Question: how do you jump(bypass) the PTO safety switches to isolate them from the system during troubleshooting?
I checked that too. I put a jumper wire on it just to double check. No joy.I have a gear drive L, when this happens on mine it’s the range switch. Usually gets grass/debris in it.
edit to be more specific…it gets debris in the range shift lever and doesn’t let it return all the way to activate the switch.
I think I am down to the ignition switch. Because the stop solenoid sometimes clicks when the ignition switch is turned and sometimes not. Thoughts?
