Lifting 5gal cans of diesel fuel a problem
BX23-S,57 A-C D-14,
5,806
It doesn't matter how easy it is to pump diesel into the tractor, it's PAYING for it at the pump that's the PAIN !!!
$2.40 here now, expect $2.65 mid July.... Too bad Canada doesn't have any oil in the ground....
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
or offshore, like near Newfoundland or Sable Island or somewhere !
(insert "rolleyes" animated gif here)
ACDII
Oct 21, 2021
685
429
Illinois
This is a perfect solution for someone that uses a lot of fuel. It would be an overkill for me since I only use 10-15 gal a month. But-I still havent seen a fuel transfer pump that I am in love with yet so I am going to leave this option on the table for now. Wonder if there is a 15-20 gal version of this?
There is a 37 gallon tank that I considered. The 50 gallon is easier to store and move though. For you needs it is overkill. Consider one of these instead, can wheel it around and if you have a trailer, just roll it right on, get it filled and roll it right off.
ayak
L3301 HST
Feb 16, 2018
704
1,004
WV
I saw too that some of the smaller ones when laid on their back to transport and fill, lose some of their capacity. I wanted something I could either fork into my truck bed or was easy to fill by using smaller jugs, if needed.
Freeheeler
b2650 tlb
Aug 16, 2018
706
526
Knoxville, TN
I used a 5 gal jug once, annoying for my back to hold the jug while pouring. I switched to a 2.5 gal VP jug with a curved spout. Works great. When I get too old to lift/pour the 2.5, I'll switch to a 1 gal jug. When I get to weak for the 1 gal jug, I doubt I'll be in any shape to be on the tractor in the first place ;)
xrocketengineer
Nov 14, 2020
834
781
Merritt Island, Florida
Oh, you will still be using the tractor even when you have gone down to a teaspoon at a time. 🙃
7,072
I got a cheapie 2-D-cell transfer pump too - - just got one with a longer hose to reach the 'Moline.
Gas cap is pushing 6 feet up, and I'm 6' 4". Good spot to set can on loader frame to get half way there. Wasn't an issue for me 40 years ago.... ;)
Works good - - can't go wrong for the $$.
RalphVa
738
321
Charlottesville
The Tera pump I have seems to be running forever on 2 AA rechargable cells. May be like my toothbrush which seems to run a year or more on a single rechargable AA.
xrocketengineer
Nov 14, 2020
834
781
I wish mine had lasted, since it was leaking badly. To make things worse, when I set it aside so that "some day" I could try to fix it, I forgot to to take the damn Duracells out and they leaked and destroyed the circuitry.
GrumpyFarmer
4,328
My terra pump has an ac plug, can take batteries (never tried that though) or alligator clips you can run off the battery.
MOOTS
MX6000
Jun 27, 2019
2,188
2,713
Canton, Georgia
Tired of 5 gal cans too. Bought this unit today. 100gal and 8gpm pump. Gonna mount to a HD oak or plastic pallet eventually.
7,072
What is brand and model.
Tera - deluxe model with 2.5 gpm, longer hose and nozzle. Still seems like I got a deal for $35 (?) or so.
If I didn’t need to reach further on the old-timer tractor, a $10 or $20 version would have been fine with me. Could probably extend the hose with a barb fitting and some tubing.
RalphVa
738
321
Charlottesville
That's one reason why I like rechargables: don't leak. I just leave my 2 AA ones in the pump.
ACDII
Oct 21, 2021
685
429
Illinois
Downside of that 50 gallon tank. Oh it doesn't actually hold 50 gallons, more like 47. I put 15 in the truck, and had about 6 in the tank.
Dieseldonato
Mar 15, 2022
728
439
Pa
Not nessisarily a cheap set up, but I have an 8 gpm flow rite pump. It's rated for gas or diesel. Not super heavy has pretty long cord for power. Have a water blocking type filter on it. 12 volt. Works pretty well. 3/4" hoses on it. I should really get a gas pump style nozzle for it, but I use it to transfer in and out of a 275 gal tank. Gas nozle would get old to hold open imo. It's a bit slow for larger tanks. I also have this "heavy oil pump" it was made to pump oil in and out of a Komatsu powered generator. It's really fast, but 24 volt, and quite heavy. Used it a lot when I did road work. Every thing was 24 volt and held lots and lots of oil. Made life easy. Now I just hate to use the heavy bugger. I have a poly 55 gal drum rigged up with some 2x4 and metal straps to toss in the back of the truck. Not ideal, and I only fill it to about 40 gallons. But it works. Just hook that little fill rite up to the bottom hole in it. Open the valve and pump into whatever. It's real handy when I'm not around the house and working in the woods, or over at my mom and dad's place. One day I'll get a real transfer tank.....
robert2601
Afton,Tn
OUCH!! That hurts
