Switching grease and pondering compatibility issues
B737
LX3310
Jun 9, 2019
2,022
2,205
for leaky grease guns these are handy
LockNLube Grease Gundom Gun and Coupler Cap
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
I looked at those. You can buy just the locking tip as well. About $25 on Amazon. Have you used one? My concern is it looks kinda long. Can you get it in all the places on the tractor? Some areas are space limited.
4,199
BTW…. when I buy a new grease gun (or refurbish an old one)…. I clean the outside of the barrel with solvent (acetone or mek works good) and paint a colored band around the barrel and then use a Pilot-Marker to label what type grease is inside that gun.
(My Moly greasegun has a Kubota orange band around it labelled “moly”. My general-purpose lithium red-grease gun has a Red band around it labelled “lithium”. My boat-trailer wheel bearings greasegun is painted green…the same color as the grease…. and labelled “marine”, etc etc. They all hang upside down inside that 5 gal bucket.)
I found a HF copy of the Lok-n-load for $17 and it works good.
Hope this helps with ideas.
Tornado
792
255
usa
If you are greasing only once a year…that helps explain why your grease gun leaks oil. Grease is supposed to supply oil to the bearings/bushings/etc and good grease contains lots of oil and eventually will seep oil ….unless it doesn’t have much oil to begin-with.
I have a half-dozen grease guns with specialty greases in them … all different. I keep them hanging inside a 5-gal bucket with their bodies inside the bucket and their handles hanging over the rim on the outside of the bucket. Any oil drips remain IN the bucket that way. I keep rolls of paper towels all over my shop on paper-towel-holders in handy locations. I grab a handful and wipe down the grease gun as I pull it out of the bucket and thereby keep everything clean.
If you only grease occasionally…. buy a very common name-brand of general purpose lithium grease… like Lucas or Pennzoil or Valvoline…. and you’ll never be faced with incompatibility issues the rest of your life…. they’ll be here a long time. Buy a “designer” grease and you’ll have more difficulty…. if not this year…then next or the one after that.
Use lithium on everything except pins/bushings (such as the loader) and Moly on pins/bushings and you’ll be “set”. (That Lucas Red N Tacky may seep oil but it’s GOOD oil. and clearly has plenty of it….and THAT’s good also. Buy a case of paper towels and grease more often.)
I have never said anywhere that I only grease once a year, so not sure why you mention that here. I grease more regularly than owners manual calls for actually. The issue is I simply have a single tractor, and only do about 50-100 hours per year on it. I live on 13 acres, not a farm where I am using the tractor every day. I often go several weeks at a time without ever using the tractor for anything. I prefer to use greases that dont leak. Some are known to leak over time, others do not leak. I prefer ones that do not. There are lots of good greases out there. Some that leak are good, I never said they werent good, just that I dont want to use them.
Anyways thanks all for the replies I think the topic has been exhausted. I will take my research with some of the feedback here and make a decision.
EDIT: The lock n load head is great. Ive used it since day one.
4,199
….. I only use one tube of grease in like a full year…..
While that original-post statement does not equal to only greasing once per year…. it implies that you grease only occasionally … and that is why I suggested that you find and use a more commonly available grease … you started this thread to address the fact you can’t find your previous grease… a more common brand-name and type will alleviate that difficulty was my suggestion.
No intent to enflame…. it’s just the way I read your comment.
BTW, incompatible greases can prevent proper lubrication as they do not blend… they separate which leads to galling and scoring. Incompatible and improper grease has contributed to tragedies. Alaska Airlines Flt 261 crashed (93 killed) due to improper maintenance and one of the factors was incompatible grease. AS33 grease by itself would be fine. Mobilgrease 28 by itself would be fine. But if mixed the two incompatible greases contributed to excessive wear of the trim jackscrew.
From the report: ““Over the course of the investigation, the NTSB considered a number of potential reasons for the substantial amount of deterioration of the nut thread on the jackscrew assembly, including the substitution by Alaska Airlines (with the approval of the aircraft manufacturer McDonnell Douglas) of Aeroshell 33 grease instead of the previously approved lubricant, Mobilgrease 28.”
While regular inspections should have caught this excessive wear the inspections were also inadequate and were blamed as the primary cause, …. and while either AS33 or Mobilgrease28 alone would lubricate .…. the incompatible greases mixed together accelerated the wear.
If you change types of grease then remove ALL the old grease and replace with the new to avoid incompatibility.
Hope this helps.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Some will spread manure and try to tell you disassembly and cleaning is required before switching
I knew this was coming.......
So any time you buy any new or used piece of machinery, it must be disassembled to clean all grease from every lube point.... because you never know what type of grease the factory or the previous owner used.:poop:
3,084
Thanks for sharing that B737. I read it over. It seems the 238 is excellent for things like loader greasing, but due to its 5% moly compound and tackyness, isn't recommended for automotive wheel bearings. The paper does mention use in bearings in other places though, so Im just curious....
Do you guys reckon this grease would work fine for ball bearings in a 3 pt. rototiller? There is a single grease zerk opposite the gear drive end that houses a big ball bearing. What about for the grease zerks on the front axle support hub where the drive propeller shaft is on the L2501 tractor? This would be the grease zerk where you remove the breather port, grease it until grease oozes from the port, then replace the screw in the breather port. I would assume the #238 grease would be ok here. The only other thing I wonder about beyond this, that comes to mine at present, are using it on my zero turn mower's belt pulleys, which have grease zerks on them - likely another bearing of some type in the pulley. Thus far I have not used the grease, so I can still 2nd guess these things. Curious what you guys would think about these 3 applications with the #238 grease, which is a 5% moly compound grease.
Also, what about PTO shaft grease zerks?
Rototiller bearings =no
Front axle = no idea what is there but probably ok
Zero turn mower = no
PTO shaft = no
Bearings will probably skid (rolling element not rotating but sliding). Element gets flat spot, bearing fails early. Early may be ten years from now or 10 months but still fails.
4,199
Tornado…. if you want only ONE grease for EVERYTHING… then select a major-brand general purpose NLGI#2 Lithium grease. You can use that on all bearings, pins, bushings, front end loaders etc etc etc. While “moly” is better for sliding bushings and pins…ordinary lithium grease will also suffice for that…. (and is likely why Kubota wants you to grease it every ten hours …because they have no idea what kind of grease you will actually choose in that service. BTW…. does Kubota mean every ten hours of TRACTOR operating time? or FEL operations? (wink)
Anyway…. you want to simplify your greasing chores? Get a good quality name brand lithium grease and use it everywhere and often.
Tornado
792
255
usa
Appreciate your suggestions. I personally would prefer a single grease option, simply because Im not someone who is out using his equipment all the time, as I have said. Running 2 seperate greases for example means Id prolly have tubes sit in the gun for 2 years before I used them all. Again this is not because I dont grease but because Im only putting 50-100 hours or so on the tractor per year. My rototiller (which I JUST bought and is brand new woohoo!) I will use it a few times per year to seed some grass seed, or plant my garden in the spring, etc. Of course I will grease as called for, and every time I use the rototiller, but still my hours are just so low, it still takes a while to use a tube of grease.
I have the Schaeffer's 238 on hand now but have not used it yet. I've still been pondering. I think I may actually end up going with lithium or something, even though I've already bought the 238 Schaeffer's. I may just buy a 2nd gun and run the 238 strictly for loader pens and stuff on the FEL, even though Id prefer 1 grease.
B737
LX3310
Jun 9, 2019
2,022
2,205
I hear you tornado. I have the second power grease gun, and tubes of 274 sitting in the cabinet, I just haven't brought myself to making the switch to using two different types either. I just keep using R&T. I know one size doesn't fit all but....
Maybe the fact im too lazy to switch to two types incentivizes me to grease more frequently with single haha
4,199
If you are using the Schaeffers 238 “ulta supreme”…. THAT is an “aluminum complex” grease and SHOULD NOT be mixed with lithium greases. Further, it contains “moly”…and should NOT be used on roller or taper bearings. It actually has limited-purpose uses for that reason.
I’m disappointed in Schaeffers’ promotional material which is described by them as “Technical Data” …. as it specifically says this: “The molybdenum disulfide and solid lubricant package allows the Ultra Supreme to act as a “backstop” lubricant when the grease base is either destroyed or wiped away due to unexpected loads, start-up or other conditions which can exceed the capabilities of the grease base’s fluid film lubrication.“
That statement was posted AFTER they’d made all their brags about how good their grease is. QUESTION: If their grease is THAT good….. Then WHY do they subsequently brag about how protective it is as a “backstop”….. AFTER IT BREAKS DOWN?
There’s a warning-flag there in my opinion.
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
I think your chart may be outdated regarding the polyurea grease type. Incomplete at best.
Shear-stable polyurea based greases like Lucas X-tra HD are compatible with almost all other greases, only borderline with barium complex greases.
B737
LX3310
Jun 9, 2019
2,022
2,205
yeah im not up to speed on the latest developments in grease. I just pasted the first thing that came up on google.
rScotty
Kubota M59, JD530, Deere 310SG
Aug 19, 2010
29
12
Colorado Mountains
Yes, I agree. Wide compatibility is partly why I like the polyurea greases like that Lucas X-tra and the JD TY6341.
As to those tables, there are lots of those grease compatibility tables and more than a few are just advertising. Nobody is surprised anymore to find the internet lends itself to data manipulation.
Below is an interesting article on how grease compatibility can be measured more technically, and some examples of how to construct relatively unbiased grease compatibility tables as well.
As with all of these things, compare it with your own education & understanding of the science involved.
rScotty
Elliott in GA
Mar 10, 2021
876
884
North Georgia
I thought Messicks covered all of this pretty well - use Polyurea High Temp grease for everything (unless you have something unusual).
rScotty
Aug 19, 2010
29
12
Colorado Mountains
They do put on a good video, and in an entertaining way that I enjoy too. But now I'm curious because there in now a new generation of mechanical guys who are way different from my older generation...
I think we all know that lubrication is a pretty scientific and technical issue that is much studied by some pretty smart people with a lot at stake. In fact, I once worked building hard drives for a guy who had a PhD in "grease and ball bearings" is how he put it.
I'm saying there is a LOT known about friction and chemistry that applies to grease & all lubricants.
Messicks are great guys, but their field isn't science. Their field is opinion and salesmanship. That makes them good guys, but they don't offer any references for their opinions. No background or experiments. They just state their own opinions as truths like they were peer-reviewed facts handed down from on High.... instead of what they really are..... which is just personal opinions. We all have those.
That doesn't bother you? Actually, like I said....I'm just curious. It doesn't bother me either; I like their videos. But liking their dog and pony show show doesn't mean I believe them.
rScotty
(I don't believe Spiderman either, but I do believe in his Aunt May)
Elliott in GA
Mar 10, 2021
876
884
North Georgia
rScotty
It is hardly just some opinions by some salesmen. They have training from industry groups and manufacturers plus decades of experience (including their service shop employees). They buy their products from people that only sell that type of product.
I see the same kind of thing on the boat forum I visit. People ask what type of oil to use in their marine engines, and various members start posting about this oil or that oil. The members that are actually employed in the boat industry, many as techs, all say use the recommended Yamaha oil.
Tornado
792
255
usa
Appreciate the replies. Ive seen all the above charts on compatability and the messicks video I saw a long time ago. Grease is just another one of those things where you get 500 opinions when you start asking, so it often doesnt help to ask. Im going to just follow my own research and come up with something. I still havent used the 238 schaeffers on anything and wont until I figure out what Im going to do.
