Mowbizz
Bx25d
Aug 19, 2021
548
311
Last 2 storms here in central NH have been slushfests…PAM in the chute didn’t work well…getting sick of winter here…😡
6,722
Yeah, hear you.
We got 12” of slush last year April 19. I can’t wait that long to change tractor over, sometimes I’ve mowed grass before May 1…
Mowbizz
Bx25d
Aug 19, 2021
548
311
Yeah, hear you.
Lol…it helps to whine about it on here…not much, but helps a bit. 😞
cthomas
LX2610 HSDC
Jan 1, 2017
845
560
La Farge Wi
What happened to "No mow May?" Mowing less creates habitat and can increase the abundance and diversity of wildlife including bees and other pollinators. One way to reduce mowing is by participating in No Mow April, No Mow May, or Low Mow Spring.
Lawns cover 40 million acres, or 2%, of land in the US, making them the single largest irrigated crop we grow. Lawns are mowed, raked, fertilized, weeded, chemically treated, and watered⁠—sucking up time, money, and other resources. Lawns provide little benefit to wildlife, and are often harmful. Grass-only lawns lack floral resources and nesting sites for bees and are often treated with pesticides that harm bees and other invertebrates.
When we think of habitat loss, we tend to imagine bulldozers and rutted dirt, but acres of manicured lawn are as much a loss of habitat as any development site.
Now I just got to convince everyone else about this as neighbors mow every 3 days. I am the every 10 days in the summer type. Of course the neighbors lawn is one acre and mine is a few more(5 acres that I mow).
6,722
@cthomas - I only mow what’s flat here, and there isn’t much of it. Snowblower in winter.
Shows the weather we’ve had lately; did oil change today with only 42 hours in 18 months. Had winters when I did 40 hours.
cthomas
LX2610 HSDC
Jan 1, 2017
845
560
La Farge Wi
I average about 150 hours on the tractor in the winter blowing/plowing snow and 300ish in the summer mowing/grading/digging in the summer. I am so happy to have a cab.
anomad
YM2310D
Jun 10, 2021
101
55
Western North Carolina
I put in my second hour of time on my new bush hog for the KX-057-4. There is a learning curve to this that I wasn't expecting. You can see how slow I am. But nothing like my first hour - LOL.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Finally dry enough to get some mowing done in the back this morning, going to try to get the second corn plot planted this afternoon.
bmblank
Mar 4, 2015
714
394
Cadillac, MI
This weekend is the last chance I have to go get my camper (travel trailer, 25') before I want to use it in 3 weeks. I didn't have anywhere to park it, so I had to get the tractor out and move 18" of dense, wet snow. It's really looking like a muddy mess right now, but I'm hoping over the next week it'll melt and mostly dry out enough to park there.
GreX
BX2380
Jan 8, 2023
185
132
Maine
Overhauled my 60" mower deck; pressure washed, painted (spray) any areas that were down to bare metal, new belt, new blades, gear oil change, lubed all zerks, and lubed the pto shaft - crazy that all of this needed to be done on a 4 year old tractor with less than 100 hours, but the previous owner didn't seem to take care of these things.
Question; the gear oil looked very clean until the last 1/3 or so came out, which was quite dirty looking, is that pretty typical, or is that a sign of a potential issue? I stuck a magnet in it to make sure it wasn't metal flakes, and the magnet returned with nothing other than gear oil, but wanted to see if this was normal?
aaluck
Oct 9, 2019
972
826
Snowdoun, AL
My daughter bought a lemon tree and lime bush. Had to fine a place to put them so we expanded a flower bed with full sun. Gave me an excuse to use the new tiller again.
Reactions: 9 users
johnjk
Apr 13, 2017
1,605
1,595
West Mansfield, OH
If you haven’t run it lately then the heavier dirt had a chance to settle out. Are you able to get a look inside the case? A couple ways to tackle it if it bothers you. Fill it and forget it till the next service, fill it and run it till hot. Now drain and refill. Should get most if not all that dirt in suspension. Lastly, get a couple cans of brake cleaner and go to to town and hose out what you can. Once happy or delirious from the fumes, let it dry and fill with oil. Personally on my mmm and brush hog gear boxes, I change the oil on them when warm from operation. If it is just dirty and not metal flake filled, I would not be that concerned.
5,037
Reactions: 6 users
Daylight
BX231, Ortolan T10
Feb 25, 2021
437
734
I got filters and S-UDT for the upcoming 50-hour service (so far, the BX only has 41 hours in almost 5 years... Can't wait to retire and finally start putting it to regular use!).
Before anyone asks: it has received two intermediate engine oil changes during that time.
GreX
BX2380
Jan 8, 2023
185
132
Maine
I've yet to even hook it up to the tractor, which I purchased in November and was in snow mode (rear snowblower attached), so it's likely sat since mid-October (or before) since being run. I wasn't sure if some dirty looking gear oil was 'normal' or if it could be a seal going bad? Given the shape they had the mower deck in, I'm guessing it is just residual from all the dirt and rocks they were mowing (given how the blades looked).
I did have the thought of changing it while warm (gear oil), sounds like I'll do that at the end of the season, unless the mower decides to stop working - hopefully that won't be the case, given the deck has maybe 50-60 hours on it.
Old_Paint
Dec 5, 2020
1,833
1,880
AL
Picked up the front end of my Husqvarna rider (again) with the LX2610SU. I completely rebuilt the cutting deck for the Husqvarna yesterday, and proceeded to break one of the new arbors today. I think I over tightened the pully nut which loads the bearings, which ultimately led to the failure. Today, I cut some 'rough' area behind the house, one notch down from fully raised. Lotsa leaves and junk from the winter dumpage. I just wanted to mulch the leaves a little and cut down the tall weeds for the first time this year, as well as make sure none of the poison ivy starts getting a foothold again. Found a rather large pine stump that I'd forgotten about, and thought I'd cut low enough to miss. The spindle shaft snapped off just below the nut, which generally means stress cracks in the threads. New arbors had grease fittings, as well as a ball bearing with a separate seal at the bottom, and I pumped both full of grease yesterday when I installed them, so I was pretty confident they'd last a long time. Not so, especially when mowing deck meets pine stump that's hidden in the deadfall. Had another spindle shaft from the old arbors, and was gonna just swap out the spindle shaft, but turns out the bearing is pressed on the bottom end a bit too tight for me to remove it without a press. One of the few must-have tools I don't have in my shop, of course. That didn't bode well for the new arbor. As I said, broke the spindle shaft below the nut, and stripped the teeth outta the pulley on the splines. Heard some new noises, so went back to the shop to check it out. So, despite the addition of zerks and greased lower bearings being a good thing, I managed to destroy a day-old arbor that had cut my yard exactly ONCE. Bugger. Put the best sounding and feeling of the old ones back in, then went back to cut. 5 minutes later, I found a root, and turned one end of a brand new blade down (also installed yesterday), which turned my mowing deck into a horizontal high speed roto tiller. Back to the shed for a blade replacement. Put the sharpest of the two I took off, and decided I should probably be a little more alert and observant. Actually, was wishing I'd let the rain overrule me and not even gone outside today. Some days, it's best to just stay inside.
