New to Kubota BX2360 questions
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
234
296
upstate, NY USA
If that is the only cluster available, and the pin outs are identical, you have run out of options.
There was a Kubota Technical Service Bulletin for replacing instrument clusters on older BX machines. There were three different part numbers.
1) BX 1860 & BX 1870 - all the 18 hp models.
2) BX 2360 & BX 2370 & BX 25 (backhoe variant) - all the 23 hp models.
3) BX 2660 & BX 2670 - all the 26 hp models.
So there ARE differences inside the cluster, likely the chip calibration for RPM.
But that's just an educated guess
I have a recently purchased BX 2370 that got a new factory instrument cluster as a condition for the purchase back in early spring of 2025.
I do mowing with that machine and wanted to be certain I was running it at the correct RPM.
Harbor Freight has a $35 or so laser/optical tachometer. You stick a piece of reflective tape on the edge of the flywheel. Spin it up to speed and compare the instrument cluster tachometer to the
Harbor Freight laser/optical hand held tachometer.
My new factory instrument cluster was within 100 RPM of the Harbor Freight unit at 3200 RPM.
I can live with that.
If @ white tiger spots this post, perhaps he can comment on the instrument cluster differences.
