7,453
Hey partner, what kind of baler do you have? Looks like the cows already been in it and you stealing it from them not taking it to them.
hillbilly162
1993 b7100
Nov 23, 2014
40
mount pleasant pa
no baler yet I work all summer for a guy and he gives me hay instead a payment is fair he gets help I get hay anyways the twine broke on me as I hook on front of bucket im going to make forks or bale spear for bucket
hodge
Nov 19, 2010
2,960
537
Love, VA
Nothing with the B7100, but I have been putting the Kubota-powered Bobcat skidsteer to work. I have been tearing down an old house addition, and using the skidsteer with forks to move debris to a large burn pile.
hillbilly162
1993 b7100
Nov 23, 2014
40
mount pleasant pa
Well you got the job done. If you have a full 5x6 bale won't that be too heavy for your tractor?
I have had the 5x5 to 6x6 bale on the 7100 and it will lift those up but in only lifting like 8 in off ground until I have to lift it up over a hay feeder if she can lift it ill do it if she cant I try to find another idea to make it work 9 out of 10 she does what I need her to do
IDKUBOTA
L3800DT/FEL/BH77 and others
Dec 16, 2012
133
Latah County, ID
tightened the front chains on the L3800 and moved a few items today, and cleaned out a drainage ditch. The weather is like spring here in Idaho. Lots of mud and no snow.
Merry Christmas,
IDK
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Either that's the strongest 7100 on the planet or those bales are light as feathers. My 7100 wouldn't even handle 4x5's, my L3000 just barely does. I tried it on 5 x 3 rolls and it wouldn't handle them and 5 x 6 is a joke. :eek: A 6x6 would give mine a heart attach.
Troutsqueezer
B21, Box, FEL
Sep 18, 2010
17
Pilot Hill, CA
Shaun,
You are exactly correct. Lumpy piles resulting from the uneven dump resulted in lumpy passes. There is no way to really kill these off either 3pt and floating or in 2pt because the scraper floats over the terrain evenly taking an inch off each pass. I found going backward in float after adjusting the rear blade to be only 1/4 inch off the ground under way really helped take out the majority of it. Backing with the scraper locked in position will take it out but you need fine 3pt control to keep it from digging in.
What I am going to do is make FWD passes on the high points with the scraper blades set to just shave off a little each time. The problem this week is my 3pt valve is one of the defective ones that don't move...don't move...then JERK to the next position, so micro management of the blade height is tough. That should be fixed this week as it's one of the items on my dealer repair list.
I am definitely going for the extended warranty. Full factory bumper to bumper 2-year with another year power train for $1300. One major part failure and its paid for. That pushes my drive train out to six years. Ya hope you won't need it but if you do....!!!
I've learned to finesse the lumpy parts with the heel of my FEL (tooth bar prevents using the front) by back dragging. It is possible to make finer adjustments with the joystick than the position control lever on my tractor. Controlling the curl gives you pretty precise positioning on a back drag.
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
Didn't really do any repairs, but was a nice day here and got the L3200 out to stretch and went for a little ride up the road. Now we're looking at temps falling back down into the 20's here in SW Michigan. Back to reality. :rolleyes:
Zekepup
B2410, woods backhoe, finish mower,box blade ,boom pole, old L2950
Dec 8, 2014
Suwanee georgia
Blew a hydraulic line yesterday on my B2410. Have wait to until Monday to pick up parts and fluid. Darn
RIDETOEAT
L4600, LA764, LP Blade,
Dec 26, 2014
132
Southern Indiana
I have not got my new L4600/LA764 yet but I did get to go visit it at the dealer and they had just finished adding the 80% rim guard to the rears and the service tech was going over everything and detailing it for Monday or Tuesday delivery.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Back bladed my neighbors gravel delivery out along his 150 ft drive way.
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
Here's what I did today...I just read this ENTIRE thread. Wow, it took a good while but was amazing to read everything that you all have done. Actually I lied a bit, I didn't JUST read all day - I used my old L260 to push some snowbanks around from last night's storm, too. [emoji41]
aeblank
411
Cadillac, MI
I put on the chains Santa got me. Man did that suck. Pictures tomorrow. Vbar ladder type from tirechains.com. Big ones weigh 75lbs each. Dang.
Sent from my XT1254 using Tapatalk
EDIT: Pictures
new to me backblade:
Modified for my quick hitch:
Snow rig overall (pre-chains):
Front chains:
Rear Chains:
Chains (up close and MEAN):
9,115
Fired her up today to charge the battery, hooked up the blade in preparation for some funk we're supposed to get. So far they've been saying freezing rain and sleet, or possibly snow. They haven't been able to make up there mind.
Installed a single use seat cover also :D:D:D hi class all the way ;)
Skip44
Jeeps, L2900, FEL, tiller, brush hog,post hole drill, rock rake
Feb 19, 2014
116
Alexander, Maine
Has anyone put a mount on their grader blade for blocks? If you have does it help or not?
Skip
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
moved some firewood from woodshed to shop....oh and gave her a secret name but will share because this is orange. "nellie" now I can't believe I am the only sick puppy out there that has named their tractor. come on folks share
Fro65
L3301HST, LA525, BH77, LP tiller, LP grader box, LP blade, BX2380
Dec 30, 2014
220
NorthEast Indiana
Sat on it and made tractor noises...dreaming of nice weather when I can put her to work. :D Glad no one saw me, they might think I have succumbed to cabin fever.
9,115
Skip
This is what I did. Makes a huge difference, I just load it with rocks
