brakes since that fancy Motive brake bleeder won't be here until next week.
WI_Hedgehog
Apr 24, 2024
1,128
1,645
Milwaukee, Wisconsin, U.S.A.
...I'm pleased with the remanufactured caliper I picked up today from NAPA. It's a Ford part that they've serviced/rebuilt and not some RockAuto mystery brand....
I order parts from RockAuto, though get commercial duty replacements; they've been great so far, better than OEM. Anything worth doing is worth overdoing.
11,755
I always try to buy the factory repair manuals for my vehicles and have really good manuals for the '98 Jeep TJ and '02 F250. I bought this used Ford set on eBay for $150 back in 2018 or so and it's thousands of pages of specs, troubleshooting, procedures and wiring diagrams.
I finished the front brakes this evening and will get to the rear brakes early tomorrow. Many of us here have done plenty of brake jobs over the years and they're probably one of the easiest jobs to tackle on a vehicle.
11,755
I finished up the installation of new rotors and pads at all four corners yesterday. I decided not to replace the parking brake shoes for three reasons. First, there appears to be enough pad material if the Ford manual spec of 1.0mm (0.039") above rivets or backing plate is to be believed. Second, replacing those shoes requires the axles to be pulled and I don't want to deal with seals. And finally, a new set for the rear is $106 and it doesn't seem like money well spent at this point.
I cleaned all the important parts, installed new rubber boots on the caliper pins, and greased the caliper pins and every other part of the caliper and pads based on instructions with the brake kit.
Now I'm just waiting on the Motive brake bleeding kit to show up so that I can bleed the brakes.
Back right.
Back left.
7,572
I just redid the front brakes on my dodge 2500. Pads, shoes, rotors, calipers, brake hoses.
I found these caliper pistons of Ebay and thought about using them but didn't want to wait and mess with them. They would be a bargain to replace the pistons rather then the entire caliper.
11,755
I'm more than happy with new rebuilt and painted Ford calipers for the price. If they were a couple of hundred each I'd probably go to the trouble of rebuilding them, but for $92 or whatever it was, for Ford parts, I'm good with that, particularly since every part except the actual caliper is new.
I've checked the rear brake hoses and have confirmed length and ordered a set of brake hoses from KLM Performance. I do a lot of towing and 22 year old brake hoses might not be the best for that application. I installed stainless steel brake hoses on my Jeep decades ago and it improved braking, not to mention the fact that the braided lines are more robust in off-roading situations.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,559
Does that set of lines include the jumper hose from the axle hard line to the caliper?
11,755
@Fordtech86 is right, and I ordered the complete set with the clear stainless finish. I'm not into all those fancy colors. My Jeep has the clear stainless steel braided hoses which look good decades later.
Oh, I also added the +2" lift option for an additional $3.75 so the total cost with UPS ground shipping was $330.51. Not a cheap upgrade, but worth it to me. The ability to stop is probably more important than the ability to go. 😂
I plan on buying a new (used) truck in a couple of years or so but don't intend to sell or trade this tuck so it's worth putting money into it. I bought it from a pilot friend of mine for $8k in July of 2018 with 117,000 miles on the odometer. He was the original owner and could have easily sold it for twice what I paid for it and probably closer to $20k but wanted it to go to a good home. As an American Airlines pilot flying international it's not like he needed the money! He'd already done a number of upgrades over the years such as a Banks Power turbo back 5" exhaust system along with boost, EGT and transmission temperature gauges which I'm still running as redundant gauges since I have a DP-Tuner chip and programmer with that information on the display.
It has been a very reliable truck for me for the past 6 years requiring very little in the way of necessary work. Most of the money spent on this truck has been upgrades that I wanted to do. I sold the SnugTop for $1,500 so the truck actually cost me $6.5k.
11,755
Wow, theyal are proud of those caliper lines 😂
Braided stainless steel brake hoses have always been expensive. I remember installing them on an Accura Integra back in the mid '90s and they weren't cheap then. I just remembered that the braided hoses on my Jeep came with the Rubicon Express 3-1/2" lift kit that I installed.
Given that a complete set of Motorcraft brake hoses costs around $160 or more and doesn't include the line from the axles to the hard lines on the body, these KLM hoses aren't ridiculously expensive.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,559
Oh, I know they aren't cheap. 3 motorcycles, 2 Jeeps, 2 BMWs and 2 VWs have them. I was talking about the $94 for just the jumper hoses on the rear axle. That's the proud part.
11,755
The $94 is for the rear caliper hoses and the hose from the axle to the hard line on the frame, so that's three hoses.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,559
The description on the base set says it's two front lines and one drop line (frame to rear axle). I assumed the $94 caliper lines are from the axle hard line to each rear caliper.
11,755
Ooops ... you're right ... sorry about that! The front includes the frame to axle hose, so five hoses in all. It'll be a while before I receive them based on their published lead times. It'll be a good test to drive around with the new rotors and pads and a properly bled brake system, and then to upgrade the brake hoses and see/feel how much of a difference it makes.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,559
Oh, that'll definitely be a good test! I'll bet you notice it. If you can, and have a safe place to do it, do a panic stop on the old hoses right before you switch em. Than after, go the same speed in the same spot and panic stop again.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Who's going to work in Mexico anyway. They're all here.
