jyoutz
Jan 14, 2019
3,590
2,692
Edgewood, New Mexico
Removed the rotary cutter for the season and installed my rear blade for the winter. This gave me some initiative to grade the gravel driveway and road that had gotten beat up over the long summer rainy season.
pigdoc
G1800S L2500
Aug 19, 2022
397
337
SE Pennsylvania
Saturday, I ran the G1800/mower around the yard just as the remnants of TS Nicole started coming through to blow off the leaves back into the woods. Now that all the leaves are off the trees, that should do it for the mowing season. Yesterday, I R&Red the deck, so that I could tip it up and thoroughly wash any residue from the bottom side. It all slid right off, with very little effort due to it soaking all night.
On the list for PM in the off-season is installing new PTO belts on the front of the engine. They've been slipping some on PTO engagement and are probably the factory originals. Also need to figure out how to increase the friction hold on the throttle lever. It gradually slips back down to idle. Annoying to have to hold it in place...
-Paul
Bmyers
May 27, 2019
3,580
4,745
Southern Illinois
Another day at the farm. Dad decided that he wanted to open up the old corn crib that we hadn't been in since either 1998 or 2001, there was a debate on when we were last in it. anyway, we opened it up and found some stuff.
Chainsaw, mower, well pump, air compressor, table saw, miter saw, old stove, bench grinder, to list a gew of the things we found. So, we worked on cleaning it out.
Then our neighbor came over. His wife told him he needed to get out of the house and find something to do. We put him to work digging up stumps.
We went over to the farm house and found a large tree branch had come down.
In the process of cleaning things up, found a drag harrow that no one knew was there. Of course my tire was the one that found it. Ended up at the shop. They patched it, but made no promise it would hold long term. Nice big cut in it. So, I guess a new tire will be in my future.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,539
central ct
I did pretty much the same. After I serviced and mounted the snow blower on the 3pt the fel was used to back blade and trim out part of my gravel driveway.
I had another triaxle load of 3/4 process delivered a few months ago. Although it has held up very well there were a couple of undulations I wanted to smooth out before I ended up turning the blower into an earth mover when it snows.
pokey1416
Jun 24, 2020
572
884
SW Michigan
1st measurable snow in SW MI. Drives and roads not bad, plowing is slow as I have to stay off lawns this time of year. Radio in cab sure is nice.
MountainMeadows
Jun 6, 2022
219
290
Poconos, PA
The long wait on my EA Wicked 55 finally came to an end on Wed. 4 months to the week since ordering it. All I had time to do was unload it from the delivery truck and put it up for the night. I was too busy at work to do anything with it on Thurs and it rained cats + dogs on Fri.
With the rains + high winds another dead pine came down so it was clean up time on Sat. It was a good chance to try it out and it worked so much faster and easier then the old way of using the forks.
Reactions: 6 users
kenmac
B26 with hyd. thumb and 4 in 1 loader bucket and EA Grapple, but not the wicked
Dec 14, 2015
92
9
Pell City, Al.
I got rid of some of the brush the previous owner left behind. And there's a LOT where that came from.
One of the reasons I got the grapple. Such a handy gadget when dealing with brush! 🙂
I couldn't imagine not having a grapple now that I've used one, especially with my sawmill. It stays on the tractor 95% of the time.
6,165
Fabricated a bucket level indicator. Cause the sticker from the factory just don't get it.
I may be outing myself as an unskilled bucket operator, but a similar bucket level indicator, which is the OEM option for mine, has greatly improved my results running the bucket. If I ran the bucket 8 hours a day 5 days a week probably wouldn’t need it but I run the grapple (can see the leading edge on it) and forks (have to stand to see them but I know the offset on the level indicator for the forks) more than the bucket, so being able to cut to the bottom of a pile of rock without digging a hole in the ground below the rock and contaminating them with dirt is actually a big deal to me. OEM for mine was only $50 when I bought it and it was definitely money well spent.
SGT13
Bx23s, CB05 bucket, GS05 scraper, Shop made ballast, hangers, & anchor pts
Sep 2, 2021
14
12
Arizona
Definitely worth it. I would have purchased one but, I just like to make stuff.
fruitcakesa
M4 071
Oct 26, 2010
877
304
Cavendish Vermont
Cleaned up most of the junk wood [trimmings, cut offs, shorts, etc.] that was leftover from logging operations and left on the landing.
Hauled a few dozen grapple loads to other cutover areas, distributed some and made a large "habitat" pile with the rest.
Still have more to move to get the landing looking presentable before the snow flies
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
My sawmilling customer is building a cabin and decided on Cedar stairs and the risers/treads will be half logs.
I sawed about half of the order Saturday and.....
Finished sawing today. The hand rails will be 2X4's & 2X6's with 2X2 spindles. The landings will be various widths of 1".
And when the sawing is finished the cleanup begins.
It really was not as bad as it looks here.
But I was still happy to git-r-done. That ole M4900 loves to work. (y)
Reactions: 10 users
Mowbizz
Bx25d
Aug 19, 2021
599
349
Mounted my quick hitch after dropping my FEL for the winter. Will mount the snowblower this afternoon. Getting ready for “dusting to 3” event tomorrow
4,063
A wood chipper would certainly make that cedar salable / valuable to anyone wanting an air freshener or closet anti-moth sock.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
456
530
NE Ohio
Took the mm mower of the BX2380 for the winter. Put the FEL and Ballast Box on. Need to remove the metal edge and install the UHMW one for snow plowing.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Used my 27 year old L2350DT to push some cut sections of a Hackberry tree off into in ditch.
Its a compact tractor and only 25 hp. but I am always impressed at how well it will 'push' things
It won't lift much, will 'pull' OK but reaches a point where the tires just spin if I try to overwork it.
But it will 'push' like a glacier. I am continually surprised at what this small tractor will move.
In low range and 4wd it easily handles things I just wouldn't expect it to do.
In the pic below....not that big a deal. A section of trunk about 10' long and 32" in diameter.
Hackberry isn't as heavy as say Oak, but 'skidding' it along the ground creates pretty good resistance.
Little Orange Tractor handled it easily.
Reactions: 10 users
forky
Feb 23, 2021
340
381
Wisconsin
Looks like you took really good care of that tractor. How many hours are on it?
Old_Paint
Dec 5, 2020
1,989
2,214
AL
Got my 50.1 hour service done yesterday. I opted for a full hydro fluid change vs. just the filters. It took about an hour start to finish so not too bad. Most of the time was me cursing at the engine oil filter location jammed against hoses and wire looms.
Here’s a tip. Take the stainless belt guard off. That will allow you to move the lower coolant hose a little bit. I also use a nylon strap wrench ‘on a stick’ that fits on a half inch drive extension. That gives a lotta torque and grip on the filter.
RCKM
2022 L3302, LP B1260 Box Blade, LP 0660 Grapple, Rear Blade, Pallet Forks
Jul 7, 2022
24
58
Eastern WI
Installed the armrests on my L3302. Literally a 5 minute job. Got them from Coleman Equipment for $71. Part #L2280
