Hi. I have a 200mm 8bolt clutch on a 7ft slasher. The problem I have is after a while, usually when I replace clutch discs, some of the spring bolts will seize up and cannot be unscrewed. Need to be cut off.
Is this a common problem and what is the cause and any solution?
Thanks
Thanks
