Switching grease and pondering compatibility issues
Elliott in GA
Mar 10, 2021
884
896
North Georgia
Appreciate the replies. Ive seen all the above charts on compatability and the messicks video I saw a long time ago. Grease is just another one of those things where you get 500 opinions when you start asking, so it often doesnt help to ask. Im going to just follow my own research and come up with something. I still havent used the 238 schaeffers on anything and wont until I figure out what Im going to do.
Well, the good news is that you will probably (95%+) be fine with whatever you choose, as long as you buy a reputable brand grease that is formulated for the intended purpose.
The bad news is that you can pay more (for grease and grease guns) and use multiple greases (more effort) to get the same results as using one reasonably priced good quality grease - but you may enjoy the process. :)
Good luck.
B737
LX3310
Jun 9, 2019
2,022
2,205
this is pretty much what happened to me. I got all gun-ho about using two greases, started 'researching', spun myself into confusion because internet, shelved the entire idea :ROFLMAO:
Pau7220
Aug 1, 2017
785
280
Scranton, PA
That's why I use the Lucas red n tacky now. Under $4.00/tube and works just fine. I can also add that I've never had a part seize, fail, or wear out while using this product. Including the abused mower spindles on my 1998 Honda 4120 which my wife runs.;)
Tornado
792
255
usa
Well to be honest, I feel I could use the schaefers 238 in everything I own and probably be fine. I am aware it is likely not ideal for every case, but with the low hours I put on equipment, it likely wouldn't actually cause much harm in the long run. Ive seen people run PTO shafts with no grease for years for example - yea its not recommended and far from ideal, but ive seen it happen and the PTO shaft keeps right on working, year after year. Ive seen rototillers where people never changed the oil and rarely greased, they keep on working. The problem for me is that I am a perfectionist, and when It comes to any equipment, computers, or other material investment, I always go for the best. because of that I have tried to find the best grease, no matter the price. Saving $10 on a years worth of grease to me is really nothing if spending that extra $10 means superior protection. Anytime it comes to fluids, oils, grease, filters, anything on my equipment I research and go for the top stuff. Going cheap on stuff you change once a year like oil just makes zero sense to me. Grease has of course proven to be a monster, simply because there are so many applications of grease. Pressure, Heat, Pins, Bearings, Gears, etc. and for each use case there are multiple types of options, and for each type, there are multiple brands all with their own twist.
Elliott in GA
Mar 10, 2021
884
896
North Georgia
FWIW, if you have not seen this video. #8 is about Polyurea grease, and it comes to the same conclusion as the Messick's video.
Tornado
792
255
usa
Yes, I have watched a lot of these videos. Also the video tractor time with tim did with the guy from lube shuttle in germany. He recommended his lithium based grease if you were going to pick one grease to use for tractor type applications.
Elliott in GA
Mar 10, 2021
884
896
North Georgia
I will take Messick's and Tractor Mike over Tractor Time with Tim - every time. :LOL:
Good luck with your choice/choices.
rScotty
Kubota M59, JD530, Deere 310SG
Aug 19, 2010
29
12
Colorado Mountains
Yes, I'd sure agree with the luck part.
And I did get - if not an answer - at least some more to think about as to whether a discussion about grease compatibility made more sense based on the grease or based on compatible opinions.
And in the bargain I also begin to understand a few other things I was wondering about.
Some of us old guys start questioning all kinds of things we used to just accept when we were younger.
Since grease is basically a base material carrier and a lubricant, I think I'll just add the lubrication part of the grease when I re-lube the sealed steering ball joints on the M59. Using a needle through the rubber covering, I can add a viscous oil (grease's lubrication component) to the existing carrier material. That way the base material compatibility is assured.
rScotty
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,976
2,357
Western MT
I’m kind of surprised the thread is still going. Most grease fittings only hold a tiny bit of grease and even if they were incompatible the old would be pushed out after a few greasings.
wendol
L3800 HST
Feb 5, 2014
202
45
North Tx
FWIW, In Jan of this year I was on the same search for "1 Grease for All Applications".......contacted Schaeffer Co with my needs that included FEL, General Lube, and Zero Turn Blade Spindles......their recommendation was Schaeffer's 219 NLGI #2 SynForce Green Grease.
However after much research, I decided to go with 2 different grease types, as the all this equipment is too expensive to cut corners for convenience and a couple of dollars............my $.02!!
4,228
It’s not “perfectionist” to resort to one-size-fits-all. That is termed “compromised”. ;)
