Welder Advice
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,069
2,611
Near Lancaster, PA, USA
Have you used this wire successfully before? Have you tried a different spool of wire? Has the wire developed some corrosion on the surface? Could the wire be out of spec.
Sidekick
Jul 29, 2023
1,164
1,638
N.Y,
Check the liner you installed. Most are .030 for plain mig wire.
soloz2
WNY
I get the not wanting to spend too much just to see if you like welding. However, I think a cheap welder will make I much more likely that you struggle and give up out of frustration than a good welder will. I have a Lincoln 210MP. I wired in 220v, but it runs off 110v as well and I've used that setting, but the machine is much more capable when powered by 220v. I also got a Lincoln Viking 3350 hood. As a hobby welder at best do I need a good hood like that? No, but it allows me to see and I'm positive my ability to see what I'm doing makes me a better welder than I would otherwise be.
On a budget today, the Titanium line at HF gets pretty good reviews. I'd still get a 220v machine or at least one that can run off either 110 or 220 and start with 110 if needed. Get a good hood so you can see.
Grab a Vulcan hood as they also get pretty good reviews. Don't forget to budget for gas. You can start with flux core, but shielding gas will give you much nicer welds as well.
4,763
I agree with the 220V machine, but I’m not "100% sold" on the import machines causing bad welds.
Similar to the the Miller vs. Lincoln Vs. Hobart v.s (whomever), I wonder how much the machine counts vs. the skills of the actual “welder himself”.
Any machine my welding instructor touched, laid beautiful beads. But he had “thousands of hours” of experience.
Much like, my fat ass, buying an expensive “tennis racket” certainly ain't gonna make me play like John McEnro, and expensive golf clubs wont make me John Daly …….
(We do have similar "body types" and "bad habits" though…and apparently “fashion sense” too..:ROFLMAO:;))
If I thought I could lay down beautiful “Stack’s of dimes” every time because of the machine, I would have bought one these "Miller Dynasty 300’s” many moons ago…...
But, after taxes, at $16,000, I don't think it would make me much better of a welder……(Just poorer, ………….and possibly single ;) )
(Wow they have really skyrocketed in price…..I remember them being ONLY $7,000 not too long ago……….I still want one though……………)
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,831
2,250
Western MT
I bought my Miller MIG 25 years ago with a spool gun. It's still very good. At the time, two of the advantages were the spool gun and duty cycle that stomped most of the machines at the time. Sure, it was a bit more, but it's still going strong at 25.
However, technology has changed over 25 years. The difference in quality probably is a lot less than it was 25 years ago.
10,646
I bought a Millermatic 185 over 25 years ago (also with a spool gun) and it's still going strong. One thing about higher quality welding machines of yesteryear is that they're better able to deal with all that life throws at them. My welder lives in an unheated garage that can be -20°F in the winter and 90°F in the summer and yet it still works whenever I need it to. The duty cycle is great too, but most hobbyists aren't going to worry much about that.
The Millermatic is a 220V machine as is the Lincoln SW TIG 200 and the Hypertherm 380 plasma cutter that I have, and personally I'd have no use for 110V anything when it comes to welding and cutting.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
120
106
Lopez Island, WA
I have a small Miller Challenger MIG welder which works well, but for a lot of tractor stuff it's too light.
I also have Lincoln IdealArc stick welder (250 A AC/DC) and this is what I use for anything 3/16" or over.... it's nearly 500 lbs, much of it copper, and it welds very nicely. There's one locally on FB Marketplace for $100; it looks a bit ragged but there are no delicate parts inside.
One of these, plus a auto-darkening helmet and some basic leather protection (Harbor Freight is inexpensive) and you can be learning to weld pretty cheaply.
