11,757
I'm waiting for the baler to finish another field, so in the interim I wrestle with my Beagle.
Is that a euphemism? Or maybe you have a Beagle! :ROFLMAO:
"in the interim" implies that you're involved in the haying operation. Are you transporting bales with your tractor?
7,004
Water service job today with a gas line in close proximity.
Start:
Dig:
backfill: The U-27 is still impressing me. Yanked and lifted that entire section of sidewalk with ease. I bounced it off the road to break it. I just couldn't heave the whole slab into the back of the dump in one shot.
Outta there
On to an emergency sewer line in the am. Seems like the guys got some equipment stuck in the line while doing a trenchless spot repair. It will no longer be "trenchless" after I get there. 😁
Reactions: 11 users
5,187
Start:
Dig:
Outta there
That is such a great looking machine.
I like the whisk broom too!
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
Start:
Dig:
Outta there
I sure was impressed with my U-25.
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
Unloaded some drill stem pipe, 31' long, with the forks, easypeasy. Paid $85.00 each, compare that to buying new pipe! IMG_20230609_092924731_HDR.jpg
Toyman
B7100HST, 1630, 4' Tiller, 4' Brush Hog; Mahindra 5005/Loader, Woods Cadet 84,
Apr 15, 2019
120
104
Pittsburgh
Spent the last 2 days working out the M4050 putting in my final spring plantings - pumpkin patch and deer food plots . The first 2 areas are the least rocky on my property so I broke up the soil with a subsoiler, then pulled the cultivator and finally tilled. Spread fertilizer and planted (sunflowers, rye & buckwheat) the 'flat' field, fertilized, hilled and then sprayed pre-emergent on the pumpkin patch. Planting today or tomorrow.
First pic is the pumpkin patch with the hills and reclaimed field below. 2nd is a field I reclaimed that was full of walnut saplings. Took out the trees and heavy vegetation in late winter, burned with glyphosate a month ago and got the soil turned, tilled and planted (rye and buckwheat). The last 2 pics are the M4050 with the cultivator I found & refurbed and added 2 bedding discs which worked pretty well.
My early sunflower planting and food plots that I planted buckwheat in late April haven't done so well with 0" of rain in the past 3 or so weeks, but hopefully they will recover with the rain called for this week.
Reactions: 10 users
Foxrunfarms
Kubota LX2610, 1951 Farmall M, 1967 John Deere 110 Rf, 2010 Arctic Cat 700
Apr 25, 2023
366
530
WI
Worked up part of the hayfield that needs reseeding(if we get any rain) My back was hunting and wanted to see how the Kubota handled the digger so didn't use my b.
Reactions: 8 users
radas
Mar 21, 2022
719
834
I tried, but she was not interested at all. 🤷‍♂️
I mowed with that as a kid and it has pulled trailers here for many years. I do plan to get it running but haven’t put any time into figuring out what’s wrong with it. It sounds like it has good compression so it will most likely run again at some point.
If I had the space and the time, that would have been a great project! Sadly I'd need something turnkey that needs minor stuff because I barely have time to maintain what I currently own lol.
7,004
Quick sewer line issue. After several attempts to get this line patched with the trenchless tools (trenchless spot repair) the bladder got stuck in the line. So, I got the call to get it out of there.
diggy
found it:
pipe
backfill
done in under 3 hours...and I didn't do any digging. Ground was bone dry and hard as a rock. Had the youngsters do it all but backfill! ;)
Reactions: 8 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,721
4,525
PEI Canada
Unloaded 50 cedar posts with the grapple and used the forks to move the aerator and landplane.
3,536
Unloaded some drill stem pipe, 31' long, with the forks, easypeasy. Paid $85.00 each, compare that to buying new pipe! View attachment 104629
Where did you find drill stem for $85 a stick?
My fence contractor has been negotiating from $150/stick down to $105/stick for about a year.
I need 1712 linear feet just for top rail. :eek:
trial and error
Feb 16, 2023
394
386
NY
Moved more wood today with the H.F. trailer and the little b. got the wood from some racks in the side yard into the "drying/seasoning pile" in the front yard. That sees the most sun and cross wind.Probably 6-8 heaping loads in the trailer and only found one snake 🐍 🙄. I am not a fan (of snakes), mostly the suprise factor, even if they are good rodent control, except we found another family of mice in the wood pile this morning alive and well. if I'm gonna have snakes I better not have mice and if I'm gonna have mice I wouldn't mind having no snakes, but alas I have both
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Well broke the Bota today 😔, gonna have to trade it in 🤣
ripped the top of the toolbox off mowing brush 😂
