GreX
BX2380
Jan 8, 2023
185
132
Maine
I mowed for the first time today with the BX2380 - I'm not sure it was any faster, nor did it seem to do a better job than my Ryobi riding mower (https://www.ryobitools.com/products/details/46396017758). It was also a lot more prep, remove the FEL, put the ROPS up, change from 2 to 4 wheel drive, etc... am I doing it wrong?
I feel the advantage of the larger machine will show itself when the grass is very long or very wet since I have a PTO driven grass catcher, versus a blade fed one on the little Ryobi, but I feel there must be an advantage in using a 60" mower on an acre, but as of now, I don't see it.
7,484
If a 60" mower will not mow the same grass a 38" mower is mowing at a faster rate you need to get it out of idle. ;)
hoot owl
L2501 with loader and backhoe
Nov 13, 2022
94
273
53
65653
also, when the tech cut the old galvanized water service, the homeowners/ power went out...WTF? Power was overhead so what just happened. Then it dawned on me that we basically cut the house ground and he must have an open neutral somewhere. His power was "restored" when we bonded the ground to the new copper water service line...yikes man.
Aren't you required to report that to the power Co.?
I became the neutral once when replacing a water meter in a basement. It knocked me out a blew me across the basement. My helper thought I was dead. He did not come back to work the next day. My hands were numb for several days after that.
hoot owl
Nov 13, 2022
94
273
53
65653
I got some seat time today after 2+ weeks. I split an old ash tree and used the bucket to carry it to the wood shed. 4 trips. After that I put the new to me rock rake on and proceeded to rake the yard of tree limbs and leaves. Saved me days worth of work in less than an hour. Then I went down to the food plot I have been clearing and used the rake to clean up limbs and knock off a few high to low spots from digging stumps with the BH77. Then I started pushing some dirt for the small pond I will be making. I will switch to the BH tomorrow so I can dig a few more stumps next week. I learned the rake is not a very good counter weight for a full bucket in the loader.
BAP
Dec 31, 2012
3,115
1,252
In New England, we give free one-way tickets to the oppressed and ignorant people to go to Texas for training on how to be polite. Please be on the lookout for one more coming your way. Possibly you can drill some holes manners into g_man?
My part of New England would love to send all of the Southern New Englanders somewhere else as they are the most rude and awful drivers in New England.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
Yesterday was a quick trip to the Kubota dealer to drop off my K Connect since they have my blower and they are marveling at the coupler wear in just 35hrs of use.......but that is a saga that seems to be too common for a $7-8K blower setup.
To take my mind off it I cleaned the air filter on the old Husqvarna 50 chainsaw and did some additional clean up with the tractor and trailer.........sure is nice to have an expensive mobile wheelbarrow.....
Biker1mike
Jan 11, 2022
1,174
1,275
Gallatin, NY USA
Sounds about right. My tractor with a 60 inch cutter is slower, but much safer than my rider on the hills.
BTW: wet grass, hills, and tractors is not a good combination.
Flintknapper
L2350DT
May 3, 2022
2,024
2,576
Deep East Texas
Looks good and decent welds as well. Good job. (y)
I find hooks on a bucket to be indispensable.
I use mine probably more than I do the bucket itself (for scooping or digging). By adding attachment points for chain(s) you add so much more utility to the bucket and tractor IMO.
Naturally....some cautions apply, but the judicious use of your newly equipped bucket won't harm it (or you) at all.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,640
4,201
PEI Canada
Got the weights transferred from the aerator to the heavy hitch. Picked up a cheap receiver rack to use as a carry-all.
Forgot the second pic
Reactions: 11 users
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
446
516
NE Ohio
Remove FEL - Okay.
ROPS up - Why is that any different from 'normal'?
2wd to 4wd - Why? Are you mowing a steep area where 2wd isn't enough? Your Ryobi is surely only 2wd.
What RPM are you running? Should be at least 3000.
johnjk
Apr 13, 2017
1,758
2,083
West Mansfield, OH
Moved a bit of rock with the B3200 and then jumped on the 1700 to get a mow in before the next round of rain
Reactions: 6 users
GreX
BX2380
Jan 8, 2023
185
132
Maine
Remove FEL - Okay.
ROPS up is just extra time - the Ryobi does not have that to consider.
4wd on the hills, as I had the tractor run on me the one time I used 2wd to move dirt - maybe overly cautious? I also don't want to tear up the yard, and turn in 4wd does just that.
I was running at 2,500 RPM in rabbit mode.
I think it also comes down to the type of yard I have, lots of mulch beds and has loads of angles - where the little rider is just more nimble, and can run at it's top speed (6-7 mph) and handles hills like a champ - all the weight is over the rear axle (big battery in there, directly over that axle), and it doesn't have an engine to come up to speed to use, just press the pedal and go.
GrumpyFarmer
4,966
We had a busy day with the little lady….she transferred bike bike rack and Adirondack rack to the big barn, got a mow in before the rain this evening, transferred some straw, did a small fencing job, and moved / Transferred our first bee box outside (into small fenced area in the hillside - bees should arrive this week!).
Reactions: 7 users
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
After hauling the electric snow bike 100 yards to what snow is left (a lot, up high) I made one last ride. All winter I was riding right out my shop's door. Then I started busting up a big compacted drift that is still (an epic winter here, way above average snowfall totals) blocking access to my outbuilding where I keep my implements. I don't need access to them (having the blade and snow IMG_20230428_094726370.jpg IMG_20230429_122749148.jpg thrower already mounted up) all winter so I don't bother keeping it clear all winter, I have enough snow removal to do as it is 70 today, it seemed weird to be on the tractor moving snow, in just a short sleeved shirt! shirt.
Reactions: 8 users
radas
Mar 21, 2022
719
834
Discovered my backhoe subframe to loader subframe bracket is welded on backwards on one side 😑
  • Sad
Reactions: 6 users
River19
Sep 10, 2020
351
665
NH/VT NEK
Nice.....admittedly I have also used the tractor to move the One-Up rack......but they are great bike racks.....
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
I like the beehive, is that Flow hive brand with the flow frames?
https://www.honeyflow.com/collections/flow-hives
I have a couple spots saved for hives on my place.
