What damage can repeated Jump Starting cause?
BX23-S,57 A-C D-14,
5,818
I still have one...'somewhere'.... don't loo that pretty though !
It's used to power the starter relay( 1 amp ) NOT jump the battery +ve to the starter +ve(300amps) though.
I did post a 60amp push button switch from Princess Auto for $10 ? that would though. Dang copper wire to get from battery to dash to starter woill cost a LOT more than the switch !
5,745
The one I pictured is for jumping a starter solenoid or relay to battery. That's an order of magnitude less than starter motor current. Given its HF its probably marginal ampacity for that.
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
I am NOT bridging at the starter motor itself.....I am "bridging" the red and black leads coming into the starter rely harness which holds the starter relay switch
You must be misreading wire colors.... that relay is picked using BRown wire(+) and Black wire with white stripe(gnd)
[I am looking at the schematic diagram.... is it not correct?]
My goodness, looking at the schematic, there are ONLY a keyswitch and a 5A fuse in that circuit. (to Brown wire)
ALL THE SAFETY-SWITCHES ARE ON THE GROUND-CIRCUIT OF THE RELAY (Black wire with white stripe) and you already told us that is not the problem
