M maxxtcram New member Equipment L4630 GST tractor Jan 6, 2025 3 0 1 Mexico, Missouri Monday at 8:17 AM #1 frozen due to cold weather, will it thaw out by just running the tractor
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 11,859 5,143 113 Greensville,Ontario,Canada Monday at 8:24 AM #2 I tried finding a diagram, no luck, but if it's internal,you'll need a LOT of warmth to 'free' it up. others will know....
M maxxtcram New member Equipment L4630 GST tractor Jan 6, 2025 3 0 1 Mexico, Missouri Monday at 8:29 AM #3 GreensvilleJay said: I tried finding a diagram, no luck, but if it's internal,you'll need a LOT of warmth to 'free' it up. others will know.... Click to expand... Sprayed WD40 and let it idle for a bit and it freed itself up. Thank you
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 5,460 1,475 113 Austin, Texas Monday at 5:41 PM #4 maxxtcram said: frozen due to cold weather, will it thaw out by just running the tractor Click to expand... Frozen how or where? If outside the tractor then probably won’t thaw out and will need some external heat added. Maybe you can rent a torpedo heater?
D Dustball Active member Equipment 2016 B2650HSDC Sep 15, 2023 330 206 43 Hudson, WI Monday at 5:53 PM #5 Is it your linkages that are frozen or do you think it's internal? If it's internal, you must have water in your hydraulic fluid which is very bad.
M maxxtcram New member Equipment L4630 GST tractor Jan 6, 2025 3 0 1 Mexico, Missouri Monday at 8:18 PM #6 Russell King said: Frozen how or where? If outside the tractor then probably won’t thaw out and will need some external heat added. Maybe you can rent a torpedo heater? Click to expand... problem fixed; the heat of the tractor idling cured it.
