New to Kubota BX2360 questions
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
Hi All,
Got my 2360 late fall last year. I have a few questions on the tractor since starting to use it since earl.y spring. Here we go:
I bought the tractor for mowing and scraping my road. Have a 4' rear scrape blade with a belly mower. I would like to keep the scrape blade on while mowing. There is a bracket on the top link connection that will hold it in the up position. The bracket looks to be a bit much to just hold the top link up but not heavy duty enough to hold the scrape blade in the up position when the mower is down. Also, what would you think about tying/chaining the scrape blade to the roll bar to keep it raised when the deck is lowered?
The mower height knob will sometimes turn to the top position to lock the mower in the up position but often it won't turn to this position. I thought I saw online that the position knob can be adjusted.
Really happy with most things on the tractor but the plastic engine cowling is ridiculous to put back on after removing. Just last week I opened the hood and saw that one of the U shaped pieces that the screw claps hold has broken off. The cowling just below this piece has cracked. I want to reinforce this area to prevent the crack growing. I was thinking that somehow gluing a piece of some kind of plastic over this area on the inside of the cowling might me the best way to go. Anyone have the problem and how you fixed it?
That's all for now. Thanks in advance for any input.
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
Hi All,
Your mower has to be fully raised in order to turn the 'Height Knob' to the Top position.
In order to keep the back blade raised, you'd need to reposition/move the 3pt arm links. Or, chain the arms up. It would be easy to use those mounting points and chain the 3pt arms in the raised position without moving the arms to the brackets on the ROPS.
Let me know if you have any questions.
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
Thanks, do have the mower in the fully raised position but still having problems getting the knob to the Top.
Looks like I would need need long locking pins to go through the link joint into the hole in the bracket. Is this correct? The tractor is located on some land we have, will be back there this weekend to see how this would work. Thanks for the input!
5,725
have to ask WHY you want the rear blade on while mowing ?
Also, check the front axle for oil ! yellow plug by left wheel...Most seem to find the axle LOW on oil.
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
Just kinda a pain to hook up and remove the blade when I need to use it. Some times of the year I have to scrape quite a bit. Lazy I know.
Have checked the front axle oil and it is good.
Sidekick
Jul 29, 2023
1,012
1,367
N.Y,
On mine the mower lift linkage has an adjustment that can help lift the mower a little extra to lock it in the top position. That linkage can also wear some and need replacement over time. Here's an old video of what caused mine not to go up to the lock position.
Grandad4
Apr 5, 2016
387
133
Greensboro, NC
3 point on/off gets easier with practice and a bit of imagination for how to simplify, especially with BX size attachments. It can be just about as easy to remove an implement as it would be to prop it up on the tractor. Besides, if it's parked somewhere else while you mow, it can't restyle the quarter panel on your pickup, take out your wife's prize-winning roses or snag the mailbox and pull it out of the ground while you pop a wheelie. Just passing along experience of many mowing hours on a BX along with best wishes for you with yours.
thendrix
M6800 BX2680
Jul 27, 2025
Winston12
Have you looked into quick attach for your blade? I'm not sure if they have them for implements this size but it's possible and would make things easier. Never have used them myself but we swap stuff around a lot.
Grandad 4, I believe me and you could right a book on the wrong way to remove/relocate items with a blade
RBsingl
Jul 1, 2022
485
565
Central IL
Shortly after I bought my Deere 955 in 1995, I built little cradles in the barn for the rear blade and the tiller which were a pain to attach if just randomly removed. With the cradle, everything is where it should be and simply backing the tractor in makes it easy to hook them up as needed. My rear mount snowblower came with an integrated stand that makes it easy to hookup although fortunately I haven't needed it in over a decade now. The 5' brush/field mower was far easier to attach than the "little" attachments until I built the cradles. Simple 2x4 (I used pressure treat) with V grooves or cleats as needed to hold your specific blade in place is all that is needed, nothing fancy. If you are short on storage space, built the cradles with wheels.
My Deere 955 has a 6' midmount deck and I would never use it for regular mowing with either the rear blade or front loader in place. One of the many benefits of having a Kubota F2690 to take over mowing duties is the loader stays on the 955 all of the time now. Any extra weight on the front or back when finish mowing will greatly reduce maneuverability, increase bouncing, and in many cases will negatively impact cut quality.
Rodger
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
***UPDATE*** Decided to go ahead and rep[lace my instrument cluster. Looked online and all sites showed that the part has been discontinued. Checked with my local dealer and Messicks, both tried to track one down but could not find it. Contacted Kubota who said that it is discontinued and there will be no replacement. SORRY I GOT A CUBOTA!!!!!!!!!
Sidekick
Jul 29, 2023
1,012
1,367
N.Y,
My BX2360 has been bullet proof. I bought it new and just basic maintenance has kept it running great for almost 1000 hours now. Wonder if you could find a used cluster because they are dependable tough little machines. Seems like most brands are discontinuing parts for machines over 10 years old due to cost to manufacture and inventory.
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
BlueRidgeRunner
Bx2360
Jul 19, 2024
27
Blue Ridge GA
Hard to believe that a 10 year old tractor is not supported by Kubota! Looking at the Messicks website, it looks like this cluster is used in many models - bx2350, bx2350,bx2370, bx24, and bx25. With known problems with this cluster all of these machines will not be supported. I sold my 20+ year old Deere and bought this thing. Never had problem getting parts for it. Should have stayed green!
