L3130 HST drastic loss of power
7,477
"NO" Difference bottel feeding ?? now what
Then you next job is to Compression test the engine.
You've got it down to injection pump, injectors, or internal issue.
I'm leaning 50 / 50 between injection pump or injectors, but more info would be better.
ferguson
L3130
Jan 19, 2022
296
115
w.v.
There is "0" blow by on the valve cove breather hose / going to hook my old brush hog tomorro / test to see trans. or eng. see if eng. bogs down under that load
Fordtech86
L3200
Aug 7, 2018
4,970
5,916
Pineville,LA
I’m not tractor tech, but it still sounds like something is causing an extra load on the tractor, don’t think you have an engine or fuel system issue from the way it reads 🤷‍♂️
does it act the same way in 2wd and in 4wd?
ferguson
L3130
Jan 19, 2022
296
115
w.v.
Brush hog ??? have to travle to put load on brush hog / Transmission temp this is all external with a good fluke heat gun / Eng. up to full temp travling arrounr yard 1/2 hr both filters 147 hotest i can find 154 ????
ferguson
L3130
Jan 19, 2022
296
115
w.v.
Any ideas on how to put a load on the eng. without travling ingaging trans. / try a brush hog /backed in a chip pile & droped it in / not long enough to put a load on eng. just long enough to make a mess
5,336
2,010
send your 3 point hitch lever down somewhere to the middle. See if it makes any more power with it in the middle than all the way up
also iv'e seen on the grand L 2900/3300 series, the hydraulic block selector screw if it's halfway between "on" and "off", it'll do the same thing--pulls a bunch of power out of the engine to deadhead the hydraulic system. And quick couplers on the loader will cause it too if one of them ain't connected all the way.
ferguson
L3130
Jan 19, 2022
296
115
w.v.
what & were is the hyd. block selector screw
7,477
When you did a hydraulic filter and fluid change did you change both filters ( right and left side)?
if so:
What fluid did you use?
and what filters did you use?
