RalphVa
738
322
Charlottesville
Ran the WC46 chipper again yesterday. Plugged both the discharge chute and hydraulic feed roller. Wife cut off all the small stuff with green leaves that was plugging the chute. Will bush hog those. Did it the day before, too. Only had ever plugged the chute one time before this.
For the roller, I used a low rise "racing" floor jack to go underneath the bar over the top of the roller mechanism. Raised the roller and pulled out the stuck piece. Jack came out easily when lowered. Still enough room to get it out.
Run the WC46 at 2300-2400 rpm for about 450 rpm on the rear PTO where I ran it on the last 2 JDs. Don't need the hp. They just loaf along.
Newaterman
LX2610 HSDC, Z422-54KW
Feb 14, 2021
99
275
53
Vermont
Had an arborist top and drop a dead tree behind the house and then did several myself. I’m still a rank amateur when it comes to felling but live trees don’t bother me too too much. One ash was the biggest thing I’ve cut to date. I probably won’t cut anything that large again anytime soon. I limbed everything up and then waiting for some weather to roll through, 50 degree temps and rain, which then froze this morning. It did however melt enough snow off that I could get the tractor behind the house to clean a lot of the branches and logs up. Brush went in a pile off the driveway that will get relocated in the spring, and logs went in a pile behind the wood shed for bucking and splitting in the spring. Now hopefully I won’t have to mount the star link dish that arrived Wednesday on the peak of the roof.
96FC5067-BCE6-4365-93F6-838DDFA2F236.jpeg DAEC9869-F657-4529-B153-59E742C27677.jpeg 672E5EB5-3890-47F5-9C74-0E9829602D10.jpeg 229D0A88-2D61-4175-86E6-49D90FAB7F52.jpeg 2A747AC6-12A8-4DDE-B813-30725EF1248C.jpeg 71BCA67D-6E41-487C-8ABB-E4C6A1DD16D8.jpeg
Reactions: 7 users
6,873
Well, the mini-mini DID have a Kubota engine...and the little bugger could dig. It seemed to be faster to backfill with a shovel though.
Found it:
new trap:
done...I had the easy part. The guys did an outstanding job at this rental property. 5 units and it was a disaster.
RalphVa
738
322
Charlottesville
Did an hour's worth of chipping of a pile, mostly red cedar, beside the compost pile.
No stoppages this time. All that small red cedar greenery got fed in by the hydraulic roller.
pokey1416
Jun 24, 2020
572
884
SW Michigan
Set out early to plow - what a mess. Top layer of frost is gone + rain = STAY OFF GRASS! This is the weather that really makes me wish I had a blower.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
Well today worked on removing water from barn from last nights rainstorm that filled my barn with 8" of water when the culvert frozen and plugged backed up durring the night. Got barn cleaned and bedded with happy beefers inside. Got tire chains fixed on the kubota. Had one that broke a link, and other loosened up to much and was getting cockeyed. Also feed 2 more round bales, fixed and filled my pipeline trailer for working in sugar bush tomorrow. Used kubota to move it around too. And filled full of fuel greased it. And gotta g get a new battery for it in the morning.
tbeckett
Kubota M5660SUHD, Monroe Tufline Disc, Woods Bush Hog, 60" Grapple
Jun 3, 2021
Columbus, MS
Did the 50hour service on the BX. I went ahead with the revised service interval in the newest manual and changed the HST fluid and cleaned the screen. Pleasantly surprised w/ how clean the screen actually was -- just 2 flecks of grey sealant was about all there was. I'd seen some pictures of the screen being nearly completely covered in errant sealant bits.
In other news, I'm actually shocked that I put 50 hours on in ~9 months. My biggest worry was it'd become a garage queen with hardly any real usage. From spreading ag lime, to post hole digging, to clearing snow, I'm only kicking myself for not jumping in sooner.
View attachment 73679 View attachment 73680
I had no idea you could use one of these spreaders for ag lime. Everyone here says you cant because ag lime will clump up in that type spreader. Whats the secret?
5,160
There is no problem using that type of spreader for lime powder or pelletized lime, however, you have to do it on a day that there is no wind or even a hint of a breeze. I spread lime using a drop spreader, and it is less likely to blow around. I had a hopper type of spreader, but the fertilizer and lime got under the powder coating, and it rusted in just a few years to the point that it fell apart. Now, I use the drop spreader that has paint on it, not powder coating, and then hose it out after each use. Unfortunately, today almost everything is powder coated because it is perceived as being a better coating to paint. I don't agree!
dclauria
Kubota L4060HSTC, L4479 snowblower, EA 60" grapple, LP GS2584, LP BB2572
Jan 1, 2022
40
46
Northern Michigan
I installed a hydraulic top link for my Landpride box blade/scraper 20220218_184354.jpg
I would have liked to order one from the recommended hydraulics guy, but with the lead time - I ordered this one on Sunday, and received it on Thursday - complete kit with all the fittings and adapters. I just had to pick out the right length.
D
Deleted member 47704
Guest
Snowed today ,not enough to plow, so tractor sat. But I did start buying parts for a rear remote.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,685
4,391
PEI Canada
Greased the loader and blower. Topped off the hydraulic fluid and put everything away then noticed my chute deflector hoses were leaking. Looks like a project for tomorrow.
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple-Grand L4060
Feb 10, 2019
124
147
WV
I installed a hydraulic top link for my Landpride box blade/scraper View attachment 75341
Do you have a link to where you got it? I am thinking about doing this.
Ron
SAR Tracker
Nov 17, 2020
254
390
Central Oregon
Was doing the DSOT (Daily System Operability Test from my old military days) checking oil levels, pressures, etc, and noticed the fuel filter on my LX2610 was loose. Not leaking loose, but loose from the mounting bracket. Oh, wait.... the mounting bracket is BROKEN! No obvious impact damage that would cause the breakage. Wonderful - the IPB doesn't list the part number for the bracket, I have to buy an entire filter assembly! This will be the chore for tomorrow. Plus we're supposed to get some snow. At least the tractor is inside! 20220221_142310.jpg
Update: I think the 2 cab heater hoses that were routed behind the filter may have been enough to break the bracket when the nut holding the bracket to the mounting stud was tightened. Re-routed the hoses to run ABOVE the filter bracket, and the bracket mounted perfectly.
SteveBX23
LX2610SU; BH77
May 23, 2021
180
305
South Jersey
B8F276AF-1C23-4391-AA50-1E09F902F5E6.jpeg 38BC7A9C-2E80-43B9-87D1-E593D275E845.jpeg F13DA183-52E2-4950-9BCD-601D2B64DCFD.jpeg
Did some grading work yesterday. Didn’t take before pictures, but there was a berm about 5 feet off the house on each side after this addition was put in. So the job consisted of grading that back in off the house, and moving/grading a couple yards of topsoil that sat on the side
Reactions: 7 users
GrumpyFarmer
5,056
Used the little one to restock the front porch with more firewood. 23F yesterday, rumors of 47F this afternoon. Today I believe I am taking the little girl for a drive through the woods and going to set some taps/spiles and hang some buckets….and then maybe we are going to open up that drop shipment I got a week ago(greenhouse).
RalphVa
738
322
Charlottesville
Mounted the bush hog, using the U adaptor on top of the QH. Note to self: replace U adaptor with top hook BEFORE putting bush hog on. 'Twas a royal pain trying to get the 2nd pin in on the top hook.
Now gotta remove blades and "sharpen" them. Yearly thing.
Green bush hog. Wife says my tractor and its implements look like a clown.
