Jsjac
B2650
Feb 13, 2022
206
330
Kind of crappy weather today. Sat in the tractor cab for a few hours today. Had light rain on and off all day.
I used the stump grinder to remove eight medium size stumps (around 12 inches in diameter) and ten stumps that were 24+ inches in diameter.
Also ground probably 20 small stumps 8 inches or less.
I should have taken a before and after picture but I didn't.
I also worked on my road a little bit also. Ground a couple stumps in the road. Cut some branches and downed trees also.
mdhughes
L3901DT
Dec 10, 2014
1,325
999
Ste Geneveive county, MO
Put the grapple on the L3901DT and move a couple 80" logs from a Blonded Ash that I cut down a couple of weeks ago. It's a little muddy here and had a little fun getting out of the area that the logs were. Blocked the logs up and got them split and stacked.
I then used the grapple to gather some leaves that I had blown together last month. Moved them down in the woods.
Reactions: 10 users
g_man
Feb 3, 2023
241
1,087
NE Vermont
Curious - how do you do this with your grapple ?
gg
GrumpyFarmer
4,009
Took the little girl and the tiny tots out to clean up a tree that fell a while back in a storm. Time allowing maybe get the chipper out tomorrow.
Reactions: 6 users
WAS BANNED FOR NSFW PICS
5,152
Used it as a learning experience for him on fixing a tire in the woods…
There is an easier way to replace the valve stem than taking the tire off the tractor and breaking the tire bead. I had the tire valve stem fail on my water storage tank and there is no way to get into the tank to repair it. I learned about this tool that replaces the valve stem from the outside. You install the valve stem onto the tool, and lubricate the valve stem first with tire lube (dishwashing soap). Next, put the plastic tube over the valve stem hole and push the new valve into the hole using the tube. When I did this job, I pushed the valve stem too far, so I had to hold the valve stem with my fingers and unscrew the tool to get the "funnel" out of the way. Then I put the tool back onto the valve stem and pulled up on the stem until it seated into the hole properly. I think that the reason it went too far into the tank was because I didn't have enough strength in my hands to put the valve stem into the hole, so I used my rubber small dead blow hammer. Took all of 10 minutes including reading the instructions.
Chanceywd
Mar 26, 2021
690
612
central ny
I am having a lot of arthritis and trigger finger problems, I have a weak grip too. But his tool looks like something I might have to have!
I have a handle for pulling in valve stems and an assortment of stems on hand. It is that little funnel thing I lack.
Thanks for posting it.
Bill
GrumpyFarmer
4,009
I like the saw box setting on your ballast box (y)
gg
Thanks. I built the top box a while back (link below)…it slips on and off without any fasteners.
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
134
238
Mark Twain Forest
Cleared out some cedar, hickory, oak, and trash trees. A couple of stands of black walnut have grown; and I am clearing out the competing undergrowth so the black walnut can flourish. Although gooseberry is growing with the black walnut. Trying not to rip those out is challenging.
ken erickson
Nov 21, 2010
1,256
2,165
Waupaca Wisconsin
I see you’re located in the Mark Twain national forest. I had 35 acres off the Berryman rd, north of Hwy 8, west of Potosi, Washington county with two sides bordering the Mark Twain. I now live in Central Wisconsin and think back just How remote my land was in Missouri compared to my land now. Missouri is a beautiful state and I still miss it after 22 years!
Nomore67
Currently own- LX4020, B2601, IRE20 (mini-ex). Previously owned- BX1870, B2601
Apr 28, 2019
29
38
Minnesota
Couple of simple additions to the LX4020... Added a little extra weight to the box blade for more traction, 👍. And, added an ammo box toolbox onto the slow moving vehicle bracket, 👍.
Reactions: 6 users
