Parking brake
1,477
frozen due to cold weather, will it thaw out by just running the tractor
Frozen how or where? If outside the tractor then probably won’t thaw out and will need some external heat added. Maybe you can rent a torpedo heater?
Dustball
2016 B2650HSDC
Sep 15, 2023
331
207
Hudson, WI
Is it your linkages that are frozen or do you think it's internal? If it's internal, you must have water in your hydraulic fluid which is very bad.
