PTO Clutch Bolts Seize
Grizzo
20
Australia
Hi. I have a 200mm 8bolt clutch on a 7ft slasher. The problem I have is after a while, usually when I replace clutch discs, some of the spring bolts will seize up and cannot be unscrewed. Need to be cut off.
Is this a common problem and what is the cause and any solution?
Thanks
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Rust and corrosion can be a cause. The locknuts can also be a cause, especially the staked kind with the dents on the flats or the ones with the last threads rolled over.
Yooper
3901 LA525
May 31, 2015
1,751
929
NE Wisconsin
Anti seize on the threads might be the solution. If those bolts get hot they make a high temperature anti seize with copper I have had good luck with
5,188
I put anti-seize on everything.......even my pancakes!🤣
5,188
I don't necessarily put it on everything but it seems to end up there...
Yup!
The stuff does seem to have legs.
No matter where you apply it, there will be instant migration, to other places where you did not want it.
