lynnmor
B2601-1
May 3, 2021
1,692
1,488
Red Lion
Can't reach all the pivot areas behind the frame/lift arms. I think I'm gonna have to start pressure washing it more often, like every 50hrs to see if that helps cut down on the amount of grease build-up.
Since the pins and bushings have no seals, pressure washing will force dirt and water inside. Just grab a couple rolls of paper towels and wipe out the excess grease, it's cheaper than firing up a pressure washer and blasting grease all over the place.
5,185
Are you using a HOT pressure washer?
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Skidsteer, rear pivot pins not easily accessible. All the grease in the rear falls down into the frame/machine.
Every 10hours the zerks get greased and depending on what attachment is on. It can easily use a half tube of grease every 10 hours.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
No, but I think I'm gonna use the drain off the water heater next time, probably put one those in line screen gaskets that are on sprinklers so the pressure washer doesn't suck any debris from the water heater.
5,185
If you have a business (farm?) I would strongly suggest that you try to budget for a HOT pressure washer.
I have a 50 year old Hotsy (brand), electric motor washer, with only 1,000 psi.
The 1,000 psi hot pressure water will 100% out clean my 4,000 psi 13Hp Honda powered, (cat pump), cold water washer.
The domestic water heater hose method will be a bit better than straight cold water, but 200 degree water, with high pressure, and dedicated burner heated water is vastly superior.
johnjk
Apr 13, 2017
1,705
1,938
West Mansfield, OH
Rock time. 100 tons dropped today. Driver doing a good job tailgating it. Need to thin out some overlap and fill some thin spots but that gets me seat time after lunch. I should be adequate with the box blade by then so I can forget everything until I get rock again
Reactions: 9 users
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
The hot pressure water will 1,000% out clean my 4,000 psi 13Hp Honda powered, cat pump, cold water washer.
Farm. Thanks, noted.
Flintknapper
L2350DT
May 3, 2022
2,006
2,546
Deep East Texas
That driver is doing a heck of job. Looks great!
johnjk
Apr 13, 2017
1,705
1,938
West Mansfield, OH
He did good. Got 10 ton dropped by the road and 10 back by the house to finish up
9,749
You can't, pressure washers do not do well on hot water you will seize up the pump.
5,185
You are fortunate to have found a driver who knows how to spread material!:)
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Nice.
Here it's cheaper to get the belly dump ~22 to 23T each load, $400 to $500 dependant on dsl costs, just got to inform driver to set locks at the lowest setting, and drive faster.
RMS
Sep 26, 2021
284
626
Buckfield Maine
Since I do better reading from a physical document I took a pdf of my wsm to Staples and had it printed out. It wasn't cheap but still less than buying one through a dealer.
Old_Paint
Dec 5, 2020
1,944
2,130
AL
I'd just be happy to get the WSM. Where'd you find that?
GrizBota
Apr 26, 2023
1,147
732
Oregon
This morning I helped the neighbor get rid of a couple pine trees that were hanging over his garden area. Used the L3830 and grapple to take the brush up to my burn pile. Tried to use the bottom tines of the grapple to tear up a mound with a bush (which had been removed) to try to uproot the thousands of woody stocks. Ended up doing a fine job of removing the dirt from around the woody stocks (we lost that round).
