Sorry i do not, he just ordered it out of his kubota book for me, if can wait for a few days before you want to order it, PM me when you get a chance and I will send it to you when it comes in. Surly will be on a box of some kind. Might be easier than finding this thread again and you remembering to do the same.ridetoeat do you have a part number for the "roll indicator kit"
I would imagine that the circuit board is just a controller for the blinker override system on the hazards. I couldn't see why it would damage anything. 12v is 12v. Add turn signal 12v to the existing hazard 12v will still be the same 12v. probably won't blink correctly with the blinkers on though, but only testing will prove that.I have a B2400HSD. The hazard unit (KUBOTA HAZARD UNIT (PART#: 6C040-55520) has died... it just buzzes and flashes intermittently if I tap on the little black box. I priced this part at Kubota and it is almost $50 with shipping.
Here is my question: I know that the original Kubota part is more sophisticated. It has a printed circuit board, etc. The little "can" flasher unit is a standard car part and is basically a mechanical bimetallic contact strip. Does anyone know if there is any reason why my "solution" would damage any other part in the electrical system of my tractor?
Thanks,
Gary, Thanks for commenting on my post/question.I would imagine that the circuit board is just a controller for the blinker override system on the hazards. I couldn't see why it would damage anything. 12v is 12v. Add turn signal 12v to the existing hazard 12v will still be the same 12v. probably won't blink correctly with the blinkers on though, but only testing will prove that.
I think !! ( dangerous I know )he is thinking that the two positions that it does the same thing could be left and right turn signals if all was back to original. ?? it is what I am think anyway. Just guessing though.Gary, Thanks for commenting on my post/question.
Help me clarify your response: The hazards flash/blink like they did before the Kubota unit died. My B2400 has a 2 position hazard switch, and both positions do the same thing (by design--I don't quite understand why Kubota designed the switch that way, but they did). There is no "turn signal" blinker function if that is what you mean. I am not sure what you meant by "...probably won't blink correctly with the blinkers on though..." since the hazards do flash correctly with the cheap flasher unit wired in.
Thanks so much for responding to my question.
Roger
I have not used Line-x, I have used Upol Raptor a number of times. I have found it easy to use and clean up works great on my Jeeps.Mine is just named Boata, kind of a blend of boat which I have had and done my entire life and Kubota. I ordered a FEL bucket roll indicator rod kit from the dealer and Evaluated pulling the floor board for Line-X which looks as simple as can be and will be done soon. I also picked up some proper 7/8" hitch pins for the bottom of the HF quick Hitch and found my 7/8" drill bit so I can open the holes up for the proper pins. I find it retarded that they sell you a Cat 1 QH setup with 3/4" pins where 7/8" should be on every Cat 1. I have a GREAT dealer in "Browns Implement " in Moorefield In. I also ordered a WSM this week.
great Idea, I will be using it. ThanksThis is what I did. Makes a huge difference, I just load it with rocks
Actually, your "thinking" makes all the sense in the world. The Hazard switch has an up and down position, just like a turn signal switch. But the B2400 factory manual clearly states that both positions turn the hazard lights on, and nowhere in the manual does it suggest that there are turn signals.I think !! ( dangerous I know )he is thinking that the two positions that it does the same thing could be left and right turn signals if all was back to original. ?? it is what I am think anyway. Just guessing though.
I thought Kubota used the same system on most of their tractors, but apparently not. I have a hazard switch which blinks the hazards. I have a turn signal switch which turns left or right blinkers. When hazards are on, the circuit board overides the hazards and solids one side while blinking the other for the turn signal. Seems like you are working for the way yours is designed to be then. Always good saving money.Gary, Thanks for commenting on my post/question.
Roger
Thats a good mud. I love times like that, they make me child again, even if i stuck there and they come to pull me out.Alexisferos,
This was mine in the spring last year, and yes it did crawl out of it on it's own.
You have not had enough fun until both you and the tractor are both covered in mud and you need help to get it unstuck.Aargh! I know tractors are meant to get dirty but...
