Dug out and put in a gravel base for our firepit area. We have a metal ring/pot for now but I'll eventually get some stone or brick to make a proper setup.
I got tired of looking at the fuse block dangling from the wire harness and sometimes making it difficult to put the battery cover back on, so I ordered a couple of four circuit fuse blocks and made it a little more professional looking. I drilled a couple of holes in the bulkhead for each block and used screws that were just long enough to secure them, but no long enough to interfere with the removable radiator screen.
The top block is for circuits that are always powered, like the shutoff solenoid and head lights.
he bottom is for all the circuits switched by the ignition switch.
I had to modify the top cover a bit for it to fit since the blocks are mounted so closely together.
The dangling fuse block was just one of those things that triggered my OCD.
View attachment 46703 View attachment 46704
Dave -if you meant 046, you had a good saw to take care of it. Only 2 bigger in Stihl. Heck, the current equivalent of your saw is $1,200 new now. Can’t imagine what the 6xx or 8xx cost....
Now, if you meant 028, that little cuss did some yeoman's work!
Looks like a softwood(?); all the better...
That’s just an amazing job! Good for you!
It's mounted on the rear of the engine on the side of the accessory case.That sure is an interesting place for an oil filter...on a plane or a tractor...![]()
That takes a lot of commitmentA friend sent me these pictures of his episode today:
Before he got stuck.
After he got stuck. 20 hours on his new Orange.It's funny when it happens to someone else.
You gotta love it when people think there new tractor can go anywhere.A friend sent me these pictures of his episode today:
Oh, that’s cool! Have never seen an 048, and it looks in great shape. Ran an 056 AV Super for many years. Thanks!
When 12-14 years old, I buried my Dad's (now mine) 'Moline by going off the "beaten path" on our way to firewood cutting.A friend sent me these pictures of his episode today:
And your Butt feels like it is on fire from the whooping you just received!!Yup, it's hard to recall stuff with your ears ringing.![]()
Those wood
Are those approved safety pants
