Hello all. I havent been around here much lately. The grease I had been using on my L2501 and variouns implements has become hard to buy, perhaps due to covid, and so I am changing greases. Ive done a lot of research and went back and forth on which product to go with. Ive researched every major option. I wanted to go with one that was more widely available. I settled on Schaeffer's 238 Ultra Supreme The grease I had been using was one a little harder to find, but also one I had done a lot of research on at the time: Prolong's EP2
Schaeffer's grease is an Aluminum Complex grease. Prolong's EP2 is a Calcium Sulfonate grease. Looking online at various charts and things, these two grease bases are listed as "borderline" for compatibility; so not incompatible, but not compatible either.
I really want to try and avoid a grease debate here on which is better - That is not the purpose of this post. What I am trying to better understand is the issue of incompatibility of greases. I know there are many long time equipment owners here who have been greasing zerks for much longer than I have, and likely could share some experience on this topic. As I said my primary greasing functions are the tractor loader, my pto shafts, my lawn mower belt bearings, etc. When I do finally run out of my old tube and go to the new grease I plan to, especially on the loader and such, really pump the grease to it hard to hopefully push as much old grease out as possible. What sorts of issues have you guys seen when switching greases?
