Piranha Toothbar
rquad
B2710, 48" Land Pride cutter, 48" Land Pride box blade
Oct 16, 2014
GA
Has anyone had a Piranha bar long enough to see how well they hold up over time? I'm especially concerned with sharpness.
I'm really interested in this bar, but worried it will dull down after lots of use. Since you can't replace the teeth, can you sharpen them? If so, how many times before you have to replace the whole thing?
2,871
BULLET PROOF......
YOU WILL NEVER SHARPED IT THAT MUCH - IT IS A MONSTER, IT DOES NOT HAVE A RAZOR EDGE BUT WILL never dull to a point that it does not work well.
Trust me - order it yesterday, and kick yourself tomorrow !!!
this is a close up - the metal plate is under this for snow, but look at that 1/2 piece of steel , it might dull - but the dirt will never mind the dullness!!!:)
bearskinner
Sep 1, 2014
926
241
N. Idaho
Will I have to take that off to use clamp on bucket forks? Kinda looks like it.
I have a BX and take it off when I use the bolt on forks, but once the holes are drilled, and you use copper death on the bolts its a two minute change out. NO big deal at all.
phaser
B7100HST 4x4, FEL, field mower
Aug 6, 2013
171
Oregon
Copper death? What's that?
gottaride68
BW 25D, w/FEL, MMM, BH, and her name is CLementine
Aug 18, 2014
19
Alberta, Canada
Hey bearskinner, what do your bolt on forks look like? Homemade? I'm trying to skeem up a set...to cheap to buy em...
bearskinner
Sep 1, 2014
926
241
N. Idaho
haha, Its a name we have always used for anti seize either silver death or copper death, aluminum or copper. I use it on everything outdoors, tractors trucks, equipment, mowers. it keeps bolts from ever sticking or dis similar metals from corroding or galling the threads. If you get it on your fingers, the stuff is hard to clean off, it looks like some kind of disease! hence the death part.
bearskinner
Sep 1, 2014
926
241
N. Idaho
Ill take a pic this afternoon. I need to load my porch with wood for the stove, and my wood shed/ splitting cover is 100 feet away. Much better than hauling 4 or 5 pieces by hand, back and forth. I hook a pallet to the FEL forks and move a few hundred pounds at a time. its getting cold, so I need to load my porch rack. Ill hook the forks over the Piranha and give it a try just for giggles, but I think they will fit better with the tooth bar off. Ill take pics of both.
SLIMSHADIE
Kubota BX25D
Apr 10, 2013
445
Eureka,IL
I bought some 1500# Titan bucket forks from palletfork.com only $169 this spring. They fit in the same spot as bearskinner showed. They actually fit over the toothbar. Only bad thing is its always the same wide width without taking the toothbar off.
bearskinner
Sep 1, 2014
926
241
N. Idaho
It would appear that they made the Piranha with those reliefs, so an add on or bolt on attachments would fit easily without having to remove the tooth bar. If its not intentionally made that way, they just happened to do it just right! I know the Piranha is absolutely awesome in digging and removing small trees
sawmill
bx24 backhoe/fel, 48" Bush mower
Nov 16, 2014
582
193
ione, washington
Got my piranha tooth bar and installed it today. Looks pretty wicked. I scratched some ice with it so it wouldn't be so slick. It worked great. Have to wait till the snow is gone to find some dirt to play in. Haven't seen any dirt at my place since the first snow last fall.
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
I used to fall down a few times on the ice every year, since I have had the PTB and scratching ice I have not gone down for two plus years now. I figure the cost of the PTB is a moot point for that reason alone. I am glad you got it and it is on. Good investment Sawmill. I think I mentioned it before but I do not ever take it off.
bearskinner
Sep 1, 2014
926
241
N. Idaho
I never take the Piranha off of mine either. I'm using the snow blade now, so the whole FEL is off, but it's on the roller dolly with the toothbar intact
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
still a helpful thread!
was worried about backdragging my gravel but you guys covered that by using the back edge instead of the front...
awesome input as is the norm here!
thanks
