Better make contact with "007kubotaguy" and see if he has an engine to put in there.
I have been away from this project on a construction site but I am listeningthe crankshaft is not the place to skimp or cheap-out,
Yes I am imagining this statement, it is convincing me to have to go the whole way with this projectthe force of punching out the block would have been exerted on the crankshaft in a direction and manner for which the crankshaft is not engineered to withstand.
I should be back at this project maybe this weekend, but I am willing to go the extra route and do the job rightand you can get it together and running reliably with the crankshaft in-place
No not true, the head can be swapped without changing the block.
You are going to need at minimum a new (used) connecting rod and cap, and 2 connecting rod bolts.
and rod bearings.
HUGE gamble that the mains are not damaged or that the rod journal (that threw the rod) will be in good enough shape to even accept a bearing, let alone run it without failure.
I extracted these statements since they give the conclusion that at this point:you can replace the connecting rod and piston, and leave the crankshaft in place, then you do not have to split the tractor.
I know the recommendation is mig welder and nickel wireForget Acetylene, use a mig welder with nickel wire.
Yes, if that engine is finished and not worth me tinkering with it, then, how about this idea:I hate to tell you, that motor is done.
1: The chances of the block not having a water jacket crack and leak are very rare.
A hit like that send cracks up behind a dry liner.
2: And this is a Killer, you can not just beat out the liner and simply replace them.
You have to press the liners in and then you need to bore them to size.
You can plainly see damage to the rod journal in the pic.View attachment 129645
Yes, I removed damaged piston
Not only is the connecting rod bent, but the piston is broken where the connecting rod hit it
On the piston with the damage, it looks like it slammed into the liner and did block damage
Do you see how the other pistons do not have this indentation?
With this issue, is it not that big of a deal because:
I can hammer out the current liner and replace it with another and it should be fine
Let me know if this statement is correct
I can get from the spare L295:
Center piston assembly: piston head, rings, the connecting rod
Then get from messick brand new:
All new connecting rod bearings for ALL cylinders, all new connecting bolts for all cylinders
Theoretically, if I do these tasks, it should run fine, correct?
I understand that the recommended advice is to take out the crankshaft and also install new main bearings
As far as the location of the main bearings, yall are referring to:
Am I pointing at the location of the main bearings?
Messick does have main bearings 1 for $339, main bearings 2 for $209
If i also want to change the main bearings, where I have to remove block from tractor
Can I get main bearings from messick and they would work fine on this block/crankshaft?
Now, I am searching for acytelene oxy setup to repair the patch on the block
The problem: it sounds expensive and there is no electricity available, And
With the acetylene oxy setup, I can also cut steel for fabrication
At this point, it is the best bang for the buck
This is one I might go get on sunday, let me know if it will be suitable for these tasks:
1. weld the patch on the block with the hole in it
2. Cut 1/4 steel, and cut steel beams
3. Reintegrate the bucket that is broken in half
4. General all kind of welding: broken buckets, broken brackets, weld on a nut to be able to fasten onto that steel
I do see some say "cutting torch" as opposed to welding torch (I am guessing)
Can I cut steel and weld steel with the same torch?
Could I get this torch, and get nickel wire, and use that setup to patch the block?
I am gathering data, and not purchasing anything until I have a better plan
Feel free to critique and answer any of the issues/questions, no rush, thanks
I was only able to run it for 10 minutes previously before I decided to put effort into the engine that eventually blasted a hole in the block, BUTI would define the leaks you mention. Where are they, why is it leaking, etc. If engine has good compression and only 1500 hrs. I'd fix the leaks and us it.
That journal looks very bad to me. I don't recall seeing the bearings from that rod in the pics.View attachment 129709
Your statement: Where I have circled, one can see damage to the "rod journal", what I am circling is the rod journal
If I touch that part that I have circled, there is no noticeable indentations or alterations to the crankshaft
They disintegrated and were turned to shards, they are still in the oil pan, oil pan is filled with shards of metal, I am assuming that was the connecting rod bearingsI don't recall seeing the bearings from that rod in the pics
I did remove rod bolts on front cylinder, looked at that rod bearing, that rod bearing was not damagedWhy not remove another rod cap and look at the bearing and the journal so you have something to compare it to?
yes plan with this engine: take off entire block and examine it to assess whether to go forward or notThe debris in the oil pan is a good indication that engine has to come out and be properly rebuilt.
See RED comments above.I was only able to run it for 10 minutes previously before I decided to put effort into the engine that eventually blasted a hole in the block, BUT
I remember:
1. leaks all over the fuel system (those I can solve with new copper washers where the injectors sit) Need to fix these leaks first.
2. Oil leaks from valve cover (fixable), Oil leaks from oil pan (also fixable)
Generally: the engine has 3 times as much hours as the one that blew up, some of the bolts have loosened, I will go through and fasten everything tight. You are hung up on the engine hours, what if it didn't have an hour meter? What if the hour meter is broken and you actually have way more hours than indicated?
I will today go and try to get it started for yall, and I want to get very close analytical details for y'all to critique and tell me what to do to make sure this engine doesn't blow up
I plan on getting very high quality video and maybe use a stethoscope for y'all to assess what I need to do on this engine so it doesn't blow up
the main question in my head:
If you got a 40 year old diesel engine with 1500 hours on it, what would you do to it to make it as reliable as possible? No one can answer that without x-ray vision.
What are the exact parts yall want me to change to make it last awhile?
My guess: change all the bearings because those are the "moving" parts, and that is where all the wear lies
Change: all the bearings on the connecting rods, and change the MAIN crankshaft bearings
So far from what y'all see, is this statement true:
If I would have changed the connecting rod bearings on the engine before it blew a hole in the block, there is a great chance that it would NOT have blown a hole in the side of the block
Since:
Once I took apart the area, we see that the connecting rod and the connecting rod bearings of the center cylinder were the main culprits
We are sure that: The problem was not the MAIN crankshaft bearings, but the smaller connecting rod bearings
I am asking, not stating these sentences
Please critique my statements, I am grateful
Yes, I will be conducting these tests on the engines to solve issues and look for bigger problemsPressure test the cooling system.
Do a compression test.
Meaning: if I put in new connecting rod bearings but leave the main bearings and NOT go through the comprehensive process of a overhaul, I am wasting time/moneyPutting new parts in an old tired engine without at least polishing crank and honing cylinders; if everything mics up ok; is a waste of your time and money.
Meaning: just because the area looks fine, doesn't mean that it is. In my case, that blow to the crankshaft might look like it did NOT damage the crankshaft, the damage could be hidden and could cause catastrophic engine damage again if I dont do the complete overhaulBearings and rings will not wear into out of round or worn surfaces. They will self destruct.
I made a mistake, the hours are about 2500, and the machine does look neglected/tough lifeKubota Engines normally do way more than 1500 hour, I have 4 here that have anywhere from 2000 to 8000 hours and all of them run perfectly fine.
So with 1500 hours, I would put a gasket kit on it to fix the leaks and run it as is.
A compression test will give a better idea of the internal condition of the engine.I made a mistake, the hours are about 2500, and the machine does look neglected/tough life
We will see what happens tomorrow once I tighten everything up, fix all the leaks
Once I get it running, I post closeup videos and sounds, and I do the tests yall tell me to do to check compression, valves, knocks, etc.
