Bearcatrp
Mar 28, 2023
1,037
657
Minnesota
Put my front and rear blades on today to get ready for snow plowing duty. Have knee replacement surgery on Thursday so wanted everything ready in case it snows while I’m going through my physical therapy, which is 6 weeks. Figured I can get on the tractor and drive without issues while healing. Hoping for no snow until end of the month but with the goofy weather patterns lately, may have snow on the ground by thanksgiving. Got 3 1/2 inches of snow last week. Melted in 3 days. Wet heavy stuff.
Sidekick
Jul 29, 2023
1,090
1,524
N.Y,
Put a plow on the RTV X. This time I leveled it
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
I want to set up a tank just like this. Do you have links to your pump and filters?
I purchased the tank with pump and spin on filter already on it. I added the water block cartridge, as I’ve had good luck with them on tanks at work.
Pump is the GPI RB-10
Filter base is from GPI, with their filter also
Water filter is Golden rod water block
Just watch the pipe sizes as GPI makes 3/4” and 1” stuff.
9,689
I notice that the Vevor tanks come with a fuel filter but none of the JohnDow tanks have them. I've not added fuel filters and/or water separators to the storage tanks since all of my equipment has both, and I never had a fuel related issue filling from 5 gallon containers for many years.
I completely understand the addition of filters and water separators since they're easy to add on and provide redundancy, but are they more important with steel tanks compared to plastic tanks?
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Condensation doesn't care if tank is plastic or metal.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,530
3,729
PEI Canada
I use a 50 gallon tank manufactured by Cresent. I have a 12v pump and use a sediment/moisture filter on it.
9,689
A couple of months ago I noticed that the MX left side tie rod guard was bent. I think this happened when I was doing a flail job this past summer at a property that had a bunch of tree stumps and other obstacles hidden in the tall grass. I greased the tractor and loader this morning (got to use the square drive socket again) and figured I'd remove the guard and straighten it for the winter. I'll make up new (better) guards in the spring, and probably for the M6060 as well.
I also ordered three more sets of Outback hydraulic hose markers. I know that some folks think it's a waste of money, but I really like them and they work well for me. My only regret is that the set includes 4A & 4B which I don't need so have a few of those pairs doing nothing.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
The tie rod boots on my mx are shredded. I have looked at those guards and it almost looks like they can/should be flipped and provide a bit more protection on the boots. I need to remember to take one off and flip it to see.
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
265
217
Wahkiacus, Washington
Sold a pig yesterday and used to trusty 'ol B7100 to lift the critter out of the pens. Gutted it on the 6x4. Have the innards in a feed bag in the bucket so today it off and into the forest to feed the wildlife. I always place the pile in a spot where I can set up a game cam to see who shows up for the feast. Most of the time the ravens are the most frequent. But have also seen eagles, coyotes or bear. We have bobcats and cougars out there but never caught any on a gut pile.
Reactions: 7 users
pokey1416
Jun 24, 2020
567
844
SW Michigan
Finished leaves and flipped pusher edge (rubber). Thought I’d clean and wax while I had easy access. Oh, moved the golf cart into storage - you gotta love a FEL 😊
Reactions: 6 users
jyoutz
Jan 14, 2019
3,450
2,532
Edgewood, New Mexico
Thank you. I think I’m going to buy the steel tank at TSC, the fill-rite rotary hand pump, and the filters you’re using.
Xizervexius
BX23S
Sep 23, 2021
24
31
Powell River, BC, Canada
Mounted a tool box off the ROPS. Thw wife had bought me these ammo boxes years ago, finally did something with them. This was the little one (which was nested inside the bigger one), seemed sbout the perfect size for the BX. I needed about a 1" spacer for the lid to clear all the hardware in that area, so printed a spacer out of some flexible TPU filament, which helps with vibrations in this instance.
Couple photos of the stance with the new 2" wheel spacers as well.
Last week I bolted some quick fist clamps on the other side of the ROPS to mount a shovel
And previous to that I removed the bolt on hooks on the bucket and replaced with the JU Fabworks work plate.
And last years mod of the fuel filter relocation kit.
Reactions: 6 users
mdhughes
L3901DT
Dec 10, 2014
1,375
1,164
Ste Geneveive county, MO
I took the tranfer tank in town and put 50 gallons in it. I wish I had noticed that one of the boards on the home made skid was starting to rot.
5,273
Been dry here so I’ve been letting the leaves pile up and blow off on their own but with rain forecast later in the week figured I should blow the gutters on the three houses and get at least most of the leaves mulched/removed. Needed to take the winch off the L and put on the leaf rake.
Before doing that, revisited a maple that fell across a path earlier this year. Had already cut it up enough to clear the path. Skidded a couple logs back to the wood yard to work up later. Dropped the winch onto its dolly and rolled back into storage. Pulled the rake out of the shed so it will be ready to go tomorrow morning.
This will be the first round of leaf removal. Hopefully one more round in a few weeks will finish it. Only thing I don’t like about this time of year is the area around the houses looks a mess. If I get up every leaf in the yards and in the road tomorrow, by Friday it will look like I didn’t do anything at all.
Reactions: 11 users
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
If you are talking about underneath, I used one of those "plastic" air conditioner pads that look like concrete. I did not want anything that would sweat or rot.
BBFarmer
Jul 12, 2024
789
1,619
Terry, MS
Just a quick cut through the berries last night, should be the last one for the season.
