BT600 backhoe swings right but not back left
ruger1980
L4310 w/La682, L225
Oct 25, 2020
595
260
CNY
The issue is access. Go back and look at the video around the 17 minute mark where he removes the front cover over the valve. Good luck getting in past those hoses to access the screws on the end cover. There are 12 hoses in two layers and spaced about 1" on center.
He is also not working on a BT600. They look to be quite different in the structure around the control valve/
I also say where there is a will there is a way. If need be remove the 2 swing hoses and that should provide enough access to the cap and bolts.
BX23-S,57 A-C D-14,
6,339
that video's for a BH92 and not a BH600,from the dwgs I see, 4 bolts release the valve assy, then remove the 'pedestal' or whatever they call it(post #117), then valve assy should be hanging in free air buy all the hoses....
unless I'm missing something.
BTW had a look...my BX23S has a 'one piece ' valve assy, so not a 'one size fits all' deal.....
7,470
We have already determined she has a sectional valve. At this point its just a matter of getting to it. I certainly can't tell her how to do that. She is in the best position to make that determination and the BH92 video is certainly a good example to consider - very easy job with no fuss and no muss.
7,470
Rather than take the entire valve body out I would remove the cap on the bottom of the section and inspect the spring and the capture bolt. I have seen the bolt back out on valves before and limit movement of the spool. if with the cap off the spool still does not able to be moved then remove the lines and fittings in the swing section and inspect for debris in the spool.
No sense making more work for yourself than need be,
I mostly agree. The valve appears to be secured to the "step" by two bolts in the bottom of the end section It looks like once you remove the top (170) and side cover (240) the valve assembly can be unbolted and allowed to "flop" forward out away from the step where it is supported by the hoses.
BX23-S,57 A-C D-14,
6,339
Agreed it is easy, especially with the drawings at Kubota's online parts page ! Probably less than an hour, providing all the nuts and bolts come off easily and the phone doesn't ring more than 4 or 5 times.
WAS BANNED FOR NSFW PICS
5,164
Everything is easy if you have the mechanical inclination to do that type of work. Not everyone can do everything, and that is why some mechanics are hacks and others are surgeons with wrenches. All the best tools in the world will not make a master mechanic out of those that don't have the ability to know how to use them.
7,470
I am going to huess you have never replaced the valve cover gasket or water pump in a twin turbo BMW 335i o_O
5,164
You are correct, I haven't. Not certain how much needs to be removed, but my guess is that you could spend 6 or 8 hours just getting to it. Much like my Ford where they put the water pump inside of the engine, so when it fails, it ruins the engine as a result of the coolant mixing with the engine oil. Another engine that I wouldn't want to get into. On the flip side of the discussion, I had been into the backhoe valve on my old BX22, and it wasn't a fun thing to take apart. On the good side of things, I have a well-stocked tool boxes, and I was able to complete the task of replacing the one leaking hose without losing my sanity. When I turned wrenches for a living, I worked on whatever came in for repair. I am long past there now, and I don't even work on my own cars except to change the oil and check fluid levels. I'm not a fan of modern engines with all the computer technology involved. I prefer simple mechanical things today.
I also know that not everyone has the same mechanical skills, and I fear that if she gets in over her head she will be in worse shape. I also believe that this repair might be beyond her pay grade. I have known many women that could turn a wrench better than most men, but they are a rarity because most women haven't been exposed to the mechanical side of an automobile. Today it is no longer acceptable to say that a woman can't do what a man can do, however, there are many things that a man can do that a woman can do better. I am just not certain in this instance that this is the case. I might wind up in the penalty box for typing this, but she needs to know the size of the can of worms this can turn out to be. This isn't like changing a tire.
7,470
Your misogyny is showing. This job has NOTHING to do with gender. Just from what I have heard from TG I am confident she is way more mechanically quakified for this job than my 44 year old son.
5,188
Yah think?
"it is no longer acceptable to say that a woman can't do what a man can do"
Just a couple of examples!
Can a woman firefighter carry a 200 pound person from a burning building, and down a ladder?
Can a woman be a nose tackle for a pro football team?
5,164
It has nothing to do with misogyny, but with the information that I have gathered in reading her posts in this thread. I have no prejudice against women as you imply. I agree that this job has nothing to do with gender, I just believe in giving everyone, both men, and women the facts of the job and what can go wrong. It is entirely up to TG if she wants to move forward once she understands the scope of the job. If she decides to move forward with the task then I hope that she will be successful.
#40Fan
689
510
Here is going to be my guess as to what the problem is. The seals circled in red have allowed fluid to pass by, filling the inside of the piece circled in blue, causing a hydro lock situation.
BX23-S,57 A-C D-14,
6,339
Hay I like that idea !! Means there should NOT be ANY oil dripping out when bolts 'L' and block 'K' are removed.
What's interesting to me is that the Caps 'E' and spring 'F' are in a different sequence or order than those on my BX23S...so... you need to have the CORRECT diagrams for what ever you're working on, as not all valves are built the same.
It'll be nice to KNOW what's really going on, hopefully before page 9 or 10 or the new year arrives.....
7,470
Interesting idea and only time will tell. But my guess is if that were the case there would be a visible oil leak around the gasketless cover.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
595
260
CNY
I would agree as pretty much every similar valve I have worked on had a way to vent the cap whether it were a sintered plug a relief cut in the cap.
BX23-S,57 A-C D-14,
6,339
OK, that makes sense, now wondering why those 3 parts ( 2 seals and plate) are different on the 'top' end ? I'd have thought ,they'd be the same pieces...
It'd be nice to have one of these to examine but at $1000 Canucks, kinda pricey just to 'see how it works'.
5,188
Is this thread really headed for "pallets in the field" type fame?
