9,749
Today, my new rotary tiller was delivered. It’s an Indian brand called LandForce, and I’m pleasantly surprised by the quality, especially given the price. It’s more affordable and seems better built than some of the more well-known brands in this area.
I decided to test it out, but unfortunately, I chose a spot under a tree. It ended up cutting through a root, which also snapped the safety bolt in the process—bringing my work to an abrupt end. I think I managed to till a whole 3 feet before it happened! šŸ˜‰
Better a shear bolt than a gear case! šŸ˜‰
Reactions: 6 users
Rosohatica
Kubota L3200, Tehnos MULS 130 flail mower, Fužinar 14ā€ plow, Landforce 5′ tiller
Feb 23, 2022
225
92
Zagreb, Croatia
That’s true. I’ve had a more serious incident yesterday too. Remember my worn-out tires? Well, I’m not sure new ones would have made much of a difference in this situation.
My shed is on elevated terrain, and I was heading downhill. The ground had been frozen solid for about a week, but yesterday, a southern wind brought temperatures above freezing. The top couple of inches of frost melted, leaving a slick surface, while the ground beneath remained frozen.
As I started downhill, even in a slow crawling gear, the tractor began to skid and pick up speed. Panic set in because at the bottom of the yard, there’s a fence and a narrow passage. I tried to brake—big mistake. The tractor started to rotate, with the back end sliding sideways.
For a moment, I was terrified it might tip over. Thankfully, the hill is short, and before it could roll, I reached the bottom. Disaster avoided, but just barely!
Honestly, I doubt new tires would have made much difference in those conditions. Even chains might not have been enough to handle that slippery mess.
9,749
Did you have it in 4wd? 4wd helps with braking too, as the front wheels will brake too.
Also in 4wd you can keep a little more traction.
Chains are a huge help in Snow, Ice, Mud and Slime, you might really want to look into them for future use.
WI_Hedgehog
Apr 24, 2024
986
1,375
Milwaukee, Wisconsin, U.S.A.
@Rosohatica : Diamond-pattern chains, even without studs, should cause your tractor to stay grippy. They cost more, but less costly ladder-bar chains have non-chain areas that ride rougher and can slide when braking--pumping the brakes helps if the wheels rotate and catch, or you might have to go forward a little to rotate to a chain area (and sometimes only one wheel catches), experience helps. More ladders also helps but the cost goes up and at that point diamond pattern are only slightly more.
Studs will damage pavement and concrete, and dirt paths and everything else, but wow they grip. I have them on lighter equipment for use on hard ice.
Old_Paint
Dec 5, 2020
1,944
2,130
AL
That's what shear bolts are for. Hate it happened, but at least you didn't blow up your PTO.
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
268
228
Wahkiacus, Washington
When we actually get snow deep enough to clear the steep, boulder filled logging trail I use Big Bertha. I take her down the grade with the 8' bucket at least 6 inches above the road. The tires/chains mash things nicely. On the way back up I fix problem spots. I never want to hit a boulder that was deposited in the last ice age with the loader bucket. It stops a 20k machine in an instant. I hurts both the machine and me.
In the end it can make the difference between having all four pickup wheels chained with v-blocks or just two. If not plowed ya park at the bottom and walk a few miles with your groceries.
Packed snow works good until it melts and freezes in wheel ruts.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
197
Waterford, Maine
Yep that counts,have you tried that green slime stuff? It worked on my front that kept going down.
I installed the Green Slime in my ATV tires in 2009, and later moved the tires to a Polaris Ranger side by side. The tires show a lot of wear, but I have never had to add air to any of the 4 tires. Still on there today, and I swear by Slime.
old and tired
1,919
1,297
I will NOT use Slime any more... It blew up my tire!!! Looked like a scene from Ghosts Busters...
Also, had it in my tractor tires, when I finally had to go to tubes, it was a royal pain in the butt to clean the rims after I had slime in there.
JRHill
Apr 26, 2016
268
228
I prefer to fix a tire/rim bead instead of using slime. But it's a thing of personal choice. When I was ranching we had pasture cactus deluxe and sometimes you couldn't see them until it was too late. Old hard tractor tires were desirable. I considered but never did do the slime thing except for one front ATV tire and it's still being used. I added the slime somewhere around 15 years ago.
But something is wrong with the above referenced post. Never have I heard of Slime deteriorating a tire causing an explosive blow out.
"... it was a royal pain in the butt to clean the rims after I had slime in there. "
This is why your wheels are the last ones to be worked on at the tire shop. But I'm guessing you don't use a tire shop too often.
old and tired
1,919
1,297
....This is why your wheels are the last ones to be worked on at the tire shop. But I'm guessing you don't use a tire shop too often.
Actually, the tire shop that I went to was pretty busy, so I took it upon myself to clean the tire before the tube was mounted. The Shop worker thanked me but I told him since I was the idiot who used it... I wanted to clean it myself.
As for the tire that popped, I did see it earlier in the day... over inflated... Cracks showing bad. I had to fill that tire that morning and I know I did not fill it that much. So, in the morning I filled it correctly. By 4 or 5 o'clock it swelling, showing the cracks bad and the explosion happened about 1 AM in the morning.
The guy staying in our camper at breakfast ask what the heck was the explosion - no else heard it and we thought he was crazy. I went down to my tractor and there was some slime on it.... actually all over it... and the house, whole underside of the deck... everywhere.
I went inside laughing my butt off... had everyone come out to see the results of the explosion...
PS. Slime was put in the tire 10 years earlier... and had been topped off at least once or twice in that time. And yes, it still needed to be aired up before use. Again, not recommended....
Scottly
B2601, LA434 loader, SpeeCo E-Hitch, LP-FDR 1660 mower, LP-GS0560 land plane
Jan 24, 2017
35
58
Indiana
Swapped out the land plane for the rear grader blade. Fueled her up.
8 to 12" of snow with sleet mixed in supposed to start in the morning.
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
Who you gonna call? 😁
mdhughes
L3901DT
Dec 10, 2014
1,396
1,267
Ste Geneveive county, MO
My wife and I did firewood yesterday and used the tractor to move logs to the splitting area. Don't have any pictures, but I did move a couple good sized Black Oak logs. Even at 60" they were pretty heavy.
I also replaced a burnt out head light (thanks nerwin) and man was it a real pain to get the "new" bulb in. trying to get the back part of the socket back in was a real pain. I was just able to get myself between the grill guard and the radiator and get both hands to try to get the bulb in place and the back of the socket pushed in and turned.
I'm think about trying to create a tool to help push the back part in. Maybe something I can 3D print.
papajoe
L3901DT Shuttle (2017), B6100E (1978), B6100E (1979), B6100HST-E (1985), RTV500
Dec 26, 2017
98
178
Oak Grove, La.
I serviced my RTV 900x today, all oils and filter and a grease job. Sort of expensive, but not too bad of a job. I had a good fire in the heater and have a car lift in the shop. It takes nearly 7 gallons of super udt2. (ouch) and those transmission filters are pricey. I was somewhat suprised at how easy everything was to get to, except front diff. fill. Winch was in the way, but a small funnel and a piece of clear tubing made it a simple job. Hydrostat seems a little smoother and quieter now.
hoot owl
L2501 with loader and backhoe
Nov 13, 2022
94
272
53
65653
This was last Monday. Used the tractor to put the roof on the new shead.
Reactions: 10 users
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
I am in the process of installing a Kubota D-782 in a International Cub LO-Boy,it should be interesting
Welcome to OTT, from S. TX.
Start a project thread as progress is made.
biketopia
Feb 15, 2024
378
384
Warrenton VA
I got the tractor all fuled up and in the garage for the snow storm. Looks like we have about 8-10" already. This is the first big snow we've gotten in the area since having our property. I almost bought a plow for the tractor a few years back but decided to put the money elsewhere. We'll see how badly I tear up the driveway with the bucket and walk behind blower. Thankfully it appears to be a nice light fluffy snow.
Ping
BX2370-1
Dec 25, 2018
342
311
Troy, Ohio
Plowed 3"+ of the white fluffy stuff this morning. 22F outside with 10-20mph winds, I was thankful I have a heated cab. ;)
