edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,130
841
Wellsville, PA
Was gonna cut up some more wood for the fire pit but the bugs were horrible this morning :)
7,083
Yeah, the skeeters were thick where the Moline is. Had designs for more time, but they drove me off…..
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
266
225
Wahkiacus, Washington
Just looking at the 'lil toy tractor and being thankful. I'll say this and it is that I've made two good purchases. #1 was a '75 Toyota Landcruiser and #2 was the 'ol '84 B7100. And the Land Cruiser has a broken Birfield on the front 'cause I was stupid and used it as a tractor.. But the B7100 wins. It grunts and groans, like me but it just keeps going.
I broke the Land Cruiser in a mistake. But even in a stupid moment the B7100 does not break. Just some wear points and the darn deteriorated wiring.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Pulled tarp off the B and grabbed my weed wacker. To lazy to walk the hill so I drove to the area that need trimming. I almost feel guilty, but, heck it is hot out there.
radas
Mar 21, 2022
719
834
Ordered a gray set of CAT1 Pats quick hitch for my BB and other future implements.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,537
3,754
PEI Canada
Going to water trees. Beats carrying buckets.
Reactions: 9 users
JRHill
Apr 26, 2016
266
225
Need to work on rewiring wiring under the console. But it's been 100f and will be for another week. There are other things I can do for the time being. 😓
radas
Mar 21, 2022
719
834
Finally showed up, when I remove my buddy's stump grinder from my machine I will install. I don't want to install now and have to deal with PTO shaft extensions for a machine I don't own 😂
S-G-R
Jun 17, 2020
1,537
3,754
PEI Canada
Hooked the tiller on for ballast and moved some dirt to fill in some low spots on the lawn.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
322
312
catlettsburg, ky
Did a little bush hogging today.
Mostly heavy grass and tall weeds.
Heavy grass had not been cut in a couple of years.
The weeds were on a vacant corner lot and some were 6’ tall.
Had to go slow because of the thickness and wasn’t familiar with the property.
Lx2610 does a good job of running the rotary cutter.
The Woods BB48x just follows along and cuts everything.
10 years old.
leveraddict
Apr 1, 2019
905
593
NEPA
Installed new tilt steering shock on the BX.
While at the dealer I stood next to an MX5???....Man thats one big tractor!!!!!
9,834
A friend is going to be borrowing the flail mower this weekend and he came by last night to check it out before we headed out to dinner. It was leaving a strip of uncut grass a bit left of center of the cutting head so I figured that a hammer was knackered. When I raised and rotated the head I saw that two hammers were stuck together due to a thick wad of grass and so weren't able to cut. Not sure if this is a common problem or not.
After clearing the grass and making sure that the two hammers were free to rotate I made a couple of short passes to see how it was doing, and all is good ... until the next time. You can see the strip of uncut grass in the photo below more to the right, and the much improved passes more to the left.
7,090
Makes me wonder if you didn't have the PTO at 540.
