Bmyers
May 27, 2019
3,495
4,425
Southern Illinois
Went out to the farm and learned a few lessons today.
The law of gravity is still in effect.
Don't put off until tomorrow what can be done today.
Always have clean underwear with you.
My typical mowing is usually uneventful. I was 20 minutes from finishing, listening to 'We built this city on rock and roll'. As I was enjoying the music, probably a little to much and letting my mind wander, I was quickly brought back to reality when my tractor started to rollover to the left.
Immediately the old pucker factor kicked in and with zero thought I just turned into the roll and down the hill we went. A little rough landing at the bottom, but was on all four tires and the tractor didn't go completely over.
Turned off the tractor, removed the seat cushion from between my butt cheeks and got out to inspect everything.
The area I was mowing is on 15-20 degree slope, but we mow it all the time and we mow it up to the edge of about a four foot drop down to the next level which we have a path to go down and mow that lower section. We have worked on making the drop off less and turn it into more of a slope, but until we remove some more brush and old stumps (now there is less brush to remove), can't finish smoothing the transition down, so we are stuck mowing along the edge.
Since I had become so focused on enjoying the tunes, I had forget about halfway along the edge we had removed a tree stump, which left a nice little hole and of course it was all overgrown, so while I was doing my drum routine with the music, my front left tire found the hole and decided that the tractor needed to go that away. I have mowed around that hole for few years now, always planned on fixing it, just never a priority.
I checked the tractor over, operated everything, looked for any damage, but besides the skid marks on hillside and my underwear, I could find no damage to anything, all lines looked good, steps okay, nothing looked out of whack, which I was very thankful.
I finished mowing and then before putting the tractor up I placed a few loads of dirt in the hole and worked on smoothing it out.
I have mowed that spot dozens of times and always had to remember to take the jog around the hole. Today, it just about cost me for not taking the time to fix the hole.
So the moral of the story is to always fill your holes otherwise you may end up filling your drawers.
Reactions: 14 users
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Moved about 1000lbs of bricks (what I call concrete "pavers" used to build retaining walls) from one spot to another spot 250' away.
3 loads of aprox 330lbs/load with my little BX. Could definitely feel the weight for sure.
Then I used the (empty) bucket to help pound in some 6' rebar "posts" into the ground for a future garden fence. Ended up using a small 2lb maul(sp?) and also a 10lb sledgehammer (way easier than the bucket.) My ground is super-duper rocky so small/short sharp blows (hammering) is easier than trying to "push a floppy" bar into the ground with a tractor bucket on slightly uneven ground.
Couldn't get the 1 picture off my phone onto my computer. Sigh....oh well !
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
Been a long time since I've posted on this one.
Finally got around to doing some repair and other work.
Replaced the oil pressure and volt meter that haven't been working for quite some time water temp has been working just fine.
Replace the glow plug light and tachometer now I have only 209 hours on my machine 😁
Added an inverter, albeit a cheap Harbor Freight one, but I've had good luck with these in the past, actually this is an old one that's been well used and still working great.
ACDII
Oct 21, 2021
685
429
Illinois
My kids ( actually my daughter, the son stood there watching, the lazy bum) cleared out the area in the barn where I planned to put shelves, so today I put the shelving up and went to see if I could get pallets up and on them. Thats a big I don't think so Tim. I just do not have enough room to swing in with the stalls behind me. I also found the 6' finish mower exceeds 6' and doesn't fit the shelf. I guess the next step is to clear out the back of the barn, level the dirt and put a pad in the back that I can reach with the tractor and put the shelves there instead. At least now the log splitter and two mowers are in and out of the weather and still have room for the little green garden tractor and both fuel tanks, just not the room I was hoping for.
7,066
Bill you go to the "Nth" degree to detail on your tractor and equipment rehabbing.
billrigsby
Mar 17, 2015
1,039
217
www.facebook.com
Bill you got to the "Nth" degree to detail on your tractor and equipment rehabbing.
Thank you sir,
I know a lot of it's not perfect, I don't have a machine shop,
I do what I can,
the best I can,
with what I got.
And I'm generally happy with the results.
And if I wasn't you wouldn't see it until I was. 🙄
radas
Mar 21, 2022
719
834
My buddy stopped by with his dump trailer and I used the forks to clear 3/4 of my brush pile. We crammed most of that brush in his 14' trailer and I trimmed the sides off with my chainsaw. The tarp and one strap held things together. He will be using the WC46 to chip all the cedar brush for blueberry plants to get the soil acidic. I'll burn the rest of the pile tomorrow to spite our Karen neighbor who doesn't like me burning 😂
My woods are finally starting to look good and walking/driving through is not a chore anymore. After I grind the last few stumps down, I'll use the box blade to smooth things out. And decide what we want to do here (shed or cover it in wood chips and leave it "natural")
TheShadyKubota
2021 BX2380
Apr 1, 2022
108
81
Manitoba, Canada
Tackled 50 ton of 2" down limestone to extend our driveway another 70'. Surprisingly this task only took a few hours including final grading with the box blade but I was impressed with the capabilities of the BX2380. It's no skidsteer but it did give me a reason to not do anything else on the honey do list for a few hours lol
3,678
Send the pic to your own email address…then download it into your photo gallery, then you can send it to others…or upload it to a post such as this one.
3,678
That inverter is a good idea! If I do one I think I’ll install it inside the canopy so rain, etc won’t get into it.
I suggest you install a fusible link or, fuse or C.B. on that “hot” lead to the inverter.
What do you use the inverter for?
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Yes, I am fairly tech savvy, but my wife took the pic, has no email on her phone and texting the picture to me works 99% of the time, but not on this occasional. (I think the picture file is corrupt.)
Another day, I'll do a similar photo.
Thanks though ;-)
dieselbob69
Kubota BX2380 (previously a BX1870 and GR2100)...
Jan 2, 2022
159
61
WNY
Dealer trip again today, as when I picked up the R14T tires last week I saw some Land Pride quick hitches on display-the QH10 and QH15. Started doing some lookin' on the internets and decided I wanted one. Salesman told me the QH10 and QH15 weren't for the BX series(just as well, they started at $550). He directed me to the one specifically for the subcompacts, I think it's the QH5??? It has a round frame. $270 including tax. Got home and put it on. I'm sure it'll make attaching my implements way easier. Inquired about a RCR1242 rotary cutter, about $1500 plus tax. Salesman said some people have used the 4' ones on the BX, it can handle it ok from what he's heard....
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
QH05 here for my bx2380. I think a qh10 would've fit also. (but I wanted the smallest/cheapest/lightest one possible,.
We must've bought 2 of the last. Those models are not being made anymore.
You'll enjoy it.
TractorTime
United States
I put the pallet forks on my B2601 and hoisted some solar panels and an attic fan on to the roof of my house. Much safer than trying to juggle that heavy stuff on a ladder. Pallet forks are a must-have!
Grandma15240
KubotaZ421KWT-60
Jul 25, 2022
Took my Z421-60” mower to the welding shop to find this out….caused by the brackets being welded on uneven at the factory ! About 1/2 to 3/4 “ difference from one side to the others! Two weeks past warranty! Quality control guy musta been out to lunch !
  • Sad
dieselbob69
Jan 2, 2022
159
61
WNY
You'll enjoy it.
There were 4 on the floor, first one was already sold. They have at least 2 left. At least last 2 of serial # is same as my birth year….
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
Dealer delivered our 2680 with R14 tires as they did not have turf tires. Turf tires came in and the dealer brought them over and installed them today. Ride is a bit better.
Mowbizz
Bx25d
Aug 19, 2021
556
322
Took my Z421-60” mower to the welding shop to find this out….caused by the brackets being welded on uneven at the factory ! About 1/2 to 3/4 “ difference from one side to the others! Two weeks past warranty! Quality control guy musta been out to lunch ! View attachment 84222
What part is that? The part that holds the deck? I have the Z422 and will be checking those welds on mine!
billrigsby
Mar 17, 2015
1,039
217
www.facebook.com
Probably not a bad idea, rarely out in the weather though.
Mostly for a small weed wacker when mowing, but
will come in handy for any small AC item.
