GrumpyFarmer
5,028
Me and the big girl / pallet forks along with FIL cut up and palletized 3 racks of wood…2 moved up under the awning, and the other left to dry in the sun just out of the frame.
Just after I stopped for a beverage, I snapped the pic of Mr. Pileated when he came by for a visit and I managed an action shot with my phone.
Reactions: 7 users
GrumpyFarmer
5,028
Cleared some brush and dead wood. Had a little fire. No hot dogs or marshmallows to be found. I did have a Dingo dog as a helper, though.
What time will should we be there for s’mores? That’s an interesting use of the word ‘little’ 😂…but then again what is a little fire? standing within 3-4 feet without melting watch band? It’s all relative I guess….compared to the smoke coming across Lake Erie from CND lately, that was little compared to what’s burning North of the border. 🥃
Bmyers
May 27, 2019
3,581
4,746
Southern Illinois
That GL can sure looks nice and clean and dry. It’s not my machine or anything, but maybe take a look under it…from the pic it looks like you have some wiring/hose hanging down looking for something to snag in the woods.
Already fixed it. One of the hose clamps had come loose, pulled back into place, and added a couple of zip ties as extra insurance on it to prevent if from hanging down if it comes lose again.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,210
3,556
Yeah, the Canada fires are something else. The smoke haze can be seen as far as the Atlantic coast when the sun rises.
Jsjac
B2650
Feb 13, 2022
239
386
Been doing a little digging at the house with the tractor and a mini excavator.
Levelled between the tractor shed and the wood shed.
Levelled at the end of the garden. Lots of rocks to move. Some dirt. IMG_20230528_192629670.jpg IMG_20230528_192629670.jpg IMG_20230528_192540500.jpg IMG_20230528_192329178_HDR.jpg IMG_20230528_192314933_HDR.jpg
Foxrunfarms
Kubota LX2610, 1951 Farmall M, 1967 John Deere 110 Rf, 2010 Arctic Cat 700
Apr 25, 2023
366
529
WI
Drowling over your shed......
I like that wagon too. Is it home built or one of those dumping mini country manufacturing ones?
GrumpyFarmer
5,028
Thanks and Good eye…it’s a Country Mfgn 2 ton wagon. It does have the capability to dump but I have not put a hydraulic cylinder on yet. I picked it up directly from from their shop...They are really good people. If I need some else they make right there I’ll buy from them again.
Foxrunfarms
Apr 25, 2023
366
529
WI
Cool. At 1st I wanted mini running gear for my garden tractors. I picked a a farm tuff mini running gear from fleet farm.
The name is complete opposite of what it is. Supposed to be a 1500lbs rating. At 170 I was bending the center.
I ended up using some gorilla carts for my project ideas.
I have a jd 1065 10 ton running gear for larger tasks.
Then had a 963 I bought for 100.00 and traded for my planter.
I'm looking atba mini wagon for behind the Kubota for tasks and or one for dedicated hayrides.
Those country wagons and spreaders really caught my eye.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,679
4,369
PEI Canada
Started to loosely assemble my garden hiller/row builder. I got the hitch from heavy hitch but had a local shop make the crossbar tube and got 6' of tubing from them as well. Freight from Heavy Hitch and duty was going to be more than what I spent on these parts. If I get home early enough tomorrow I'll give it a test run.
Old_Paint
Dec 5, 2020
1,990
2,215
AL
More work on the new parking area.
Used the subsoiler again to cut along the edge of the driveway so I can drop in a 4” perf pipe for drainage.
Swapped back to the grapple and BB to handle the cross ties and got the top wall complete. Probably a lighter day tomorrow cause the missus will be at the doctor. Probably sharpen my saw after just a few cuts on the ties.
Gotta rent a concrete saw and remove a section of driveway to run the drain pipe under. Just happens to be an expansion joint so hoping one cut will do. Gonna backfill with #47 and pour it back with a few sacks of quickrete. No wonder it’s cracked to hell and back. I don’t think it’s more than 3” thick anywhere. The 47 will let a little water go around the pipe for a while.
I set 10 ties with the grapple and only 1 had to be handled back on top. The one I have in the grapple in this photo is the only one I missed with.
Got one little runoff problem to solve. Thinking some of the fill removed will be used to push the runoff around the end farthest from the house. The orange bucket in the background is my water level. Built my deck with it, the slab for my shop, and countless little projects that required elevation info and control.
Reactions: 8 users
11,739
Anyone notice a problem? 😩 This was my day today!
  • Remove two 160lb wheel weights from the rear wheel of the M6060
  • Remove the wheel & tire that are filled with Rim Guard
  • Remove the center of the wheel
  • Flip the wheel around and install the center to the second widest setting (was second narrowest)
  • Reinstall the wheel
  • Reinstall the two wheel weights that were removed in the first step
  • Install a third wheel weight
  • Repeat the process on the other side
I just love spending a few hours doing something only to realize that I need to do it all again.
Reactions: 7 users
S-G-R
Jun 17, 2020
1,679
4,369
PEI Canada
That would make a guy swear out loud😉
  • Sad
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
you are going to angle those discs the other way before you start using it, right? Or did @mcmxi put em on? 😜🤣😜. Just messing with y’all
Reactions: 6 users
utkdoc
15
17
usa
Spent a big chunk of the three day weekend building a playhouse for the kids. I still have to find a slide I like and finish up the roof/climbing wall. I'm not much of a framer but this has turned out much better than I expected. Turns out getting your 4 posts square goes a long way to making life easier :)
I had a 9" auger and after trying to dig out the remaining few inches to get to ~ 12" diameter in one of the holes, I decided it would be best to save my back. My wife went out to TSC to buy the 12" for me. The 12" weighs about as much as the 9". It seems things are made as cheaply as possible more and more.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
I needed to replant sunflower seeds for September/October. The first planting didn't germinate or all the seeds washed. The other food plot, the sunflower plants are doing good.
The Laundry Fairy likes and helped out with her new ride, she wanted an UTV for our 25th anniversary of my life sentence. No complaints here.
Reactions: 7 users
11,739
Yep! It was a tough day for sure and I hope I never to have to do this again! I knew I had to move the tires to the other side of the tractor after changing the setting of the centers, but completely forgot about it in the stress and heat of the moment. I had removed the wheel weights and wheel on the left side when I realized the mistake. That's such a great feeling when you know you have to do it all again. :mad: I will add that we did a much better job of aligning the weights than the local Kubota dealership, and given the cost savings (around $500) it was worth doing myself.
I don't know what the wheel/tire weighs but there's 72 gallons of beet juice in each tire which is around 720lb, then there's the weight of the steel rim and the tire itself. 1000lb would probably be a reasonable estimate.
Even with the MX and pallet forks it was still a tough job due to the weight of the wheel/tire and the friction of the rubber on the pallet forks. It all worked out in the end though but I was beat last night. The wheel weights were the easy part, but I can assure you it wouldn't be much fun trying to position and bolt on 160lb wheel weights without something to help. Pallet forks work well for that.
Here's how the morning started with the wheels at the second narrowest setting and two wheel weights.
Removing the weights
Removing wheels
Moving wheels around
All done with all bolt/nuts torqued to spec, and the tires on the correct side of the tractor :ROFLMAO:
Reactions: 10 users
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
373
Seattle, WA, USA
What a great weekend! On Saturday I went down to my neighbor's house and helped him process a pile of tree branches with my chipper ... four hands made the work go a lot faster. He helped me last week haul a large stump off my immediate neighbor's property ... for my stumpery garden, so I was happy to go down and return the favor. I used the BX's backhoe to loosen the brush pile and spread it out, and when we were done I used the FEL to scrape up some of the smaller debris and dump it.
On the way back home I stopped by another neighbor's house and graded out a small area that she had been trying to do by hand. I park my tractor at her house so I'm always happy to help out and keep her happy. Then I spent the rest of the weekend pulling stumps and moving rocks and firewood on my own property. Back in the city again for the week ... can't wait to get back up there.
This is the large stump we dragged off my neighbor's property (with permission). It took a truck and 2 hours...
A smaller BX-sized stump ...
My emerging firewood collection ... for a year or two down the line
Reactions: 6 users
