WAS BANNED FOR NSFW PICS
5,152
Spent 4 hours cutting grass with the rear finish mower. One-half hour in the mower threw the belt, so it was back to the garage to get a new belt out of inventory and a wrench to adjust the new belt once I got it on the pulleys. The replacement from Kubota is about $100, Amazon $70, and less than $30 from https://www.vbelts4less.com/. When I was finished mowing I checked the new belt and it showed no wear at all.
Siesta Sundance
Oct 23, 2022
1,819
2,530
youtube.com
Agreed, even a heavy dew works.
Ok we have had a light rain for a bit over an hour!!! Looks like 2/10ths so far, and what used to be dust, lol.
I'm really happy cause I was suppose to put hay out today, but too busy with other projects. I'm really hoping this rain perks up the grass.
Bmyers
May 27, 2019
3,463
4,332
Southern Illinois
Shocker! Watering trees. We're supposed to get some rain from whatever is left of Beryl Wed/Thursday but I'm not holding my breath.
We got just over 4 inches of rain.
We ended up with almost 4 inches from the storm. Rained all day yesterday. Will be out mowing this weekend.
WI_Hedgehog
Apr 24, 2024
717
955
Milwaukee, Wisconsin, U.S.A.
It rained most of my week off, everything in extremely green in Central Wisconsin (if it's not under water).
New kubota added to the fleet. Traded in my 15 year old bad boy. The kohler engine was getting real tired zo I decided to upgrade. Did a little mowing before the rain hits and wow what a difference in power and speed. I found out real quick that I need to take it real slow between the raised beds. The 60 inch deck fits only if I keep the chute up.
Awesome looking machine! I wonder how much a Kubota foot pan mat costs...?
Here's my BX2370 underside before:
and after installing the BXtreme underbody armor:
Reactions: 6 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,458
3,453
PEI Canada
Still talking 1.5 to 4" tonight into Friday on the news. Hope we get it.
S-G-R
Jun 17, 2020
1,458
3,453
PEI Canada
Mowing ahead of the possible rain. 7 out of 9 acres done.
Bearcatrp
Mar 28, 2023
900
569
Minnesota
View attachment 132448 View attachment 132449
View attachment 132450 View attachment 132451
I bought one last month for my 1880. Will install it when the mower deck comes off before the snow flies.
Bearcatrp
Mar 28, 2023
900
569
Minnesota
That looks like jack Daniel’s instead of water.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,536
central ct
Progress on the antenna tower today :)
Drilled the hole for the 1st I Beam anchor point, set the beam with the tractor and then filled the hole with quick setting concrete. That 18" auger made quite a bigger hole than 18"! I didn't get to use my extension here as I hit a serious rock at 4'. Command decision was made - 4' was enough. I am going to plant large rock against the beam to supplement the ground support.
The white marks on the i beam are from the Ospho. Will wipe off that powder residue before I paint the beams.
BTW holding that 400lb bean out like that was a tension convention time. I should have switched back to the ballast box before moving the beam into position.
Reactions: 10 users
WI_Hedgehog
Apr 24, 2024
717
955
I was a bit baffled why the mower deck lift wouldn't lock at "Top" with the BXtreme armor installed. The instruction sheet mentions a gold adjustment bolt behind the left rear tire (the right side does not have a matching bolt). I marked the side facing me with a black marker to keep track of the starting position and one turn was all it needed. After cycling the up/down a few times it loosened up and the bolt could be set one flat spot "tighter" (5/6 of a turn from starting). Really easy.
I also used Red thread lock on the bolts so they don't back out on me (a common problem in my world), Blue (medium strength) is probably a better option, though I don't plan on taking off the mounting bushings.
Bearcatrp
Mar 28, 2023
900
569
Minnesota
The mower deck should protect underneath so I’ll wait. Didn’t think it was possible to have that plate installed along with the mower deck. May leave it on next spring when the mower gets installed. Was it fairly easy to install that plate with the tires on the ground or should I lift the tractor?
WI_Hedgehog
Apr 24, 2024
717
955
With the BXtreme armor, only the armor or mower (one of the two) can be mounted at a time because the armor plate uses the mid-mount mower lift arms to hold the rear of the plate in place. (The front section rests on bushings you install into existing holes in the tractor frame). Installation is quite easy, put a washer, bushing, and second washer on a bolt, put the bolt through a hole in the frame, then add a washer and nut and tighten. Repeat for the other side, then slide the armor over the bushings and lock it into the lift arms after you lower them, then raise the lift arms and set the mower height dial to TOP.
(washers and nuts that hold the bushings)
(slide over front bushings, then latch rear pins)
(than raise mid-mount accessory arms to raise the plate like you'd raise the mower, then use the dial to lock the plate in the fully up position TOP)
I had to adjust the bolt by the left rear tire to get the mower dial to turn to TOP with the armor on because the armor wouldn't allow the arms to raise quite as much as the mower deck allowed.
According to what I read, with Bro-Tek a similar area is divided into two sections and the rear section can stay in place, the front section needs to be removed when using the mower.
5,100
Started the day with the forks on and the tractor just happened to be the most convenient vehicle available at the time, so used it to move a whopping 44lb of cat food to the chest freezer at the storage house. The overkill was almost comical, but it worked.
Over the past 6 weeks we’ve had rain all around us but until day before yesterday, not a drop of rain here. Hadn’t mowed since the last rain so it was looking pretty ragged. Got a soaking rain that dropped 1.5” on us. That didn’t exactly fix everything, but it was worthy of getting out the T2290 and trimming up the yard.
After that, trimmed up the dead branches along the driveway and a few live ones that were encroaching a bit much. 3 grapple loads later, it was quite a bit tidier. (The pic is part of the trail to the brush pile by the shed, not the driveway.)
Later, after work had stopped for the day, stopped by the new development directly across the road. Looks like they’re about done with the initial grading Everywhere there’s a pipe sticking up, there’s a house going up… about 200 of them. I am SO looking forward to it.
This is what it looked like before…
I suppose some think it’s an improvement. 🤷‍♂️
  • Sad
S-G-R
Jun 17, 2020
1,458
3,453
PEI Canada
Later, after work had stopped for the day, stopped by the new development directly across the road. Looks like they’re about done with the initial grading Everywhere there’s a pipe sticking up, there’s a house going up… about 200 of them. I am SO looking forward to it. View attachment 132552
Not me, I'm not thrilled with my one new neighbors house beside us. That's why I keep watering those trees 😉
5,100
I’m very thankful I have a few hundred mature trees between my house and my new neighbors. Otherwise I’d be dusting off the old water wagon in the shed and we’d both be watering. 🙂
WI_Hedgehog
Apr 24, 2024
717
955
Ordered 3 grease zerks to replace the missing MMM wheel zerk (2 spare) after reading your comments about thread pitch, and a hood skirt retaining knob from the dealer... prices are reasonable and Kubota quality is tops. Front headlight lens is about $150 from Messick's so not going to bother asking the local dealer about price and the cracked one is going to stay. Thanks for the needle greaser idea, in this case the MMM is too spendy to not buy a few $1.35 Kubota parts that will last the life of the mower instead of generic. The wheels get used a lot on the Wisconsin glacier-formed terrain (seems Climate Change isn't man-made after all). Let's hope the replacement zerk stays put.
Rear remote is getting installed.
Rear remote hydraulic installation came to an abrupt stop when the Landpride kit wouldn't quite fit.
The extension pipe needs to be removed and needs a short nipple on the far side to match the nipple on the near side, but that's not in the kit. Dealer sent an inquiry to Kubota on this situation, which is the nice thing about having a great dealer.
Where's a good place to get quality 1/4" Pioneer style hydraulic parts?
