Welder Advice
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Have you used this wire successfully before? Have you tried a different spool of wire? Has the wire developed some corrosion on the surface? Could the wire be out of spec.
Sidekick
Jul 29, 2023
1,248
1,795
N.Y,
Check the liner you installed. Most are .030 for plain mig wire.
soloz2
85
80
WNY
I get the not wanting to spend too much just to see if you like welding. However, I think a cheap welder will make I much more likely that you struggle and give up out of frustration than a good welder will. I have a Lincoln 210MP. I wired in 220v, but it runs off 110v as well and I've used that setting, but the machine is much more capable when powered by 220v. I also got a Lincoln Viking 3350 hood. As a hobby welder at best do I need a good hood like that? No, but it allows me to see and I'm positive my ability to see what I'm doing makes me a better welder than I would otherwise be.
On a budget today, the Titanium line at HF gets pretty good reviews. I'd still get a 220v machine or at least one that can run off either 110 or 220 and start with 110 if needed. Get a good hood so you can see.
Grab a Vulcan hood as they also get pretty good reviews. Don't forget to budget for gas. You can start with flux core, but shielding gas will give you much nicer welds as well.
5,304
I agree with the 220V machine, but I’m not "100% sold" on the import machines causing bad welds.
Similar to the the Miller vs. Lincoln Vs. Hobart v.s (whomever), I wonder how much the machine counts vs. the skills of the actual “welder himself”.
Any machine my welding instructor touched, laid beautiful beads. But he had “thousands of hours” of experience.
Much like, my fat ass, buying an expensive “tennis racket” certainly ain't gonna make me play like John McEnro, and expensive golf clubs wont make me John Daly …….
(We do have similar "body types" and "bad habits" though…and apparently “fashion sense” too..:ROFLMAO:;))
If I thought I could lay down beautiful “Stack’s of dimes” every time because of the machine, I would have bought one these "Miller Dynasty 300’s” many moons ago…...
But, after taxes, at $16,000, I don't think it would make me much better of a welder……(Just poorer, ………….and possibly single ;) )
(Wow they have really skyrocketed in price…..I remember them being ONLY $7,000 not too long ago……….I still want one though……………)
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,937
2,334
Western MT
I bought my Miller MIG 25 years ago with a spool gun. It's still very good. At the time, two of the advantages were the spool gun and duty cycle that stomped most of the machines at the time. Sure, it was a bit more, but it's still going strong at 25.
However, technology has changed over 25 years. The difference in quality probably is a lot less than it was 25 years ago.
11,757
I bought a Millermatic 185 over 25 years ago (also with a spool gun) and it's still going strong. One thing about higher quality welding machines of yesteryear is that they're better able to deal with all that life throws at them. My welder lives in an unheated garage that can be -20°F in the winter and 90°F in the summer and yet it still works whenever I need it to. The duty cycle is great too, but most hobbyists aren't going to worry much about that.
The Millermatic is a 220V machine as is the Lincoln SW TIG 200 and the Hypertherm 380 plasma cutter that I have, and personally I'd have no use for 110V anything when it comes to welding and cutting.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
I have a small Miller Challenger MIG welder which works well, but for a lot of tractor stuff it's too light.
I also have Lincoln IdealArc stick welder (250 A AC/DC) and this is what I use for anything 3/16" or over.... it's nearly 500 lbs, much of it copper, and it welds very nicely. There's one locally on FB Marketplace for $100; it looks a bit ragged but there are no delicate parts inside.
One of these, plus a auto-darkening helmet and some basic leather protection (Harbor Freight is inexpensive) and you can be learning to weld pretty cheaply.
snoeproe
BX23s
Feb 19, 2026
12
I’m a Canadian red seal jman welder. CWB certified structural welder. Stick and flux core All position. Post secondary welding instructor. CNC plasma table experience.
my advice to a beginner is to avoid 110/120v powered units. They are too limited in ability. I have 2 machines at home. Lincoln idealarc 250 ac/dc stick machine. Runs on 230/460/575v single phase power. Burns any rod I can throw at it. I also have a Miller bobcat 250 gas powered machine. Mounted on its own trailer I built. It’s multi process and I run stick and flux core wire with a suitcase feeder.
I would avoid any Chinese made machine. As for me, I’m only buying Lincoln, Miller/Hobart or ESAB.
Concept Automation LLC
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
I live in northen new england far from civilization so the usual advice doesn't really hold true, hence why I'm looking for something I can mail order that would be easiest to learn on. I can add a 220v outlet if I need to go that route.
. I worked for a major welding equipment mfg. 20 years. Dealing with Bath Iron Works Shipyard Etc. I should add my comments to the end of this thread, after a certified weldor from Canada, respectfully added his. . I'm bombarded with ad's here trying to post. Thus the possible typo's.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
I will say I worked for Thermal Dynamics Inc. Pioneer in Plasma cutting, since 1956, in Lebanon, N.H., long before Hypertherm. Thermal brought to market, the first single phase 230v, and 120v, made in USA, and 1st. in the world, plasma cutter, when I worked for them in the 1980's. THAT said, I was the rep. for Bath Iron Works, that brought in the first 40 lb. hand carry 1/2" air plasma, to , take on board ship. It too was made in N.H., Not China. . FAST FORWARD Today. I just ordered for the HELL of it a $180 ARC-CAPTIAN, 50 amp 120/230v air plasma cutter to test. As if I don't already have enough in SEMI-retirement. Same for welders. I have a wonderful 45 year old I bought new,, Lincoln SP-150 MIG, Miller XMT-304 Stick /Mig Tig, Thermal Arc AC/DC 250 Inverter Pulse TIG, CobraMatic_Aluminum Push-Pull System...........As I REALLY Hated to see the "China Syndrome" tools, equipment, and welders, invade my marker place, I'm also going to buy that Arc-Captian Full Blown Multi Process Mig-Tig-Pulse_Mulit Volt to test in my shop. JUST FOR THE HELL OF IT !!!!! Two reason why.......I just joined this "Orange Tractor Talks", don't even have my used B2650HSDC yet, got so many wonderful answrers from Kubota owners helping me get started to get ready with options, I thought with your limited budget and welding skills, even though I Hate China imports, this Arc Captian product line has too many You Tube fabricators Thumbs up. I need to challenge. When I worked for that mfg., I was proud to help design. I still do. I sell new and custom re-furbish CNC Plasma/oxy cutting machines today. If you have bought a Tig/Mig machine yet, I'll post my results on that Arc Captian when I test it. Most often, some things are too good to be true.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
I still long to find a mint orig. Lincoln SP-125, that runs on 120 v. ( for my body & tin work and moving around ), , but it welding 3/16" with .035" wire is pushing it. I agree you should put in a 230 volt outlet, at least 30 amps. Flux Core gas-less wire OK for brackets etc., like stick welding. Sheet-metal / cosmetics need .030" wire & gas, or TIG, that's where you could get away with a 120 v. machine. FYI: One Lincoln Electric "Bent Carrot" marketing product is the SP-150 Welder at the Big Box Home Store. It's a look a like to the one at the Industrial Welding store, $$$$ Hundreds Less, Gas-Less, No Gas Solenoid Kit, Only 4 Voltage Adjustments (Not Continuous Pot, so Sheet Metal Impossible). What a bargain !!
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
Hobart Ironman 230, Miller wand, c25 gas, excellent mig results last eight years
Great news. Like what You have.
My only caution to those buying new mig welders, are those with gasless flux-core, can they latter be upgraded, if you need to, gas kit for doing finer work like sheet-metal.
AND, is the VOLTAGE Control in STEPS or a Continuous knob. If in 4 Steps,, it's a Cheap worthless for Sheet-metal fine tuning, Goldy Locks Syndrome. Get What Ya Pay For.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
71
57
Shelton, Washington
I bought a Prime Weld 180 last year and I love it. I think it's selling for around $550 now with free shipping. Runs at 110 or 240. Comes with a spool gun for aluminum which I don't think I will ever use. I put a dedicated 240V outlet in my garage for it. (highly recommended)
You will want to factor in a bottle of gas to run it in mig configuration but it comes with the flow regulator.
Reviews
I used a Lincoln SP100 mig for 40 years prior and the Prime Weld 180 blows it away on 240 volts.
My story is the same as this one. After retiring from my construction gig, I took a couple quarters of community college welding labs (Saturdays 9-4) working on stick welding profieciency. I already owned a Lincoln AC225. Then I bought the same Primeweld machine as above. It was shocking how easy MIG was compared to stick, though since I had some stick experience, it may have contributed to the easy transition.
The 180 seems to be a really nice little machine. I am now working on tuning up my stick welding skills again in preparation for welding together the ripper attachment for the BT1100 on my L48. The MIG is a little short on heat for 3/4 to 3/4 connections. Or so I have been told.
It will not run 6010. It is a little sketchy with 6011, though it may be the cheap rod I bought. My next purchase of 6011 will be a different brand, not from India. The 180 runs 7018 really nice. Absolutely fun to run the 7018 on it.
The 180 welds nice on 110, but better on 220, without a doubt. Also, the company has VERY responsive customer service. You would not be disappointed if you chose their product. Easy ordering and quick shipping. I could not have one complaint.
Have fun welding.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
Have fun welding.
I must say I always want to buy American. I worked for an American Mfg. of Plasma Cutters for 20 years. Still I sell as a dealer, CNC American Mfg. Plasma machines. BUT, As a Hobbyist, a friend has a Miller Maxstar portable Stick /Tig. The P/C Board Blew. $1,200.00 replacement part. He Went to Harbor Tool, got one made in China for $300, and is happy. I can't argue. A throw away tool.
RunAmok Ranch
L4600, Landpride 1860 shredder, Landpride box blade, Greenline Auger
Nov 29, 2023
10
24
Tellico Plains, TN
I chose a multi-function 120/240 inverter rig from ArcCaptain ordered through Amazon.
I like that it will allow me to do multiple welding methods. I learned as an apprentice (40 years ago) that stick welding and my vision didnt get along, but Heliarc (TIG) was my jam. The MIG function will let me run flux core wire without gas, or plain wire with shield gas. I run the unit plugged into a 50A RV outlet I had installed outside my garage when we built our house. My barn has no power yet, so I can power it with my generator if working there.
Haven't used the plasma cutter yet, but I need to cut patches to weld on my brush hog deck.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
197
270
Hardy, VA
I have the ArcCaptain MIG205 which I feel is the machine you speak of. I upgraded from a 120v Hobart that was great but I needed more oomph. I tried to hunt down a decent red or blue 220v machine on the local used market but they are still very pricey. So I gambled and got the $700 ArcCaptain and it has exceeded my every expectation. I have only used the MIG, stick, and plasma functions to date. I am VERY impressed and feel that for the hobbyist like me doing smaller fabs and minor repairs - this is all the machine I will ever need.
chim
Jan 19, 2013
3,278
2,976
The specs on my inverter welder indicate the THD of a generator powering it need to be under a certain percentage. You may want to check that.
