tweels
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
For tractors it will depend on how they last/hold up over a long period of time and how much they cost. On tractors that run in mud and small debris I wonder how they perform when filled full of dried dirt.
man00
197
12
okla
True, at the current cost it may be sometime before see them on tractors if ever
Jared 756
MX5400, L3901 and B2601
Jun 9, 2021
53
35
Washington st
Well the day has come!! A B2601 will be getting tweels at my local dealer. Will try and get a picture once its setup and ready to go
leveraddict
Apr 1, 2019
905
594
NEPA
And the purpose of tweels are?????
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
They make tweels for tractors or are you pulling our leg? I'm not very knowledgeable on the subject, but have only seen them on zero turn mowers.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
They don't go flat. Supposedly they have better traction and don't mess up turf as bad and a few other claims like lasting longer, better hillside performance.
Jared 756
Jun 9, 2021
53
35
Washington st
I am right there with you, had no idea tweels for a tractor were a thing or would ever be a thing but here's some pictures. Will get some after they are mounted on a tractor. They are heavier than a normal wheel and tire but probably still need a ballast box to do any real FEL work. Curious how they will hold up in such an application. They are 12N-16.5 Michelin tweels Tweels.jpg Tweels1.jpg
D
Deleted member 47704
Guest
Zero turns tear up the grass something fierce, they cut the grass at work this morning and there are marks all over.They grind the grass right off and you are left with dirt on the grass and bare patches all over.Looks like garbage.
7,430
The statement I put in bold is caused by operator not knowing his equipment!
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
Jared,
Ah, thanks. I look forward to seeing them after being mounted.
3,350
Wonder if we see them on tractors someday, or they have them already?
I had no idea what a Tweel was. Now do after reading this thread.
What is the advantage for a tractor application over foam filled tires? Foam filled tires will be heavier which is good for tractor stability and will never go flat.
In Utopia
L175 FEL
Apr 21, 2013
654
183
Utopia,Tx/Pasadena,TX
I am right there with you, had no idea tweels for a tractor were a thing or would ever be a thing but here's some pictures. Will get some after they are mounted on a tractor. They are heavier than a normal wheel and tire but probably still need a ballast box to do any real FEL work. Curious how they will hold up in such an application. They are 12N-16.5 Michelin tweels View attachment 63542 View attachment 63543
Very popular in upstate New York. Even use em on riding lawnmowers.
