OK, stared at this and it occours to me that IF the the plate labelled 'D' ,somehow got off center, then the spool 'B' would not be able to go down. That might happen if bolts 'L' got a wee bit loose and both 'K' and 'D' moved. Plate 'D' looks like 'I', to me and the spool does go through 'I'
Before you soend a LOT of time removing the entire 'valve block/ assembly', carefully remove the bolts 'L' and slide off the 'K' and whatever else. I'm thinking the spool has to be in the down position as all that stuff gets assembled and the bolts get tightened. Wondering if anyone has tore them apart, if there's info in the WSM other than 'replace entire unit' ???
