5,184
Charging the battery. It's been 6 weeks since I used it and there wasn't enough juice to get it started😐
Depending on the battery (air) temperature, it may be time to consider battery replacement.
An alternative, would be a maintenance charger left on the battery when the machine is not in use.
I keep a maintenance charger on all batteries (I am away for months), and very rarely have starting problems when I return.
11,751
I went with the 84" with the back drag option, but probably could have gone with the 96" but wanted the blower and pusher to be close to the same width for the parking spot I back into.
Neil released a video today all about the HLA snow pusher that he's now running on his personal tractor. I can see the appeal, but I need to be able to push snow off to the side when plowing rather than straight ahead.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,681
4,375
PEI Canada
It stays above freezing in the garage. It will be 2 years old in April but I think it was just a matter off the tractor sitting for over 6 weeks. Normally, I'd be out 2-3 times a week moving snow and this winter snow has been scarce. I have the battery charged up now so I'll keep a closer eye on it.
S-G-R
Jun 17, 2020
1,681
4,375
PEI Canada
HLA doesn't scrimp with the metal. I had a SP1500 60" with metal shoes and backdrag. It weighed around 350lbs without the backdrag. I would push snow to the side and then run the blower through it. What little snow I moved today I enjoyed it a lot more with the rear blade and front blower.
Moose7060
Oct 14, 2023
827
2,243
bc
6,872
sewer line repair done. it turned out to be a foundation wall/pipe penetration leak.
start:
hole/seal:
backfill (added 1.5 T stone since it had settled big time there).
done. a little messy due to snow and the grade was terrible.
home at noon.
6,200
As noted on another thread, I finally got the skidding winch I’ve been driving everyone around me nuts talking about for dang near a year.
Farmi W50R from Northeast Implement. Picked it up from the nearest XPO terminal late yesterday. Put it together today. By the time it was ready to take out on a shake down run a predicted 3 day rain had started. Thankfully it wasn’t raining early in the process. Started with it laying on the already half busted pallet. IMG_1761.jpeg
Unpacked everything and was left with the main portion of the winch still laying on the pallet. Wasn’t quite sure how I was going to go about standing it up.
Plan A: Just stand it up and lean it against a wall or something. How heavy can it be? Worst case I’ll call a couple of friends to help man handle it when they get off work later. Pick up the top end to see how heavy it is… at least I think I got it off the ground a little. Check bill of lading. Shipping weight 775lb. This is not a job for muscle and bones.
Plan B: Take it outside and stand it up with the forks. It’s sitting on the blade that’s well behind the center of gravity so even standing straight upright it’s leaning hard toward the tractor. But I need to take the tractor out of the equation briefly to turn it around and hitch it up the 3 point. This is still a job for equipment, cribbing, etc. and no way me or anyone is getting between the winch and that wall. My skills, or more accurately lack thereof, with the forks totally destroyed what little wasn’t already busted on the hapless pallet.
Enter the little winch. A shackle in one of the lower pulley mount holes and the 3500lb winch on the Mule held it nicely to allow setting down the parking stand and hooking to the 3 point. IMG_1764.jpeg
Hooked to the 3 point, it was back inside to fit the PTO shaft and finish assembly.
IMG_1767.jpeg Now I need a little dry weather to put this thing to work and see what it will do.
Reactions: 13 users
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
386
539
SE, NM
Ran across some old pics. Digging a hole for the pool.
115997574_3379130472121051_1947777193785895384_n.jpg 110671823_3379130615454370_1503132025955554602_n.jpg
5,160
Pushed ice and slush for about 2 hours in preparation for tomorrow's rain, which will hopefully eliminate what is left of the snow.
S-G-R
Jun 17, 2020
1,681
4,375
PEI Canada
Bladed and blew a bit of snow. Still haven't gotten enough to give the blower a good workout.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
After 8 inches of rain this week(1/3 of our yearly avg) it was past due to get hay out to the cows. I haven't seen the ground saturated like this in a few years.
Nice ruts grabbing bales.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Oh, Happy Friyay Y'al! Another stressful load for the SVL this morning, all 115lb cull spike.
Reactions: 9 users
Old_Paint
Dec 5, 2020
1,990
2,215
AL
Rainy day in East Tennessee today so I also took a nap and didn't do anything at all.
I've been thinking about opening a new business. I figure I'd be a pretty good trainer for naps.
Moose7060
Oct 14, 2023
827
2,243
bc
I call BS. You'd go broke sleeping on the job!
