M maxxtcram New member Equipment L4630 GST tractor Jan 6, 2025 3 0 1 Mexico, Missouri Jan 6, 2025 #1 frozen due to cold weather, will it thaw out by just running the tractor
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14, Apr 2, 2019 13,226 5,885 113 Greensville,Ontario,Canada Jan 6, 2025 #2 I tried finding a diagram, no luck, but if it's internal,you'll need a LOT of warmth to 'free' it up. others will know....
M maxxtcram New member Equipment L4630 GST tractor Jan 6, 2025 3 0 1 Mexico, Missouri Jan 6, 2025 #3 GreensvilleJay said: I tried finding a diagram, no luck, but if it's internal,you'll need a LOT of warmth to 'free' it up. others will know.... Click to expand... Sprayed WD40 and let it idle for a bit and it freed itself up. Thank you
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 7,057 2,495 113 Austin, Texas Jan 6, 2025 #4 maxxtcram said: frozen due to cold weather, will it thaw out by just running the tractor Click to expand... Frozen how or where? If outside the tractor then probably won’t thaw out and will need some external heat added. Maybe you can rent a torpedo heater?
D Dustball Well-known member Equipment 2016 B2650HSDC Sep 15, 2023 457 316 63 Hudson, WI Jan 6, 2025 #5 Is it your linkages that are frozen or do you think it's internal? If it's internal, you must have water in your hydraulic fluid which is very bad.
M maxxtcram New member Equipment L4630 GST tractor Jan 6, 2025 3 0 1 Mexico, Missouri Jan 6, 2025 #6 Russell King said: Frozen how or where? If outside the tractor then probably won’t thaw out and will need some external heat added. Maybe you can rent a torpedo heater? Click to expand... problem fixed; the heat of the tractor idling cured it.
