hope to float
L3450
Feb 18, 2018
485
61
Ireland
I can see that I am going to have to take more care naming my photos when I move them to the laptop. :rolleyes::censored:
UpNorthMI
May 12, 2020
849
566
Up North, MI
It was time to clear a couple of woodland food plots. Out with the chainsaw to leave 3’ high stumps, Kubota track loader and hydraulic tree puller makes quick work of the stumps. Track loader with skeleton bucket to scrape, fill and level ground. MX 5800 with 84” EA Extreme landscape rake to smooth, level and collect debris. Final pass with chain harrow really tidies things up. L3200 with PTO spreader adds a little lime to balance out soil PH. Will be planted for bow hunting season in October. Would be impossible without equipment,
mdhughes
L3901DT
Dec 10, 2014
1,323
998
Ste Geneveive county, MO
Took a couple stumps out. This one just didn't want to give up. Got it in the end. Had a pretty go size tap root, found it after using the shovel to clear some of the dirt from under the stump.
BX23S
2022 Kubota L3901 FEL, BH, GRAPPLE, PALLET FORK, SNOW PLOW and Hard Canopy
Sep 1, 2018
70
41
ID
Nice work with stump removal!
I did the same thing last year, unearthed around eight stumps, and enjoyed every minute of it.
shootem604
Apr 23, 2018
874
British Columbia
New wheels and tires are on the L245DT. Dished out the wheels to give me an extra couple inches on each side for extra stability too.
Magicman
Oct 8, 2019
5,910
8,936
Brookhaven, MS
knotholesawmill.com
Yup, it is bumping up. I use 5 gallon jugs for my "off road" and they are all full. Non-ethanol gasoline jugs are also full. ;)
Kevin1
Husqvarna MZT 52, BX2380,FEL, Box blade, Landscape Rake
Dec 15, 2017
127
New Bern, N.C.
Finally got around to checking the hydraulic pressure on my 2380. With 222 hours on it I was showing 1650PSI. I shimmed it up to 2000PSI.
5,315
Finished my cherry picker - stripper cage... added a saw holder as well.
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
I installed a quick connect to the battery, and wired one onto my new sprayer so I can spray stuff and things.
SidecarFlip
Banned
557
Cleaning away. Running hay always leaves everything covered in chaff and I have a couple issues to address as well. I have a main gearbox seal weeping gear oil on the round baler, needs replaced and I have a couple knives on the disc mower that need attended to (replaced). Such is life with hay harvesting.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
I installed a quick connect to the battery, and wired one onto my new sprayer so I can spray stuff and things. View attachment 44424 View attachment 44425 View attachment 44426
When you put that sprayer together, did you put the 4 bolts in the bottom of the tank to attach it to the frame? There was a lot of complaints of the tanks cracking at them bolt holes. I left mine out, the two straps over the top will hold the tank just fine. 3 years with mine and no issues.
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
I did install those bottom bolts. Wife went off full bore bouncing like crazy. Tank is fine, but she hit the fence when she was coming out of the pasture.
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
I did install those bottom bolts. Wife went off full bore bouncing like crazy. Tank is fine, but she hit the fence when she was coming out of the pasture. View attachment 44436 View attachment 44437
I already fixed this, and I'll yank those bolts out next time I'm outside, in maybe a week because we are getting 6 days or rain most likely. Does anyone actually use neutralizer after spraying 2-4-D? I filled it with 20 gallons of water, ran the handheld until it was running clear, then did the same for the boom, then let the rest run out in the ditch.
