Plasma cutting
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,210
1,826
Pittsburgh
That's a lot of capacity for single phase.
Sidekick
Jul 29, 2023
1,270
1,826
N.Y,
These are cuts from my Hypertherm 45. Just under 3/8 steel that is near the high limit on duty cycle when cutting a sheet full. Will do 1/2 but not as straight and clean a cut. Great hobby machine that id easy to switch from hand torch to machine torch.
dlsmith
BX2230, LA211
Nov 15, 2018
1,363
1,064
Goshen, IN
I have a Hyperthem Powermax 1000 G3 and it slices through 1" steel like butter, slower speed, 1/2" and under, I can blow thought it like Darth Vaders light saber. Sure makes you want to throw rocks at the oxy acet set up, but they have their place too.
Having the power of the sun at your finger tips is awesome. I have those stainless templates for cutting circles, squares, trailer light holes including those oval truck lights.
Nice narrow kerf, with a straight edge, little cleanup grinding and no pre heating metal before cutting, stone cold, you are in and out. 1/4" steel, after I cut it with plasma, I can pick up up bare handed in about 10 minutes, oxy acet cut, 3rd degree burns.
What a great time to be alive, all this cool technology.
I have the same machine and love it.
Sidekick
Jul 29, 2023
1,270
1,826
N.Y,
That is a very nice kerf.
Here's an old boring video of one of my plasma cut design and build projects that shows the quality of plasmacuts once dialed in. My welding sucks but plasma cuts by the Hypertherm 45 are all beautiful. The biggest challenge was building the cnc table back then before Cheap Chinese controllers and components. If you go to the end, you can see the finished project.
OrangeColoredTractor
2017 L2501 4WD HST
May 10, 2017
75
23
Washington
It says 1.25 thick steel but only a seperation cut. Ive done 1 inch easily.
I have gouging tips and drag tips. Cuts are so clean. If you use a guide and steady. No gringing needed.
Had feature to keep pilot arc on for cutting expanded or perforated metal
