Finally got to move some dirt with this trailer. The load shown is two B219 buckets full, slightly damp fine roadbed material. The B7100 didn't even know it was back there, even with a 3rd bucket in the loader.
Conclusions:
It is awkward to unhitch, load with dirt & hook back up, especially alone. (you better back it up to align the hitch exactly, because you won't move the trailer by hand once it's loaded) But I moved 9 buckets of dirt in 3 trips, instead of 9 trips.
On flat ground everything works great, but throw an 8" rock or stair step in the mix & the tongue drags; not much can be done to correct that, that is where the tongue lives.
The foam tires had almost no "squish"- much less than I expected.
The foam tires had almost no flotation in soft stuff. They dug deep ruts in my cinder driveway, while the R1 tractor tires hardly left a mark.
All in all, pretty happy with the trailer, dumping the load was a little PITA, but that was because of the damp material. Dry stuff would probably dump with no problems.
Conclusions:
