Rats ate my wires
Velma
B2301, FDR1660, RB1560, SGC0554, Pats QH, CMP Dethatcher
May 12, 2022
95
58
MI
Talk to your insurance company for the tractor and/or home. They may cover that bill…after the deductible of course.
One summer we had groundhogs get into both our cars. Auto insurance covered the damage. It was a small win…unfortunately, neither car ever ran the same again.
Dustball
2016 B2650HSDC
Sep 15, 2023
512
380
Hudson, WI
Thanks for all the replies! I found the wire connectors @ Findpigtails.com they have about every connector known to a man, I sent them pics of the connectors and they replied quickly! 80.00 each not cheap but better than the whole harness!!
Still waiting for pictures here.
Is this it?
jyoutz
Jan 14, 2019
3,589
2,692
Edgewood, New Mexico
Fo you leave it turned on when you’re driving, or do you pop the hood and turn it off when the engine is running?
3,545
1,975
I believe they sense motion and shut down when the vehicle is in motion.
John T
2017 BX23S
May 5, 2017
1,250
782
under a rock
It stays powered on all the time. I believe it's timed.. goes on and off. either strobes and/or ultrasonic noise.... might be motion sensing too... not sure.
so it IS a small parasitic draw.
They suggest starting the car/tractor every couple days to keep the battery charged....
and if need be, there is a rocker switch on the side to shut it off completely.
5,184
I would assume that keeping a maintenance charger connected would eliminate the need to start the car/ tractor periodically.
I keep maintenance chargers on everything I own, with a battery, except daily drivers.
John T
2017 BX23S
May 5, 2017
1,250
782
under a rock
same here...
I also use a 30 watt solar panel where I don't have electricity.
it runs down to a Battery tender solar controller (small box) and then the leads go to the battery.....
same as the regular electric chargers.... works great.
I keep a few motorcycles back there for the winter .... I will go back there every couple days and plug into another bike...... just to share the love...
but It goes into float mode when it gets to 12v
Ironically I have NO mice in the back shed.
when I built it I wend overkill caulking every wall/floor and door seam.
I put a couple mouse traps in there.... just to be sure...... Never any action.
Link.
5,184
same here...
Link.
I am away for up to 6 months at a time.
I simply have a .75A maintenance charger hooked to every 12V battery (14).
No need to monitor, or switch chargers.
I use Decon packets (or similar) in/around/on tractors/cars, etc., for mice.
Have a 48V maintenance charger hooked to my golf cart batteries also.
Friend has his Kubota M62 stored in a "sea can" (hi -cube container).
Has a 12V maintenance charger hooked to a small solar panel.
