g_man
Feb 3, 2023
287
1,310
NE Vermont
Very relieved to have found a coolant drip - took about 4 days before I was sure.
Found green snow under the tractor in the woods. Lower hose clamp had drips on it. Tightened both clamps and wiped everything off. Next morning it was worse. Hard to see but saw it running down the water pump gasket - oh no. Kept looking and found one small drop on the top hose, Tightened those and wiped. Next morning lower hose dripping again but it turned out to be fluid pooled up above I couldn't reach with a rag ran down. Yesterday all good - phew.
gg
Mowbizz
Bx25d
Aug 19, 2021
555
321
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
530
gg
My RTV keeps doing that from the first week I brought it home. I have a couple rad hoses that leak as soon as it cools off after use. I've tightened them and it still keeps leaking. I'm going to have to take the hoses right off and clean everything I guess.
Trustable
l2501HST
Jul 5, 2022
209
137
5,179
Called a dealer about looking into a price for a landpride land plane/leveler. Expected to be like $800-$1000 for a 5 foot medium duty version. The light duty 4ft version meant for a bx/b was at least $1800 iirc. At that point I said appreciate you looking but not willing to spend that much. May have to create a facebook account again to check marketplace, think im gonna stick with used implements wherever possible if the price is better.
The used implement price WILL be better!
5,835
Did you have a chance to get this checked out?
The dealer is sending a service tech/truck Friday am. I'm hoping it's just a fitting somewhere in the innards. I really didn't want to be wrenching on it myself after day 1. I lost quite a bit of hydraulic oil as it's no longer visible in the sight glass. Fingers crossed.
Trustable
l2501HST
Jul 5, 2022
209
137
Hopefully they can get it fixed at no charge to you. Maybe some of the prep work the tech at dealer did was incorrect possibly. Based on your pictures its not like you use it in the woods or on super rocky terrain that would knock something off from underneath.
Trustable
l2501HST
Jul 5, 2022
209
137
I Hope so, there is a guy near me selling his 90s or 80s ford tractor with some TSC implements, they look in really good shape, the backblade looks almost brand new, but hes asking way to much for a used implement, within 100 dollars of a new one. Hopefully that isnt a trend!
5,179
Depends on your available funds.
I would submit that TSC implements, either new or used, are at or near the lowest quality implements in the marketplace.
Most TSC implements are currently made by Tarter Gate, which is the lowest cost US implement builder.
If you want a QUALITY back blade, check out the Everything Attachments "6 Way Deluxe Scrape Blade".
Yes: It will cost more, but it is worth every penny (I am not a you must buy everything from EA crazy sorta guy).
I have had three other blades, and the EA 6 Way Deluxe Scrape Blade is more easily adjustable, and by FAR the best!
Trustable
l2501HST
Jul 5, 2022
209
137
I will have to check it out! I have heard that about tsc implements, hence why I would be willing to pay a few hundred for a used one, but not 700-800. I am currently using a backblade my neighbor used to use with an old 8n or 9n, it seems to work fine for snow removal and cutting in trails. The thing has been modified over probably the 80 years since it was made with all sorts of welds and plates.
5,179
Check out the Everything Attachments "6 Way Deluxe Scrape Blade" on their website.
It ain't cheap.....but don't do as I did, and buy 3 new blades before I finally got the right one.
The EA 60" 6 Way Deluxe Scrape Blade is kinda pricy at $1382, but is shipped free (maybe a small fee to the UP), and without tax.
A blade is a once in a lifetime purchase......but can get kinda pricy if you buy 4 of them,.... like I did!
Any back blade will work, but the EA blade is SO much more user friendly, and SO adaptable for all sorts of uses.
Trustable
l2501HST
Jul 5, 2022
209
137
I'll have to keep them in mind, I have heard nothing but good things about them (except some long lead times) on here and other forums/media.
5,179
I think their lead times have lessened significantly recently, as they apparently have moved into new manufacturing facilities.
I just can't say enough about that 6 Way Deluxe Scrape Blade,.... of course,...... I bought mine 5+ years ago, when as I recall, it was under $900.
Flintknapper
L2350DT
May 3, 2022
1,974
2,507
Deep East Texas
Post Oak blew over into the edge of the Fish Pond. Not quite sure how I'm going to go about cutting it up and removed, but confident it will involve the tractor is some way.
Flintknapper
L2350DT
May 3, 2022
1,974
2,507
Deep East Texas
Way too much of a task for a 25HP Kubota!
Agreed.
It will need to come out in pieces for certain. I have a couple of 90 hp. tractors available to me. But you'd be surprised what the little Kubota (that could) will push and pull. It won't lift much of course.
5,179
Agreed.
I do not think that I would attempt that project with my L48 TLB.
