Flintknapper
L2350DT
May 3, 2022
1,998
2,532
Deep East Texas
I fully agree. Those hollow trees scare me. I'm a weekend lumber jack, so I know I lack the experience and skill to handle it like the professionals. We have a few trees that will wait till my more experienced tree cutting friends can come take them down or the weather does it for us.
Smart of you. Part of the trouble....is not recognizing from the beginning that the tree is hollow or otherwise compromised inside. As bad as the OP's tree was, you would have discovered that when making your face cut.
But many trees are only partially rotten inside (not completely hollow as in this case) and can start falling (or come apart) unexpectedly. Especially if you have a 'leaner'. Where I live we have several tree types that are notorious for being hollow or partially rotten inside.
Water Oaks and Hackberry trees to name a couple. If I have any suspicion about them at all....I will make a single plunge cut with the bar to see what is what.
Bottom line: If the tree makes you feel spooky, follow your gut feeling and leave it alone.
hoot owl
L2501 with loader and backhoe
Nov 13, 2022
94
272
53
65653
Bussey week so far. Our youngest son came over Monday to help me cut down dying trees and trees that the tops came out of in last Sunday night's storm. I finished up the down trees by my self yesterday.
We dropped around 20 trees along our 6/10s of a mile drive. Cut them in to logs for the local saw mill to pickup. I will cut the tops when the weather is colder. I have plenty cut and dry for this winter to heat the shop.
42 logs in the pile. The one on the right was to heavy for my 2501 with 6' bush hog on the back to lift.
Today we received some much needed rain. 2" so far and more coming over night tonight. I am taking my chain saw with me to church just in case the storms tonight bring down anything else.
Going to start swaping an engine for our daughter tomorrow.
johnjk
Apr 13, 2017
1,696
1,896
West Mansfield, OH
Fired up the B1700 and got my mow in. Spitting rain but just enough to cool me off.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
I pulled the pump jack & pipe out of a newly discovered well. The well is 28’ deep with 11’ of water. I’ll get a pump & see how good this well might be. Sure could use the water now.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
I made it. I just rolled some 16 gauge sheet steel to the size I needed. I welded the cylinder, but left a tab extending out (like the number 6). Welded a disk on the bottom & painted an odd shade of orange. I attached 2-100lb magnets (from Amazon) to the tab. It hasn’t moved a mm. I mounted a holster with the same magnets to the inside of the fender, same result, very solid.
Reactions: 12 users
hatfieldsminifarm
B2650hstd with fel, landpride box blade, lp 3rd function kit, es pallet forks
Apr 16, 2023
14
Hart county ky
i used the fel on my b2650 to load a refrigerator onto my enclosed trailer, as well as a box of number 2 copper wire, and some other misc scrap. moved my log splitter in to the garage to get it out of the rain. and took the trash up to the road.
g_man
Feb 3, 2023
305
1,383
NE Vermont
Bussey week so far. Our youngest son came over Monday to help me cut down dying trees and trees that the tops came out of in last Sunday night's storm. I finished up the down trees by my self yesterday. View attachment 108923
Nice pile of logs. What wood species are they ??
gg
hoot owl
Nov 13, 2022
94
272
53
65653
They are all oak. We had 4 that were hollow and left them lay. The bears will take them apart for the grubs and ants.
I unloaded 40 cinder block today that my son borrowed back in the spring. They were stacked on a pallet setting in a friends field. I backed up to the stack and started loading them on the truck. Got down to the last 3 block and a small Skunk stuck his head out. I backed up to the drivers door of my truck and thought now what? I wanted to clean things up so he could get another cutting of hay. I remembered I had a new can of wasp spray in the back seat. I sprayed the skunk several times and he headed out through the field with a few extra shots to keep him moving and finished loading.
Changed the oil and filter in the truck after lunch, because I have a 250 mile trip tomorrow and back on Saturday. The truck only has 321,000 on it so I have to be nice to it once in a wile.
g_man
Feb 3, 2023
305
1,383
NE Vermont
Gave him a dose of his own medicine :)
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Reactions: 8 users
ken erickson
Nov 21, 2010
1,305
2,303
Waupaca Wisconsin
6,010
had a crappy week with the kubotas.
Sewer line job was supposed to be 6 feet deep. Got out a tape measure and it was 8' plus. No big deal right? Wrong! The new gas line was installed directly on top of the sewer line. :mad: That creates a real problem. I couldn't bench the right side of the trench and had limited room on the left side due to the water service. I knew we were in trouble and suggested we don't even start and just get a larger machine.
Well, we were encouraged to try. Started digging and found this lovely mess. It was completely covered by ground (the cap you see was our plug we used when we uncovered it.) Yes, the black line you see directly behind the risers is the gas line and yellow trace.
I kept digging (cautiously) and we had shoring in place to make the connection at the house foundation. We were going to skirt the new line out and then back in to the connection at the curb to try to get away from the gas line. The cast iron trap had an additional abandoned sewer connection as well as a very old rain leader. Evidently, they ran them as a common when the house was built. We didn't get very far the first day.
Second day, the guys were working at the foundation (inside the shoring) while I continued to dig with the U-27. The right side of the trench caved in. Almost took the new gas meter with it. :mad: It happened in a millisecond without warning. The guys were safe but we all were shaken up. That was it for me.
We backfilled the entire trench, covered it with heavy mil plastic, then threw the dirt mats over top in order to try to keep everything dry. Will be back at it next week with the large rented mule and trench boxes.
To add insult to (non) injury, the last bit of concrete and trap got stuck in my truck bed while I was dumping it out....GRRRRR
the next morning, I was on to another job to re-route some sump and rain leaders...I was the only one that showed up. No one let me know that the job had been re-scheduled. GRRRRRRRRR
  • Sad
Reactions: 8 users
pokey1416
Jun 24, 2020
568
855
SW Michigan
I forgot to post this awhile ago sorry. For all of you that have a backhoe on back. Reverse your pads for soil work. Wow, what a difference in traction. Machine stays planted - makes it harder to crab yourself around but it’s worth it. I just use a hitch pin on the other side of the pad pin.
frysl
L3301 LA525 FEL & FDR1672 6' Finish Mower
Jun 13, 2016
Sumner County, TN
Made another big pile of tops a small pile of future mulch thanks to my PTO driven chipper.
5,183
Not sure what I am seeing here.
That appears to show the normal way for the pads on my L48 TLB.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,535
3,754
PEI Canada
Going to mow grass and then I have a few trees that need to be pulled out.
