JimDeL
Aug 31, 2022
388
444
Austintown, Ohio
@GreX, @JimDeL Here is a picture that I took when cleaning up the deck. Normally, I store it against the garage wall during the winter. I will try to find the company I purchased them from, but I know that others have come up with DIY solutions as well.
Thanks for the pic. Are the axle shafts a full inch/25mm diameter, or smaller? Are they cross drill so they can be pinned to keep them from sliding back and forth?
I'd like to make a set, but haven't found any wheels with 1" diameter axles. I may have to find someone with a metal lathe to cut the shafts down.
je1279
LX2610 w/ 60" MMM, LP 72" Snow Plow, EA Wicked 55" Grapple, and Woods 60" BB
Dec 6, 2020
828
585
Upstate NY
I'm unsure of the diameter, but I can check this afternoon. The ends are definitely smaller, 1/2" maybe. They are crossed drilled and that hole is used to pin them to the guide wheel arms on mine. I know the configuration for the BX decks is a bit different though. Unfortunately, the site I purchased them from no longer appears to be in business. If I were building my own, I would try to incorporate locking caster wheels as they would make close quarters maneuvering much easier. Here is a link to a solution from another member.
JimDeL
Aug 31, 2022
388
444
Austintown, Ohio
I'm unsure of the diameter but I can check this afternoon. The ends are definitely smaller, 1/2" maybe. They are crossed drilled and that hole is used to pin them to the guide wheel arms on mine. I know the configuration for the BX decks is a bit different though. I just checked my email and the site I purchased them from no longer appears to be in business. If I were building my own, I would see if I could incorporate locking caster wheels as they would make close quarters maneuvering much easier. Here is a link to a solution from another member.
Thanks for the info. The swivel casters sound lie a good idea, too.
GreX
BX2380
Jan 8, 2023
185
132
Maine
I'm unsure of the diameter but I can check this afternoon. The ends are definitely smaller, 1/2" maybe. They are crossed drilled and that hole is used to pin them to the guide wheel arms on mine. I know the configuration for the BX decks is a bit different though. Unfortunately, the site I purchased them from no longer appears to be in business. If I were building my own, I would see if I could incorporate locking caster wheels as they would make close quarters maneuvering much easier. Here is a link to a solution from another member.
Agreed, thanks for the link, looks pretty simple, I think even my poor attempt at DIY projects could make something like that. Get a couple feet of pipe, cut in half, make holes in the pipe for the casters and a pin in the middle (for stability) and you have yourself a mower deck dolly. I've seen the dolly's that folks have purchased, and they cost $300-$400 which is a bit too steep (https://www.deckdolly.com/deck-dolly/).
@JimDeL - here is a video - https://deckaxles.com/
5,936
Day 3 and finally done. Pulled out some more HUGE boulders and "replanted" them in backfill.
I just heard that we will be back in the spring to do the entire right side of the building as well.
dig:
pipe
backfill
burried some rocks and tried to grade it before dark
Reactions: 11 users
Tschulz
LX2610
Nov 28, 2023
I have a LX2610 I hooked up my snowblower LX2963 and I’m getting a grinding noise from the blower. Any idea what is going on,
RMS
Sep 26, 2021
279
608
Buckfield Maine
The coupling for the blower might not be lined up. Move the lever to the uncoupled position and remove the cover (4 bolts). With the pto lever in the rear position you can rotate the coupling to where it lines up correctly. This happened to me my first time through it too.
Foxrunfarms
Kubota LX2610, 1951 Farmall M, 1967 John Deere 110 Rf, 2010 Arctic Cat 700
Apr 25, 2023
366
529
WI
We had about 2.5 inches of snow this past weekend. It was wet and heavy, the ground wasn't frozen so I left it. This morning I leveled the ruts and speed bumps out so I could walk better. Pros and cons vs the tractor and atv
5,181
drewzee87t
L45 TLB, B2910 Turbo
May 20, 2016
176
misery
Pulled a RAM 4500 dually with a dump body and trailer out of my ditch/field with L45. Had to drop the trailer to get the truck out. Picked up trailer with my little 1500 4*4 and got it all back up and on the road for the guys that were fixing my house this week. No pics but my yard is a mess lol
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
Well...consider that aerated!
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
You might want to do a full inspection of their work. They have a truck and trailer and don't know how to drive. Don't be so sure they know how to "fix" things.
g_man
Feb 3, 2023
299
1,340
NE Vermont
I put on my chains today. A wet and merky day but above freezing. I use the "H" pattern chains because I depend on them a lot and they can't hide between the lugs on my R1 tires. I use the "drive them on" method to mount them. I have a length of rope with a hook on each end. Hook near the center of the chains and loop the rope over a set of tires lugs.
Drive forward, stopping to check once in a while, that they are well centered.
When you get all the way around the chains are tight and with "H" chains there is plenty of slack to hook the centers. At least 6' of slack here.
Then when you hook the side chains and close the long cam levers everything tightens up - easy peasy.
gg
Reactions: 14 users
trial and error
Feb 16, 2023
394
386
NY
Got to participate in one of our local towns christmas parade today . We where originally going to go and just be spectators but I havent gotten any seat time in a week or two and was looking for any excuse. Had to take the counterweight back off amd I still wasn't sure if the tractor was going to fit on my tiny little 4x8 harbour freight trailer (sketchy) with the new plow configuration. We'll it didn't fit very well frontwards as the plow was hanging wayyyy too far forward and I was in danger of hitting the tailgate that I just had repaired when I turned. Soo I did what any logical person would do and put it in backwards, still sketchy but slightly less, and I only had to go a few miles (famous last words)
No pictures of that debacle and I'm sure if I had any and posted them here I would get an ear full from the safety Sallies anyway that part worked "ok" and I made it to town trailer sides and ramps in the truck tractor on the trailer with less then a couple inches on either side.
Got to town unloaded the trailer put the sides on "decorated" the trailer, so the Mrs and month old boy could ride in the back, and Little B and joined what was said to be roughly 90 other tractors side x sides trucks and other odds and ends ranging from a couple zero turns all the way up to full on 100hp + ag machines even had 4 Lamborghini tractors show up.
Few pictures below
Reactions: 9 users
SAR Tracker
Nov 17, 2020
248
368
Central Oregon
Stored the pallet forks and the FEL/Bucket for the winter, put the front mount snowblower on, and put the plow blade on the Polaris ATV for the "small stuff". Pretty much guarantees no snow until February!
trial and error
Feb 16, 2023
394
386
NY
Bingo on the forecast prediction
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Next year, I'm going to use the loader to get my mower deck back and forth from its storage orientation. I have the axles that allow you to store it vertically when not in use (they are great and save a bunch of space), but I've been lifting and lowering it myself for the past three years. Let me tell you, that ~400lb deck (RCK60-30BB) isn't getting any lighter as I continue to get older. Work smarter not harder as they say...
Mine have been used for 6 years. A previous tractor, now this one. These made to order at the time. No Longer Available.
mdhughes
L3901DT
Dec 10, 2014
1,369
1,153
Ste Geneveive county, MO
Got some 80" logs out of the woods, blocked up, split and stacked. Also got some pole wood out, was a little long, but I was able to get through the woods with it. Was a little tight getting around the corner of the shed. The logs and pole wood are from a Maple that was blown down a couple months ago.
Bearcatrp
Mar 28, 2023
1,031
646
Minnesota
serious lugs on those chains.
