ACDII
Oct 21, 2021
685
429
Illinois
Well, First use of the JD 1209 MoCo. I spent a good 6 hours putting the new sickle bar and parts in, and finally hooked it up to the tractro. Worked really good considering I only paid $1600 for it. It needed a new PTo, but I knew that when I bought it, and had to make an equal angle hitch for it, which I didn't know it needed, but knew the sickle bar needed replacement. Thankfully only needed 3 guards along with the wear plates and hold downs.
So all told, $372 for the sickle portion, another $550 for the PTO, and $60 for the steel to make the hitch.
All in, ~ $2600. The least expensive mower near me was $3K when I found this one 2 hours away. Had to rent a trailer to get it, but well worth it.
Reactions: 7 users
5,902
Ground some stumps yesterday for some quick cash. I wound up using the quick hitch with a PTO extender. All went fine but my neck was still sore from the day before. All in all it was a good weekend for the Kubota.
aaluck
Oct 9, 2019
982
833
Snowdoun, AL
I never had a good solution for storing / mounting it. I eventually got a chain fall under the deck to hang it with. Worked ok but not the best. I suggested to Adam that he build a frame to store it on. Unlike me, he can weld.
My $.02.. I just dig a hole about 2 feet deep and leave it there in the hole. Back up, hook it up next time I need it. Takes longer to remove the quick hitch than to hook it back up.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
Thanks aa!
Yes I have heard of users doing that and mentioned it to my son. For me, I just couldn't get comfy with the idea of that tip just sitting in the earth . . .
Mowbizz
Bx25d
Aug 19, 2021
555
321
Mowed my ENTIRE lawn (weedy grasses) today with my z422-54.
This timeI tackled my hilly grass around the house…some squirrel-y action on a few down slopes but she climbs like a trooper. Found out I need to go up then back down (reverse) in a few spots as it was too steep to keep control…no problem as it’s still faster than with the BX. I’ll figure it out😂
BigG
Sep 14, 2018
1,951
774
West Central,FL
Did the front end get a little light as you are going up the hill? I have never used a ZT but it seams like driving up a steep hill does not sound like a great idea. Stopping the mower as you go down backwards does not look like something you want to do either. I load some equipment on my trailer butt first because driving up the ramps forward allows the front end to become squirrely.
9,561
View attachment 80545 View attachment 80546 View attachment 80547
Wow! Great implement and photos. (y)
MOOTS
MX6000
Jun 27, 2019
2,188
2,713
Canton, Georgia
Fuel tank clean out on the L5030 at work. Pretty easy job. Found some rubber bits as well as some hard brittle transparent plastic sheet, algae maybe? Got everything reassembled and will fill with fuel and a dose of power service tomorrow.
9,561
I picked up the M6060 from the dealer this morning and drove it 3 miles home. I want this beast to be as stable as possible on my hilly property so had the wheels set to widest and beet juice ballast added. I might add wheel weights at some point too. It looks more like the back end of an M5 now.
I was in Illinois for work all last week so it was the perfect time to have the following options added:
Creep range
540/540E
3rd function
Third remote with float option
Top-n-tilt
I like the stainless steel hard lines running along the loader arm but I don't like the hoses they made up for the top-n-tilt. Just no thought put into how they were set up. Also, a panel was scratched, there were oil smudges all over the place and generally I'm not impressed with their work this time. That's what I get for not buying the M6060 from them I guess.
I'm taking the MX6000 to the dealer tomorrow to have the wheels altered to the second to widest setting, or maybe the widest, I still have time to think about it.
9,561
Pulled out some old fence posts with the bucket hooks and a chain. Running a string line so I can put in new posts
I've pulled a lot of fence posts with a hi-lift jack, and a bunch more with a chain/bucket/tractor which sure beats the jack. But .... if I ever replace the 3/4 mile of fencing around my property I'll be buying one of those hydraulic post/tree pullers. Not too bad when you have a helper, but still, hydraulic is the way to go.
TomGT350
MX6000 HSTC
Aug 20, 2021
51
54
Maryland
Creep range
540/540E
3rd function
Top-n-tilt
If you don't mind answering, what did adding the Creep range cost?
Ty
9,561
Ty
I don't mind at all. The Creep "cassette" with installation was $1,184. No one at the dealer has any idea what the manual is talking about when it describes how to and how not to use Creep range.
Magicman
Oct 8, 2019
6,046
9,476
Brookhaven, MS
knotholesawmill.com
The customer bringing me another log. Only about a half dozen left to go here.
I am down to only two logs for tomorrow morning and this sawing job will be completed.
foobert
BX2380
Mar 25, 2021
110
105
Washington
Well folks, I did it. My borrowed time finally came due: I wedged the post-hole-digger and the lil BX couldn’t lift it out.
My soil is glacial till and there’s an abundance of “potatoes” waiting to be found. They range from softball to lumpy beachball sized. I can usually work them up (or around them) and the trick is to feather the 3-point down so that it’s not given any chance to “thread” onto a rock. But, it was the last hole for the night (naturally), and I just got lazy and let it drill on in.
The auger would spin just fine, but no matter how I nudged it for and aft, it just wasn’t budging.
Fortunately, my rescue plan that I’ve had in the back of my mind for this eventuality worked out just fine. Sure would have been nice to carry all that heavy stuff out to the field with the loader bucket…
Just for an idea how stuck it was, I darn near broke the single 4x4 in the first pic and had to double it up before I could get any movement.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
I'm sorry this happened to you, but I must say---VERY inventive solution.
Well done.
Just to an idea how stuck it was, I darn near broke the single 4x4 in the first pic and had to double it up before I could get any movement. View attachment 80626
s
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,525
3,709
PEI Canada
I only had about 10 to take out. Got posts in all the holes and started to get them lined up. I'll finish them up tomorrow night.
